pvidal
NETWATCH issue with DHCP-CLIENT
Mon Jun 10, 2013 5:23 pm
Hi!
Im trying to monitor a gateway of my ISP. Im using netwatch for that purpose. Basically, i need that when that GW is unreachable (DOWN) the netwatch enables the DHCP-Client for an eth interface (in this case, ether1), and when is UP, the opposite: disable that DHCP-Client over that eth. When the GW is UP, the "disabling" of that eth works fine, but when its DOWN, is not working.
Here i attach a screenshot. What is wrong with this?
Thank you in advance!
Regards
ditonet
Forum Veteran
Forum Veteran
Re: NETWATCH issue with DHCP-CLIENT
Mon Jun 10, 2013 7:00 pm
On Up:
ros code
/ip dhcp-client set [find name="ether1"] disabled=yes;
On Down:
ros code
/ip dhcp-client set [find name="ether1"] disabled=no;
HTH,
pvidal
Mon Jun 10, 2013 8:45 pm
On Up:
ros code
On Down:
ros code
HTH,
Thank you so much!
pvidal
Mon Jun 10, 2013 9:13 pm
ros code
On Up:
[code1=ros]/ip dhcp-client set [find name="ether1"] disabled=yes;[/code2]
On Down:
[code1=ros]/ip dhcp-client set [find name="ether1"] disabled=no;[/code2]
HTH,
In rOS 5.x didn't work for me (i just tried it), but like this yeah:
ros code
/ip dhcp-client set [find interface="ether1"] disabled=yes
on UP
ros code
/ip dhcp-client set [find interface="ether1"] disabled=no
on DOWN
Thanks for the guidance!
ditonet
Forum Veteran
Forum Veteran
Tue Jun 11, 2013 6:49 pm
Try interface name without quotation marks:
ros code
/ip dhcp-client set [find interface=ether1] disabled=yes
/ip dhcp-client set [find interface=ether1] disabled=no
HTH,
