normis
RouterOS 6.1 released
Wed Jun 12, 2013 2:47 pm
All reported issues are fixed
What's new in 6.1 (2013-Jun-12 11:50):
*) pptp, l2tp - fixed crash when tunnel mru was too big and fragmented ip packet
was received;
*) hotspot - fixed problem when after upgrade hotspot html directory was empty;
*) ipv6 nd - dns dynamic-servers were not included in router advertisements;
*) winbox - fixed problem Switch menu disappeared on RB2011;
*) fixed memory amount issue on RB1100AHx2;
*) console - '/import' prints each command that is executed;
*) console - 'import' has new argument 'from-line' that starts executing
commands after specified line;
*) secure api - fixed problem when wrong client ip address was reported;
*) hotspot - fixed universal client;
*) api - added support for API over TLS (SSL);
*) api - api service is now enabled by default;
*) ppp - do not show R flag for locally authenticated users;
*) vrrp - fixed ah authentication;
*) webfig - added support for RADIUS authentication (via MS-CHAPv2);
*) ipsec - for peers with full IP address specified system will
autostart ISAKMP SA negotiation;
*) trafficgen - added inject-pcap command for replaying pcap files into network;
*) dns - retry queries with tcp if truncated results received;
*) improved queue statistics updating;
*) fix 1G linking with some Cisco devices (affects RB7xx, RB9xx, RB1100, RB2011, CCR);
http://www.mikrotik.com/download
normis
Re: RouterOS 6.1 released
Wed Jun 12, 2013 2:58 pm
use "check for updates" button in your "packages" menu to get the new version. Works in console too!
timoid
Wed Jun 12, 2013 3:19 pm
vlan issue fixed?
normis
Wed Jun 12, 2013 3:20 pm
vlan issue fixed?
if you mean Intel cards and VLAN - yes
jandafields
Wed Jun 12, 2013 3:22 pm
I've downloaded this 3 times, with the auto-updater and also direct from the website and dragged it into winbox.
Every time, after rebooting, it does not upgrade. The log says "broken package routeros-mipsbe-6.1.npk"
doush
Long time Member
Long time Member
Wed Jun 12, 2013 3:24 pm
it installs fine here . mipsbe
normis
Wed Jun 12, 2013 3:25 pm
possibly in your proxy cache is a broken file. try here:
http://www.mikrotik.com/download/router ... .1.torrent
picmixer
Wed Jun 12, 2013 3:29 pm
RB2011UAS-2HnD-IN Tx Power Problem
ROS V6.1 and V6.0 (Firmware 3.08)
On wireless tab
Frequency Mode set: manual txpower
Country: no_country_set
Atenna Gain: 0
Tx Power tab
Tx Power Mode set: card rates
Tx Power set: 18 dBm
Current Tx Power tab show all rates = 30 dBm Total Tx Power
Why is it so? Or I before it didn't notice?
kirshteins
Wed Jun 12, 2013 3:34 pm
Is this router running one of the last rc versions? In that case try netinstalling.
kirshteins
Wed Jun 12, 2013 3:39 pm
On wireless tab
Atenna Gain: 0
Tx Power tab
Use all-rates-fixed instead of card-rates for AR9300 WLANs.
jandafields
Wed Jun 12, 2013 3:42 pm
Yes, it is running 6.0 RC15
Does RC15 break upgrading?
kirshteins
Wed Jun 12, 2013 3:47 pm
One of the pre-release build for rc15 had this problem with upgrading. Netinstall if you see "broken package routeros-mipsbe-6.1.npk" message.
picmixer
Wed Jun 12, 2013 3:48 pm
Please update FAQ and Manual))
macgaiver
Wed Jun 12, 2013 3:52 pm
AFAIK RC15 was never released :) so it never happened.
honzam
Wed Jun 12, 2013 4:22 pm
It pre-release version. From development page
normis
Wed Jun 12, 2013 4:27 pm
use at your own risk, it says ;)
Reborns
Wed Jun 12, 2013 4:40 pm
Hello MikroTik team..
What does that mean ? and why ???
Upgrading from 5.25 to 6.1
Thanks,
normis
Wed Jun 12, 2013 4:41 pm
Thanks,
you have newer one. so don't worry and leave it untouched.
toni17
Wed Jun 12, 2013 4:57 pm
Are included Global-In & Out Simple Queues in this version ? If not im never upgrade ROS. I really need them .
hci
Long time Member
Long time Member
Wed Jun 12, 2013 5:41 pm
When I load this on RB333(PPC) and upgrade from 6.0 to 6.1 I loose access by IP after about 60 seconds but can still get into it via MAC address. Down grading to 6.0 fixes it. I suspect it has something to do with bridging. Loaded 6.1 on a RB951-2n(mipsbe) with almost exact same config, (pppoe client, NAT, IPv4, IPv6, bridging, UPNP and etc), no issues at all.
Chupaka
Wed Jun 12, 2013 6:29 pm
they are not. and they won't be included
why?
doush
Long time Member
Long time Member
Wed Jun 12, 2013 6:55 pm
@Normis
Bonding issue still same.
http://forum.mikrotik.com/viewtopic.php ... 50#p372661
I have upgraded to v6.1 per your suggestion and nothing changed.
Ticket#2013061266000864
toni17
Wed Jun 12, 2013 6:59 pm
I don't undrstand why mikrotik didn't include Global in & out in new versions . I use marked packets from layer7 firewall and then include them in global out simple queues , youtube & facebook etc .
alphahawk
Wed Jun 12, 2013 7:12 pm
Does this fix issue where auto negotiate is disabled and still the port will not link up?
THanks
sx10
Wed Jun 12, 2013 8:43 pm
Anyone having trouble with routerboot upgrade? It shows I am out of date but upgrading does not change the current version. No error message, nothing in log.
ropeba
Wed Jun 12, 2013 9:15 pm
Is IGMP proxy fixed?
ghi000
Wed Jun 12, 2013 9:41 pm
ipsec from 6.1 to 5.25 - no connection
ipsec from 5.25 to 6.1 - packet rejected
marcodor
Wed Jun 12, 2013 10:32 pm
IGMP works perfectly in 6.0 and 6.1 versions.
Tested on RB951G-2HnD
m1byo
Wed Jun 12, 2013 10:51 pm
I found on 6.0rc14 that I had to tell it to upgrade routerboot, then reboot the router.
Same on 2x RB751-2nHD and 1xRB2011-2nHD-IN
THG
Wed Jun 12, 2013 11:07 pm
I found a minor GUI bug in the DHCPv6 Server Bindings. IPv4 servers show up in Winbox and Webfig.
erebusodora
Thu Jun 13, 2013 8:37 am
Before upgrade changelog in Sysstem->Packages->Check for upgrade is show but after is gone why ?...I think the cnahgelog is show always before and dfter ugrades.
normis
Thu Jun 13, 2013 9:10 am
The changelog is being read from the server. After upgrade, you no longer are connected to the download server. Better read before you click the button :)
boroday
Thu Jun 13, 2013 10:02 am
Bug in master-port order after upgrade ROS 6.0 to ROS 6.1
RouterBoard 1100AHx2 with default config after system reset:
1.
/interface ethernet set ether7 master-port=ether6
/system reboot
ROS 6.0: Work fine.
ROS 6.1: System hang after reboot with no led light on port 6 to 13, port 1-5 lights on, but device is unaccessable.
Reset config by S402 pin hole.
2.
/interface ethernet set ether1 master-port=ether2
/system reboot
ROS 6.0: Work fine.
ROS 6.1: System hang after reboot with no led light on port 1 to 13, device is unaccessable.
3.
/interface ethernet set ether2 master-port=ether1
/system reboot
ROS 6.0: Work fine.
ROS 6.1: Work fine.
Shkrid
Thu Jun 13, 2013 12:19 pm
Ggraphs did not save interface graphing data after reboot
/tool graphing> export verbose
# jun/13/2013 12:10:44 by RouterOS 6.1
# software id = EFBE-4LMB
/tool graphing
set page-refresh=300 store-every=5min
/tool graphing interface
add allow-address=0.0.0.0/0 disabled=no interface=all store-on-disk=yes
/tool graphing resource
add allow-address=0.0.0.0/0 disabled=no store-on-disk=yes
/system resource print
             uptime: 12m2s
            version: 6.1
         build-time: Jun/12/2013 11:50:54
        free-memory: 3203.1MiB
       total-memory: 3969.0MiB
                cpu: tilegx
          cpu-count: 36
      cpu-frequency: 1200MHz
           cpu-load: 1%
     free-hdd-space: 428.1MiB
    total-hdd-space: 512.0MiB
  architecture-name: tile
         board-name: CCR1036-12G-4S
           platform: MikroTik
timoid
Thu Jun 13, 2013 1:25 pm
VRRP - V3(IPv6) doesn't seem to work. Downgraded one of the pair to 6.0 and its now the VRRP Master.
anajavi
Thu Jun 13, 2013 2:01 pm
IPv6 link local address for bridge interface seems to be somehow broken. It was also on 6.0.
Somehow it worked for the first reboot after upgrade, but the second reboot broke it.
The link local address now gets assigned to (unknown) interface.
 #    ADDRESS                                     FROM-... INTERFACE        ADV
 3 DL fe80::d6ca:6dff:fe3b:ec5/64                          (unknown)        no
If I remove this address, it gets regenerated in next reboot.
bycabral
Thu Jun 13, 2013 6:08 pm
After I've upgrade to release 6.1 some hotspot users can't get login, the system report that user name or password are incorrect, but they are not.
ropeba
Thu Jun 13, 2013 7:23 pm
You're wrong! Since there's a IGMP proxy in mikrotik there are two big bugs. One of them is described in this topic:
http://forum.mikrotik.com/viewtopic.php ... mp#p283100
Works fine if there's one upstream and one downstream but with more downstream interfaces huge problem exist.
I have almost 1000 of RB2011 in FTTB network and I'm also offering IPTV via them and I struggle with those bugs in IGMP proxy last two years
Each user is looking at one stream (one STB) but on their interface is going a few other streams too (bug). So, the stream of all the channels that the user has previously looked is going, and on that same RouterBOARD someone else was watching that channel. Stream will not stop until all the users on the RouterBoard leave the stream.
MrYan
Thu Jun 13, 2013 10:54 pm
I find that mine shows this for the wireless interface (or at least that's what the MAC address in the link local address implies).
regardtv
Thu Jun 13, 2013 11:45 pm
I trust you rebooted the router after the upgrade - otherwise the change won't have applied ;-)
heywood
Fri Jun 14, 2013 1:12 am
Sorry if this is an obvious question, but I can't figure out how to upgrade my 951G-2HnD from 5.25 to 6.1 at all.
Using WebFig, System > Packages > Check for updates says Current Version = Latest Version = 5.25, but the announcement at the top of this thread suggests that the RB9xx units should be able to find and perform this upgrade to 6.1.
For what it's worth, System > License shows Software ID = 9G0L-4HZF, Upgradable To = v7.x, Level = 4; and System > Routerboard shows Current Firmware = Upgrade Firmware = 3.07.
Can anyone point me in the right direction please?
Thanks in advance,
-H
Ivoshiee
Fri Jun 14, 2013 7:00 am
Thanks in advance,
-H
There are some automatic upgrade capabilities as well, but simplest is to download a proper arch image (.npk) and upload to your device. Then reboot and maybe your box will com up not a brick and all functionality intact as well.
normis
Fri Jun 14, 2013 8:34 am
Currently, the auto upgrade feature only shows minor revisions. If you have v5.xx it will only show v5.xx+1
To upgrade to a major revision, like the v6, you must upload this package in the Files menu, and reboot: http://download2.mikrotik.com/routeros/ ... be-6.1.npk
JanezFord
Fri Jun 14, 2013 11:56 am
ipsec (transport mode) between linux openswan and mikrotik stopped working after upgrade from 6.0 to 6.1 ... ipsec between mikrotik and mikrotik works OK ...
after downgrading to 6.0 everything works OK ...
normis
Fri Jun 14, 2013 11:57 am
please send full details of your configuration to support
ropeba
Fri Jun 14, 2013 1:03 pm
Hi Normis, I don't know why mikrotik stuff pretends to be deaf whenever someone mentions IGMP proxy, you don't know how to fix that bug or don't want to do that?
normis
Fri Jun 14, 2013 1:05 pm
There are things that are not easily fixable between minor revisions of software. It will be fixed when possible, but I can't make any specific promises.
PhilipLykov
Fri Jun 14, 2013 2:59 pm
IPSec Cisco - Mikrotik stopped working after upgrade from 6.0 to 6.1.
Guys, are you really don't test your firmwares?
PhilipLykov
Fri Jun 14, 2013 3:03 pm
URGENT!
Where to take 6.0 in order to downgrade?
We have upgraded RB1100AHx2.
janisk
Fri Jun 14, 2013 3:10 pm
need more details, IPSec did not receive any changes that would brake that.
try to enable debug logs on RouterOS and see what is happening.
PhilipLykov
Fri Jun 14, 2013 3:16 pm
IPSec logs or debug?
PhilipLykov
Fri Jun 14, 2013 3:23 pm
Logging doesn't work also!
[admin@ITSC_MKTK] > system logging print
Flags: X - disabled, I - invalid, * - default
# TOPICS ACTION PREFIX
0 * info disk
1 * error disk
2 * warning disk
3 * critical echo
4 firewall disk
5 ipsec disk IPSEC_
6 debug disk DEBUG_
No new records in the log...
PhilipLykov
Fri Jun 14, 2013 3:26 pm
0 * info disk
1 * error disk
2 * warning disk
3 * critical echo
4 firewall disk
5 ipsec disk IPSEC_
6 debug disk DEBUG_
I find out this bug with logging:
we have in settings "lines per file" = 50000 and "file count" = 250. And when the checkbox "Stop on Full" is set mikrotik would not create more than one log file. Bug?
normis
Fri Jun 14, 2013 3:44 pm
debug ipsec logs.
"ipsec,debug" is what you have to add. above shows incorrect configuration and is not supposed to work.
PhilipLykov
Fri Jun 14, 2013 3:48 pm
debug ipsec logs.
Why is it incorrect?
BTW: I sent you the logs, ticked #2013061466000628.
JanezFord
Fri Jun 14, 2013 5:47 pm
ipsec configuration of linux box, and export compact of two routerboards has been sent to support ... [Ticket#2013061466000753]
JF
heywood
Fri Jun 14, 2013 9:35 pm
Thanks -- that did the trick!
As an aside, it would be good to document this more prominently—I spent a fair bit of time reading the wiki and this was not at all obvious to me. Perhaps I just missed it in the instructions, though.
Cheers,
-H
sealin
Sat Jun 15, 2013 2:53 am
Hello MikroTik team
Why do you limit the number of routes by 251?
Could you please increase the number of routes limits? Thanks a lot.
ericthecat
Sat Jun 15, 2013 1:07 pm
Also have had IPSEC problems 6.0 <-> 6.1 - downgraded the 6.1 side, and its now working again. However it was intermittent - ie worked fine since about midday yesterday until first thing this morning, then stopped.
Rebooting 6.1 router didn't help - 6.0 one is live one so don't want to reboot :)
Using IPSEC Tunnel.
Do you want more logs or do you have enough to be going on with? (have had IPSEC debugging on for a while)
anajavi
Sat Jun 15, 2013 3:27 pm
I guess it's a confirmed bug then?
Quite erratic though, some reboots go okay, some don't.
ivanfm
Sat Jun 15, 2013 3:38 pm
I have upgraded from 5.25 to 6.1.
After upgrade I cannot login using web interface using Chrome 27.0.1453.110(Linux).
I got the message "ERROR: Internal Server Error"
I can connect to web interface using firefox, and I can connect using ssh.
MiKeDaDoC
Sat Jun 15, 2013 3:59 pm
Hi Folks,
had IPSEC Problems as well upgrading 6.0 -> 6.1
With downgrade to 6.0 everything ok again.
FYI
Configuration is multiple IPs on a two port-bridge WAN Interface on an RB1100AHx2. Multiple IPSec Peers to some RB2011xx and a Netgear Prosafe Router.
Problem was that only on IPSec Peer would establish correct SAs, randomly, that means it doesn't matter if it was the netgear or a RB2011xx. Analysing the problem showed that one had to deactivate all but one peer, this peer would come up perfectly. Then activate the next peer, wait until it would come up after nearly one minute. And so on.
One could also see that in the remote peer list the local adress would sometimes be the wrong IP-address on the WAN Interface (src-nat rule is ok as there are no such sympthoms with Version 6.0)
Chupaka
Sat Jun 15, 2013 4:57 pm
Hello MikroTik team
again: it's not the number of routes, it's the number of routing tables. why do you need so much of them?..
sealin
Sat Jun 15, 2013 5:40 pm
Hello MikroTik team
Thanks a lot for your replay.
Fiber lines are expensive in my country, so i am using more than 400 pppoe-clients(each one is limited by 4M).
I think this is one way to solve network bandwidth bottlenecks, and it is running very well for 6 months.
Could you please don't limit the number of routing tables? Thanks a lot. I have got the level 6 license, if you can support more routing tables, I need more license for other company&school.
Thanks.
Chupaka
Sat Jun 15, 2013 6:09 pm
I just duplicate the answer here:
Linux Kernel supports upto 252 additional routing tables, so MikroTik cannot break that limit
AlexVB
Sat Jun 15, 2013 7:17 pm
Is openvpn bug described in ticket 2013052266000927 fixed?
syahjo
Sun Jun 16, 2013 7:06 am
just download, see what could be better
omidkosari
Trainer
Trainer
Sun Jun 16, 2013 10:09 am
The problem previously reported , also occurs in 6.1 http://forum.mikrotik.com/viewtopic.php ... 50#p372627
After upgrade from 5.25 to 6.0 PPPoE client disconected after 3 hours on x86. System reboot PPPoE client conect again. Back to 5.25 all is OK.
Same problem with RB7xx . Manual disconnect and reconnect PPPoE client solves problem for few hours .
PPPoE client tx and/or rx freezes after few hours .
benesm1
Sun Jun 16, 2013 6:13 pm
I confirm the VRRPv6 bug. Please do something about it. We bought a couple of CCR1036 as our edge routers and such bugs are making me to second guess my decision. Mikrotik has to put more effort into quality control.
Russian
Sun Jun 16, 2013 6:59 pm
We have 2 problems with the Ros6.1 release.
importing rsc scripts has changed the calling structure and also the maximum characters per router script has been changed in Ros 6.1
The first problem is fixable with some work on rewriting the structure of the scripts, aka where we had to \\\ a " or $ it has to change to only 1x \.
The second problem we can also sort by breaking the scripts up into smaller scripts being called.
I do not see these changes in the change log, and wondered who else has experienced this problem?
We have advised our clients not to upgrade to Ros6.1 for the moment as we first need to rewrite our scripts and test it on the new version, as it currently breaks (fails) on importing the rsc script file.
Is this an error on Mikrotik's side or will things stay this way forward?
Any info welcome please.
bysard
Mon Jun 17, 2013 8:27 am
Dragging and dropping multiple files from one winbox (5.24) to another (6.1) terminates the winbox on 6.1. This wasn't happening in 5.x.
mikrohenry
Mon Jun 17, 2013 12:24 pm
Problems here with IPSEC between Draytek and Mikrotik 6.1 - worked fine in 6.0 but upgraded to 6.1 and found the VPN randomly disconnects and will not reconnect.
Workaround - copy the IPSEC proposal and the connection comes back up but the issue re-occurs.
No logs available at this time (production environment) :shock:
bysard
Mon Jun 17, 2013 1:28 pm
I have observed this with SSTP and PPTP links also, random disconnects after only a few minutes of uptime, stable link on both sides and no problems prior to upgrade to 6.1.
Main side = x86 Mikrotik
client sides = windows XP or windows 7 PPTP client
Cha0s
Mon Jun 17, 2013 4:40 pm
Same problem here with v6.1.
IPSec not working with v6.1 <> v5.25 and also with v6.1 <> v.6.1
aragon
Mon Jun 17, 2013 4:43 pm
This is turning into a spectacular problem for us too, and we've advised against 6.1 too. MikroTik, could you please be more careful with changing your scripting API? Some people have constructed elaborate management systems around it and have to also try accommodate multiple ROS versions across hundreds of routers. Changes like these really hamper the stability of the ROS platform.
So my first question, why does /import have to print script lines by default? Can you rather add a "debug=yes" or "verbose=yes" option to the import command, please? Reason being, we have scripts that are already perfectly verbose ala :put, so having ROS automatically print line numbers and commands creates an utter mess of the terminal output.
Secondly, please could you (MikroTik) explain exactly what other limitations have been imposed now, that Russian has observed? Right now all I see is scripts failing all over the network, and researching a fix will be much easier with an in-depth understanding of the changes you've made.
Thanks.
theprism
Mon Jun 17, 2013 9:45 pm
Windows 7 <- L2TP/IPSEC -> Mikrotik 6.1 stopped working.
Passing over L2TP and when at IPSEC it compains in logging about payload and triming.
Worked fine before upgrading
Mikrotik 6.1 <- L2TP/IPSEC -> Mikrotik 6.1 works fine.
Please fix urgently since affecting IPSEC like this is unpleasant.
I also upgraded the firmware based on this new release. Can I downgrade to 6.0, or my firmware won't allow it?
Thanks!
theprism
Tue Jun 18, 2013 7:10 am
Just to keep you informed...
Downgraded back to v6.0rc14.
Upgraded firmware to v3.07
Upgraded to v6.0
Keeping firmware at v3.07 (even if it asks to upgrade to v3.02 (not sure what kind of upgrade is this)) :)
L2TP/IPSEC works fine now.
Best regards,
the_prism
tkgit
Tue Jun 18, 2013 12:50 pm
running OSPF and wds-mesh, after upgrade to 6.1 then cpu always 100%
Shkrid
Tue Jun 18, 2013 3:10 pm
http://forum.mikrotik.com/viewtopic.php ... 83#p373130
sealin
Tue Jun 18, 2013 3:54 pm
Thanks,you are right!
It is limited by Linux.
JanezFord
Wed Jun 19, 2013 10:55 am
Upgraded to v6.0
Best regards,
the_prism
So it is clear now that v6.1 has issues with IPSEC that were not there in v6.0 and v5.25... has anyone received any feedback from Mikrotik about this problem?
Normis, Janisk?
Edit: Sorry to bother, but IPSEC connectivity is quite an important feature for me, since no other implemented vpn solution is not yet production ready (openvpn not fully implemented, sstp still not stable enough).
JF
Ulypka
Wed Jun 19, 2013 9:26 pm
so what about the [Ticket#2013061366000906] ?
majkel
Wed Jun 19, 2013 10:37 pm
Today version of 6.2 rc1 on 951G.. when on winbox clicking DHCP Server option >>> the winbox is crashing.. on rc1 from 17/06/13 its ok..
sniggle
Thu Jun 20, 2013 6:38 pm
Had the same problem, just clear your browser cache and it should start working.
paka
Thu Jun 20, 2013 7:41 pm
Hi Normis,
UM v6.1 has a bug, please check the link below
http://forum.mikrotik.com/viewtopic.php?f=10&t=73813
theprism
Fri Jun 21, 2013 6:31 am
Since I reverted back to v6.0, IPSEC works fine but I discovered a new bug, as follows:
If to disable the pppoe-out1 connection (ADSL) and to bring it back up, it will never connect and will rotate with this in logs:
23:19:26 pppoe,ppp pppoe-out1: initializing...
23:19:26 pppoe,ppp pppoe-out1: dialing...
23:19:27 pppoe,ppp pppoe-out1: terminating... - failed to authenticate ourselves to peer
23:19:27 pppoe,ppp pppoe-out1: disconnected
23:19:37 pppoe,ppp pppoe-out1: initializing...
23:19:37 pppoe,ppp pppoe-out1: dialing...
23:19:37 pppoe,ppp pppoe-out1: terminating... - failed to authenticate ourselves to peer
23:19:37 pppoe,ppp pppoe-out1: disconnected
Only reboot helps.
I don't recall to have such issues in 6.0rc14 and I'm not sure if they're present in 6.1.
If not - good, if yes - please fix in the next release.
Thank you,
the_prism
alexanders
Fri Jun 21, 2013 8:57 am
What happening with cpu load in 6.0-6.1? here is cpu graph and bridge graph. Why the cpu load is so high if there is no traffic? In firewall i have only two dest nat rules, and only two scripts,one for dyndns and second for vpn connectivity check.
rb751U-2Hnd, 6.1.
normis
Fri Jun 21, 2013 9:02 am
alexanders check what "tool profile" menu shows. you will see which process takes it.
alexanders
Fri Jun 21, 2013 9:09 am
Have checked, dns showing from 90 to 40-30-20-0. what can be wrong with dns ?
normis
Fri Jun 21, 2013 9:10 am
you have "allow remote requests". have you made firewall rules to protect your router from DNS queries by unknown hosts? maybe your router is being abused from outside. create firewall in the input chain
alexanders
Fri Jun 21, 2013 9:28 am
normis
thanks, this help.
infused
Fri Jun 21, 2013 10:15 am
On RC13, 60 days uptime in production. Do you recommend upgrading to 6.1?
normis
Fri Jun 21, 2013 10:17 am
Don't fix what ain't broken. If you are happy and nothing is missing, stay with what you have.
crtee
Fri Jun 21, 2013 11:30 am
That's one of the lessons you learn the hard way :lol:
Anyways - for me, 6.0rc13 on CCR is quite rock-solid at the moment. No problems so far, but in every newer version (6.0rc14-6.1) I've got a strange issue, does anyone else here suffer from that?
Few minutes after upgrade, everything is fine. Then, the items in Winbox (Interface list, BGP peer list or OSPF neigbour lists for example) start to take a few seconds to load. 2-3 Minutes later, Winbox loses it's connection. Logging in even per ssh or telnet is not possible anymore. The device still responds to pings, but after a few more minutes (also 2-3) it loses connectivity completely. Luckily, I've got a remote serial connection to it, because login on serial is still possible. A reboot command there takes about 5 Minutes until the router reboots itself. I've tried to generate a supout.rif when it got stuck, but even that didn't work.
It's running as a BGP RR with 4 IPv4 and 3 IPv6 peers (full feed), OSPFv2 and v3, MPLS PE (LDP, 4 VRFs, VPLS & L3VPN) and has 3 bonded interfaces (2xGE each) with about 5-6 VLANs per interface.
I'm happy with 6.0rc13 until now, so for me this is not a critical issue so far. But I'm interested if somebody else has observed this behaviour and if it's known at Mikrotik.
steen
Fri Jun 21, 2013 12:52 pm
Hello Folks!
I am bit comfused here regarding RoS versions.
Is RoS 6.X considered to be the stable production version series ?
We would never ever consider using and Release Candidates or betas in our production environment.
We have upgraded to RoS6.1 on some none important routers only and standard wifi internal networks, that ha been working without problems since start.
But I read here about IPSEC and instable wireless networks.
I have some questions:
1. Is the NV2 wireless network stable in RoS6.1 and RoS6.0 ?
2. Does IPSEC work between RoS <-> RoS devices, we need rock solid IPSEC links.
Currently we run RoS5.24 and RoS5.10 rock solid both in NV2 and IPSEC, is it safe for us to upgrade to RoS6.1 ?
We can not take any outages and breakdowns in our networks due to buggy RoS versions.
What do you say ?
d9nut
Fri Jun 21, 2013 1:28 pm
I've also been having issues with 6.1 on my RB450G - PPPoE hangs, also issues with random reboots.
Grepping syslog for June:
grep "router was rebooted without proper shutdown" */*
12/messages:Jun 12 19:04:21 fw1 system,error,critical router was rebooted without proper shutdown
13/messages:Jun 13 03:54:21 fw1 system,error,critical router was rebooted without proper shutdown by watchdog timer
14/messages:Jun 14 01:54:26 fw1 system,error,critical router was rebooted without proper shutdown by watchdog timer
14/messages:Jun 14 08:57:55 fw1 system,error,critical router was rebooted without proper shutdown
15/messages:Jun 15 04:51:31 fw1 system,error,critical router was rebooted without proper shutdown
15/messages:Jun 15 17:33:20 fw1 system,error,critical router was rebooted without proper shutdown
17/messages:Jun 17 07:04:57 fw1 system,error,critical router was rebooted without proper shutdown
17/messages:Jun 17 16:03:30 fw1 system,error,critical router was rebooted without proper shutdown
17/messages:Jun 17 18:39:15 fw1 system,error,critical router was rebooted without proper shutdown
18/messages:Jun 18 14:04:46 fw1 system,error,critical router was rebooted without proper shutdown
18/messages:Jun 18 17:25:23 fw1 system,error,critical router was rebooted without proper shutdown
18/messages:Jun 18 22:00:42 fw1 system,error,critical router was rebooted without proper shutdown
19/messages:Jun 19 12:59:19 fw1 system,error,critical router was rebooted without proper shutdown
21/messages:Jun 21 08:43:46 fw1 system,error,critical router was rebooted without proper shutdown
I've rolled back to 6.0 this morning and so far no issues.
spire2z
Long time Member
Long time Member
Fri Jun 21, 2013 1:52 pm
I'm using it and its fine.
From the looks of the forum there may be some small issue with Ipsec in 6.1 but looks like its very stable release overall.
infused
Fri Jun 21, 2013 2:05 pm
Thank you :)
infused
Fri Jun 21, 2013 2:07 pm
Out of all the releases for CCR, RC13 looks like the most stable.
honzam
Fri Jun 21, 2013 2:08 pm
With 6.1 is very often disconnect. It is used NV2. When client have 5.24 (5.25), then is uptime a lot of days. But after upgrade to 6.1 is uptime several minutes.
[Ticket#2013062166000392]
toxicfusion
Sat Jun 22, 2013 6:42 am
upgrade from 6.0 to 6.1 broke all IPSEC VPN connections on RB1100ahx2... downgrade back to 6.0 resolved issue. Thought 6.1 would fix IPSEC VPN issue of random VPN disconnects and inability to pass traffic to CISCO end points.
issue with link aggregation speeds 802.3ad as well - inconsistent balancing
hapi
RouterOS 6.1 released - btest fail
Sat Jun 22, 2013 1:32 pm
btest is setting only SEND. Watch torch.
omidkosari
Trainer
Trainer
Sat Jun 22, 2013 2:43 pm
Very bad performance of PPPoE server after upgrading to 6.1 form 5.25 .
in first day it works fine but after that the number of pppoe clients decreases .
lordzar
Sat Jun 22, 2013 5:25 pm
I took 2 CCR's and put them side by side with 6.1 installed. Ran a cable between 2 of the ports.. .and set up IPSEC.
EPIC FAIL !
Submitted a ticket and got back "We have a known IPSEC problem in 6.1"
Really?? At this stage in the game.??
I still can't put my CCR's in production on my Gig fiber link... too many issue from the very start.
Reborns
Sat Jun 22, 2013 7:05 pm
On RB750 the high DNS usage , about 90-100% , downgrading to 5.25 with the same IP address on WAN and the same config solves the problem .
Thanks.
Cha0s
Sun Jun 23, 2013 4:48 pm
Regarding IPSec, a temporary solution is to use v6.1 on both ends and put the peers on port 62465 with rsa key as authentication method instead of PSK. This is the only way it works for me.
If 6.1 is on one end and 5.25 on other, then the above workaround does not work. Still searching for a solution.
MikroTik any ETA on a fix for IPSec?
mihaimikrotik
Sun Jun 23, 2013 6:56 pm
I have 2 issues: CCR1016-12G keeps locking up every 2 weeks. X86 version still has packet loss of over 30% on ANY Intel interfaces. VRRP is unusable. Both routers are running v6.1
Just pointing out the fact that I have mentioned this in previous posts and there is no fix even after so much time. This issue is rendering the routers useless.
Regards,
Mihai
morf
Sun Jun 23, 2013 9:40 pm
Please give me a link to ROS 6.2 RC1. And also, the current list of changes.
jandafields
Sun Jun 23, 2013 9:48 pm
6.2 RC1 has not been released to the public yet, and there is no changelog at all for 6.2 yet. You should wait for 6.2 to be released and then they will have a changelog for it.
Cha0s
Sun Jun 23, 2013 10:00 pm
How can someone get access to the beta/RC builds for testing/feedback before they get released to the public?
neophyte
Mon Jun 24, 2013 12:08 am
No changelog and questionable stability...Why do you need it?
http://www.mikrotik.com/download/share/ ... 6.2rc1.zip
Cha0s
Mon Jun 24, 2013 12:17 am
I don't need it at the moment (unless it includes a fix for IPSec :) ). I was just curious if there is a process (register somewhere?) for users to try beta versions for feedback etc.
tomaskir
Trainer
Trainer
Mon Jun 24, 2013 1:23 am
Write to support and ask for access to beta releases.
aoakeley
Mon Jun 24, 2013 6:07 am
I can also confirm issues with 6.1 and IPSEC with PSK.
IT seemed to be chipset based. All routers on 6.1
MIPS-BE <-> MIPS-BE = YES
MIPS-BE <-> PowerPC = NO
MIPS-BE <-> x86 = NO
POWERPC <-> x86 = YES
POWERPC <-> POWERPC = unknown
X86 <-> x86 = unknown
Downgrading to 6.0 on all routers resolved the issue immediately
Andrew
scampbell
Trainer
Trainer
Mon Jun 24, 2013 12:54 pm
I am debugging a site with mutiple IPSEC tunnels on ROS 6.1 currently.
Enabling ipsec in system logging creates multiple entries but it is very difficult to identify which log entry belongs to which ipsec tunnel. Is there an easy way to filter the log so I see entries relating to just one endpoint please ?
Also, it seems it only negotiates SA's when the "secret" is identical for all tunnels. Changing one tunnel to a different secret breaks all tunnels (eventually) when their lifetime is up and they renegotiate.......
alex_rhys-hurn
Mon Jun 24, 2013 5:06 pm
The best way to manage logs in Mikrotik - and frankly just about anything - is to export them via Syslog to a Dude server. You can then filter/sort/export them to your hearts content.
Go one step further an deploy SIEM if you wish to do correlation etc... http://communities.alienvault.com/
I havent seen what you describe about secrets though. We are running about 70 Ipsec tunnels on 5.25 and beginning to test with 6.1.
Hmmm, reading above is a bit worrying about ipsec. Has anybody tried mikrotik -> Cisco Ipsec? v6.1?
Alex
Cha0s
Mon Jun 24, 2013 6:27 pm
I am trying to upgrade a Mikrotik installation (5.25) on a XENServer 6.1 Virtual Machine to Mikrotik v6.1.
Doing the automatic upgrade by downloading the upgrade package to mikrotik, leaves me with a kernel panic after reboot.
Also sometimes while rebooting prior to upgrade the package verification fails with an error about licensing which doesn't make sense since the installation has a proper license.
Trying to boot from the installation ISO just gets stuck forever right before the package selection screen.
From a search on the forums it looks like this issue has been going on since at least 6.0RC7
http://forum.mikrotik.com/viewtopic.php ... er#p353213
http://forum.mikrotik.com/viewtopic.php ... er#p355551
I also tried to create a supout.rif while on v 5.25 and it never completes.
Does MikroTik v6.x not support XENServer?
It works like a charm on VMware ESXi 5.1
Cha0s
Mon Jun 24, 2013 6:44 pm
I also just tried v6.2rc1 with the same results.
Here is a screenshot of the VM Console when kernel panic occurs.
leequince
Mon Jun 24, 2013 8:13 pm
Just started another thread on the XenServer Issue, I have been trying since 6.RC10 to get this working..
scampbell
Trainer
Trainer
Mon Jun 24, 2013 11:50 pm
Alex
Hi Alex,
Thanks for the syslog suggestion. I'll redirect these logs to The Dude and see if that helps.
IPSEC is troubling me on ROS6.x.
We have had several sites upgrade from working IPSEC VPN to ROS6.x and they have each experienced some disruption.
In one case we only had to change one tunnel's encryption algorithm to get it working to this latest site where we had to set every password the same **.
We suspect, but have not yet proven, that special characters may also be an issue if used in the secret. As it is a live site once we got it going we have had to leave it alone :-)
These tunnels are a mix of Mikrotik to Mikrotik and Mikrotik to 3rd Party routers.
** Now confirmed issue on two sites using RoS 6.1. Change password on one peer so that it is different to the others and it breaks all tunnels. Change it back and all tunnels are again connected within a few minutes.
** Also, disabling one peer in the group also caused tunnels to start dropping. Re-enabling the disabled peer corrected the issue.
This is like the peers are somehow inter-connected ?
telepro
Tue Jun 25, 2013 1:32 am
Thanks.
We are also seeing a substantial difference on how scripts are processed between 6.1 and 6.0. Mikrotik, could you comment on whether these changes were purposely done and scripts will need to be changed, or whether this is the result of an inadvertent side effect of some other change and will be fixed in (perhaps) 6.2. See for additional reports of the same issue:
See http://forum.mikrotik.com/viewtopic.php?f=1&t=73772 and
http://forum.mikrotik.com/viewtopic.php ... 3&start=74
http://forum.mikrotik.com/viewtopic.php ... 35#p374835
thanks in advance.
dineck
Tue Jun 25, 2013 9:01 am
For those who need version 6.0 use this magnet link:
magnet:?xt=urn:btih:DFD38099181BA8AE7DD29E7F72288C556C93EF35&dn=routeros-6.0&tr=http%3a%2f%2ftracker.mikrotik.com%2f
DirectX9
Tue Jun 25, 2013 12:18 pm
Hello MIKROTIK Support.
Try to ask one more time:
When can we change DTIM interval of 802.11 wireless interface network?
When can we change Beacon SSID interval of 802.11 wireless interface network?
When can we change time slot (short, long or both) on wireless interface?
dzieva
Wed Jun 26, 2013 12:59 am
Web-proxy disable and still using the cpu.
What is happening, v6.1 has many problems.
Ticket#2013062666000025
kevigizmo
Thu Jun 27, 2013 4:15 pm
one issue i have encountered is that if you are not "local" to the MikroTik trying to log into the box fails on everything, winbox, ssh, telnet even the webfig!
i upgraded a box to it (v6.1), then found i couldn't get to it any more, same thing happened to my box at home, dad couldn't log into it from the outside the network
any clues?
Kev
Nighthawke
Sat Jun 29, 2013 2:34 am
My RB750UP keeps blowing its little mind, randomly rebooting.
"System, error, Critical - router was rebooted without proper shutdown by watchdog timer"
It's operating in stock NAS mode, no modifications to system outside of shutting down all IP services, save for winbox, API-SSL and SSH.
I got half a mind to roll back to 5.x - what version is recommended to get a stable platform?
alexandrecorrea
Sat Jun 29, 2013 7:03 am
Memory Leak not solved !!
running 6.1 on CCR1016 .. after some pppoe connections... memory use are growing... then, routerboard reboot.. (i have sent it to support).
running 6.2rc1 .. same problem... HOLLY CRAP !!!!!!!!!
When one 'stable' version will be release ? one version that i can use all of my CCR ?s ??
shit softwware !!!!!!!! GRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRR !!!!
stmx38
Long time Member
Long time Member
Sat Jun 29, 2013 11:22 am
Lost my VPN with Cisco ASA 5510.
Downgrade to 5.25 - all is ok!
invalid length of payload
SoKaR
Sat Jun 29, 2013 12:57 pm
I can confirm the problem with IPSec and ROS v6. Now back to 5.25, all fine! Please fix this bug soon, want to use my CCR again ...
Nighthawke
Sat Jun 29, 2013 2:48 pm
There is more to this than just IPSec issues. The router, running 6.1, was very sluggish in response to commands, as if it was stuck in a loop, the terminal window taking upwards to 30 seconds to get to a command prompt in comparison to the normal 3-5 seconds.
Package rolled back to 5.25 immediately showed a clear difference in overall system performance. And this is nothing fancy running, just a stock RB on a cable connection with DHCP/NAT operating, and barely too, since I locked almost all my hardware in to the RB with static IP's.
6.1 is FUBAR, seriously.
scampbell
Trainer
Trainer
Sun Jun 30, 2013 1:03 am
Alex
Hi Alex,
We rolled the worst site back to RoS6.0 and it's IPSEC tunnels have been stable for 3-4 days now. I have not been game to try RoS 6.2RC1 as this is a live customer site......
emibel
Sun Jun 30, 2013 11:10 am
I haven't had this or any other problems running 6.1 in a dual-WAN configuration. I don't use IPSEC or VPN.
SoKaR
Mon Jul 01, 2013 11:42 am
Alex
Hi Alex,
Already tested, but same result. On 6.2RC1 we also have problems with IPSec. Such as "kernel panic" and reboot ....
wa4zlw
Mon Jul 01, 2013 7:59 pm
FWIW I have two connections at home. My 10m connection is for my VOIP and my 50m connection is for data. When I went to 6.x after awhile my VOIP router would have very high latency due to all sorts of connections being made. This only happens on the VOIP router. I've regressed back to 5.25 after a few days on 6.0 and it happened again there. My data router is currently on 6.0. I am running OSPF v2 amongst my network as well. I am also using VPNs which also endpoint on the VOIP router. So this is all related.
Thanks.
Leon D. Zetekoff, NCE, MTCE
BackWoods Wireless
jandafields
Mon Jul 01, 2013 10:19 pm
any clues?
Kev
You obviously have either a firewall rule blocking you, or an "Allowed Address" set on your username preventing your from logging in from a non-local address.
TheOtherNeo
Fri Jul 05, 2013 1:18 pm
I'm seeing the exact same problem trying to connect an IPSec connection from a recently upgraded AH1100 V6.1 to an AH1100 V5.24. Not an issue connection to antoher AH1200 with V6.0rc13.
On the V5.24 side I see errors such as "malformed cookie" and "invalid payload length".
I'm a bit weary of upgrading the V5.24 router as it is in our headoffice and always in use, and when upgrading the other two units to V6.0rc13 it didn't apply the IP settings to the correct ports or not at all and requiring me to do the configuraiton from scratch on both the other routers.
wa4zlw
Fri Jul 05, 2013 11:51 pm
another BUG on both 6.0 and 6.1
seems you can not change the serial port to anything BUT AUTO. Why is this? We can not make any connections with the serial ports.
Leon
alexandrecorrea
Sat Jul 06, 2013 12:01 am
welcome to bugOS world !!!
:oops: :evil:
DirectX9
Mon Jul 08, 2013 2:34 pm
Hello MT support.
Have a bug on CCR in connection with RB951G+RB751G
I have 2 EoIP tunnels in Each of up selected devices with each other. I think you know.
If i downloading/uploading data from 951 to 751 - the traffic goes trough CCR.
I think it must go direct EoIP tunnel from 951 to 751.
Please correct this in 6.2
autostoper76
Wed Jul 10, 2013 1:58 am
Nighthawke
Wed Jul 10, 2013 2:05 am
Do we dare after the ordeal 6.1 put us through??
normis
Wed Jul 10, 2013 10:16 am
I don't recommend downloading files from unknown sources. Those are not MikroTik domains.
neophyte
Wed Jul 10, 2013 10:30 am
When will be available for download 6.2?
normis
Wed Jul 10, 2013 10:43 am
When all known issues will be fixed.
mandrade
Wed Jul 10, 2013 1:51 pm
And while this.... we live on Bug World..... :( :( :(
BR
ropeba
Wed Jul 10, 2013 2:35 pm
issue with IGMP PROXY is "known issues"?
cheeze
Wed Jul 10, 2013 10:50 pm
It's pretty well understood that things are kinda rocky in transitioning to ROS 6. Can we all please submit as many tickets to Mikrotik so that successive versions can get better? It does us no good to just complain frivolously.
I think Mikrotik is trying to do what they do as best as they can. Lets give them as much ammunition as we can to fix all these problems and help them succeed.
nz_monkey
Wed Jul 10, 2013 11:45 pm
+1
Mikrotik are working really hard to resolve the reported issues.
danond
Thu Jul 11, 2013 5:27 pm
We saw the same errors connecting to a Sophos/Aastaro UTM and to a Sonicwall TZ170. Downgraded to 6.0 and the problem went away. Did not matter what Phase 1 settings were, it simply would not complete Phase 1.
Hard to believe this was missed.
x187
Fri Jul 12, 2013 10:29 am
CCR1036-12G-4S on v6.1
lost ping to CCR after winbox attempt. any help?
Reply from 192.168.10.252: bytes=32 time<1ms TTL=64
Request timed out.
Request timed out.
Request timed out.
Request timed out.
ropebih
Fri Jul 12, 2013 1:21 pm
+1
Two years for a reported bug that still has not been resolved is "working really hard"??
They're wasting time on nonsense and unnecessary things while serious bugs are still unresolved.
normis
Fri Jul 12, 2013 1:25 pm
Please tell me the ticket number of this issue, and I will check the progress.
ropebih
Fri Jul 12, 2013 2:33 pm
October 03, 2011 12:08 PM
Ticket#2011092966000591
nobody777
Fri Jul 12, 2013 7:44 pm
I upgraded from 5.21 to 6.1 (x86 Machine)
Server "stop networking" a few seconds after connect to L2TP Server (MikroTik) from Windows 7 client (no ipsec).
Under the "Stop networking" I mean = no ping to Mikrotik IP-Address from inside (real terminal) and from outside (over LAN).
For "start networking" again - helps reboot Machine 1-2 times
jandafields
Fri Jul 12, 2013 11:48 pm
Wow, that IS old! What is the issue in that ticket?
x187
Sat Jul 13, 2013 4:15 am
Request timed out.
Request timed out.
Request timed out.
Request timed out.
2yrs minus 2 days and counting...
ropeba
Sat Jul 13, 2013 12:25 pm
http://forum.mikrotik.com/viewtopic.php ... hilit=igmp
senzatempo
Sat Jul 13, 2013 6:02 pm
Hi All
in the 6.0 rc14 I have found that, exporting and importing backup on another hardware, backup also imports the mac address.
Once imported you can not change it in winbox and if change manualy in the .backup file don't effect.
I remeber this problem was present in versions 2.xx but solved in the next.
The problem has been fixed in 6.1? I have no way to test it at the moment.
thanks
Senzatempo
normis
Mon Jul 15, 2013 11:16 am
Hi All
thanks
Senzatempo
This is well known and documented. Backup is only for restoring on the same machine. Use Export/Import files to move config. This is not a bug.
vbnz
Tue Jul 16, 2013 11:56 am
Hello,MikroTik team!
It will be great,if you can fix problem with (3g/4g) ppp disconnection,and add ndis driver for popular 4g modems.
PPP disconnects after 1 minute or 40 minutes,and then try reconnects every second.
3G Network signal quality is from -74dbm to -83dbm.
I tested RoS version from 5.22 to 6.2rc1.
All versions have this problems.
My record was 1:40 minutes without disconnection.
(RoS 6.2rc1;RouterBoot 3.5)
Also I noticed that problem occurs frequently,if you didn't add NAT masquerade rule,or disable it.
This problem is very old.
Some forum themes about it:
http://forum.mikrotik.com/viewtopic.php?f=3&t=71031
http://forum.mikrotik.com/viewtopic.php?f=9&t=56463
Thanks.
senzatempo
Tue Jul 16, 2013 10:34 pm
ok backup is for the same hardware, but in previous versions (5,x) worked well on different hardware.
Please to want to consider how to implement inquiry, working with similar configurations on the same model of rb, it is very convenient to use it instead of having to use export / import
to be able to import a configuration with import takes several steps, with the backup function only 1 click.
THS all
Senzatempo
Nighthawke
Wed Jul 17, 2013 2:02 am
Kick a ticket open, start a paper trail, that's the only way you can spur them to even look into the issue.
Thanks.
ropeba
Wed Jul 17, 2013 5:44 pm
Hi Normis, did you check progres of ticket #2011092966000591?
ste
Thu Jul 18, 2013 11:04 am
Is there a change with ARP-Cache?
Seems it has a longer TTL now. Replaced a Router and the only BOX I needed to clear the arp-cache was a CCR with V6.
autostoper76
Thu Jul 18, 2013 11:06 am
Hello everyone,
when it expects the new version mt 6.2 ?
thanks
mtmx80
Thu Jul 18, 2013 4:24 pm
It's definitively time for ROS v6.2 except if this is holiday period there :)
normis
We don't have any holidays now. Work work work and fixing bugs :)
morf
Thu Jul 18, 2013 4:50 pm
You can tell which bugs are fixed in version 6.2?
normis
Thu Jul 18, 2013 4:53 pm
See changelog.
morf
Thu Jul 18, 2013 5:22 pm
See changelog.
Excuse me, but where to get a new list of changes. There is only 6.1.
Stillhard
Thu Jul 18, 2013 10:39 pm
here: http://forum.mikrotik.com/viewtopic.php ... 34#p377724
And you can get the v6.2 from here: http://www.mikrotik.com/download/share/ ... es_6.2.zip
morf
Thu Jul 18, 2013 11:14 pm
Thanks, Stillhard.
I have read the changelog.
Normis, please tell me, any planned improvements in the performance of CCR?
Alfabi
Fri Jul 19, 2013 1:49 pm
what about OSPF -nssa stability ? is that fixed?
mrz
Fri Jul 19, 2013 1:54 pm
One known nssa problem was fixed several versions ago, so please be more specific on problem description.
Alfabi
Fri Jul 19, 2013 3:23 pm
connected network on nssa (redistribute connected on) become unreachable, default route on nssa present, translator always on but dont know where is nssa connected network, reboot tranlator fix this bug... to next time
mrz
Fri Jul 19, 2013 3:48 pm
sounds like already fixed problem,
Basdno
Mon Jul 22, 2013 11:22 pm
THS all
Senzatempo
I wouldn't recommend using Backup to move config from one Routerboard to another, since it f.ex. brings along MAC adresses. This can under some circumstances give u some serious headaches. Also Backup doesnt bring along any Wireless settings.
Regards
jrecabeitia
Tue Jul 23, 2013 12:51 pm
CCR1016-12G with 3.04 firmware v.6.1 works
When updating the firmware to 3.09 does not work.
backup partition booted.
All Partition work on same firmware.
but on the other partition I have v6.rc11 and allowed me to download the firmware and boot from the root partition.
Now install v6.2 and firmware version 3.09
Now it works fine.
rpingar
Long time Member
Long time Member
Thu Jul 25, 2013 11:14 am
we are running 6.2 about JUL 08 and still experiencing random not active PPPoE interface.
attached there is a screen shot
NORMIS, when it will be fixed???
thanks
normis
Thu Jul 25, 2013 11:15 am
thanks
Did you contact support ? Let me know your ticket number, I will check status
rpingar
Long time Member
Long time Member
Thu Jul 25, 2013 11:20 am
It has been posted arounf for a while......
I am going to open a ticket.....
regards
Ros
thanks
rpingar
Long time Member
Long time Member
Thu Jul 25, 2013 11:30 am
[Ticket#2013072566000383]
regards
Ros
Chupaka
Thu Jul 25, 2013 3:59 pm
regards
Ros
what should Normis see in a fresh ticket? wait for an answer from support first ;)
gjp1000
Thu Jul 25, 2013 4:51 pm
Hi guys, my ethernet chip atheros AR8151 b not recognized with ros 6.1 ,any idea why this happen ?
normis
Thu Jul 25, 2013 4:52 pm
In which RouterOS version did it work? What device is this ?
gjp1000
Thu Jul 25, 2013 5:23 pm
this is the gigabyte ga-g41 m-combo onboard lan chipset .The motherboard is brand new and i use it for first time with ros 6.1
normis
Fri Jul 26, 2013 9:00 am
If it never worked before, there is nothing we can do. Apparently linux kernel doesn't support it yet.
indnti
Fri Jul 26, 2013 5:23 pm
[quote="MiKeDaDoC"]Hi Folks,
Problem was that only on IPSec Peer would establish correct SAs, randomly, that means it doesn't matter if it was the netgear or a RB2011xx. Analysing the problem showed that one had to deactivate all but one peer, this peer would come up perfectly. Then activate the next peer, wait until it would come up after nearly one minute. And so on.[/quote]
Same Problem here. Only one IPSEC connection can be established. :( It seems something is broken in 6.1 regarding IPSEC.
gjp1000
Fri Jul 26, 2013 8:58 pm
thank you
jandafields
Sat Jul 27, 2013 1:18 am
Hi Folks,
Yes, IPSEC is broken in 6.1. It should be fixed in 6.2, look back a few posts for the pre-release link to it.
mtmx80
Mon Jul 29, 2013 2:38 pm
It's still broken for me in unreleased ROS6.2. Very strange issue (2x RB2011), ping and small packets are passing fine, but larger packets are not reaching it's destination. I'm checking what can cause this and there is a support ticket open, but I had no much luck until now.
Cha0s
Mon Jul 29, 2013 4:44 pm
Yeap, on 6.2 pre-release IPSec is still broken.
I know that the proper way to report this is via supout.rif files but as these are on live running networks it's not easy to do so and frankly I don't want to *have* to break my networks everytime Mikrotik decides to change something that was otherwise working perfectly fine.
Mikrotik should do more tests before changing stuff that break important functionalities. It's not our job as end clients to do beta testing for them by providing supout.rif files each time they break something...
It's one thing to discover an unknown bug and another to find that the latest release has some functionality completely broken.
In the case of the latter it's obvious that whatever Mikrotik changed since the last known good release, that caused the problem. So why the hassle with the support.rif files and tickets?
Maybe they could form a beta testing community to allow to it access to night builds and have a larger set of installations to do tests before public releases. Some incentive for those people trying to help would be nice (some free routeros licenses maybe?)
This thing where on each release you don't know what will be broken needs to stop.
Mikrotik you cannot enter the high end market you are hoping for with CCR with this kind on inconsistency on your routeros releases. Think about it, what serious business will wanna use a software that unpredictable on each release?
Chupaka
Mon Jul 29, 2013 5:05 pm
write to support@, they can give you access to pre-release builds with (sometimes) changelogs via your MikroTik.com account
Ulypka
Wed Jul 31, 2013 9:06 am
And what about the [Ticket # 2013070166000356] ?
aoakeley
Sat Aug 10, 2013 6:12 am
Has anyone tested this in production using 6.2 final release? changelog says its fixed........
Sorry - should have checked the 6.2 thread http://forum.mikrotik.com/viewtopic.php?f=2&t=75392 some people still having issues
beamer
Sat Aug 17, 2013 5:35 pm
I second this. I was so stupid to upgrade a CCR router from beta "release candidate" to the "stable/release" version 6.2 and now it totally crashed after two weeks of uptime. It's a very very basic setup with 10 VLANs and a VPN (PPTP) access (and "no" traffic compared to what a CCR is supposed to handle!).
I have to downgrade to 6.0rc13 and maybe leave it there forever. :( :cry:
I cannot afford playing guinea pig for MikroTik since it's a production environment.
[EDIT] Seems CCR wasn't the core culprit in this case, but the DSL router hung.
But with all this reports of memory leaks etc. in ROS 6.x I certainly do not feel well (and the DSL box was stable for years).
5CardBaka
Thu Mar 13, 2014 8:49 pm
I tried a few times to use 6.7, then 6.1 but both have issues using MLPPP which I almost exclusively use the Mikrotiks for. Normally on 750GL's or 493AH's depending on the number of lines in the bond.
5.26 is listed on the Mikrotik site as stable and has no issues as far as I can tell. Will not touch 6.anything until its in the stable spot for ANY production environment.
Chupaka
Thu Mar 13, 2014 11:56 pm
does anybody know about those issues? have you written to support@?
Users browsing this forum: Bing [Bot], GoogleOther [Bot], JDF, Kanzler, kormenator, newbie54321 and 187 guests
