mistry7
www.mikrotik.com not avaible
Thu Jun 13, 2013 8:58 am
Hi Mikrotik,
du you use ROS 6.1 in your own Network?
normis
Re: www.mikrotik.com not avaible
Thu Jun 13, 2013 9:32 am
mikrotik.com is not hosted in our own network, but in the amazon cloud ;) as you see, their server has some issue.
normis
Thu Jun 13, 2013 10:17 am
Please check now. Site is up
honzam
Thu Jun 13, 2013 10:29 pm
The same problem now. From 20:20 to 21:20 is mikrotik.com DOWN.
Please make some mirrors :idea:
LAN, FTTx, Wireless. ISP operator
markom
Thu Jun 13, 2013 10:48 pm
Why Mikrotik host site outside Latvia or even outside EU? I have lot of web sites and servers and all is hosted in Serbia. What can be profit from outsourcing? 100-1000$ by month? From my point of view always is better to host in your own country on servers you give to some ISP data center for housing.
Ivoshiee
Fri Jun 14, 2013 6:50 am
Three reasons capacity, availability and security. These things tend to be better when you hand it out to a specialists to deal with. Sometimes they fail as well, but it is usually only sometimes.
normis
Fri Jun 14, 2013 8:40 am
Our country ISP could not manage to hold off DDoS.
honzam
Fri Jun 14, 2013 12:55 pm
Amazon cloud have yesterday problems. It would be good have some mirors
normis
Fri Jun 14, 2013 1:03 pm
no, problem was on our side.
Users browsing this forum: MSN [Bot] and 30 guests
