wildbill442
RFC 3021 and ROS
Thu Mar 16, 2006 3:33 am
Does RouterOS support RFC3021 for point to point links? (31bit masks)
eflanery
Thu Mar 16, 2006 9:04 pm
I don't know, never tried it. But, MT does support an even more efficient method.
You can just use /32s, the addresses don't have to be adjacent, and they can be reused on multiple interfaces.
i.e.:
router1
/ip address add address=1.1.1.1/32 network=2.2.2.2 interface=to-router2
/ip address add address=1.1.1.1/32 network=3.3.3.3 interface=to-router3
router2
/ip address add address=2.2.2.2/32 network=1.1.1.1 interface=to-router1
/ip address add address=2.2.2.2/32 network=3.3.3.3 interface=to-router3
router3
/ip address add address=3.3.3.3/32 network=1.1.1.1 interface=to-router1
/ip address add address=3.3.3.3/32 network=2.2.2.2 interface=to-router2
3 point-to-points, using only 3 addresses; /31s would require 6, and they would need to be in pairs.
With more links, it becomes drastically more efficient.
--Eric
mag
Fri Mar 17, 2006 9:32 am
good! i always missed some kind of "unnumbered" connection.
this should be a perfect replacement.
(it's not mentioned in the manual particularly, is it?;-)
Eugene
Forum Veteran
Forum Veteran
Fri Mar 17, 2006 5:00 pm
And you can use OSPF on these links to. Just don't forget to specify the interface as being point-to-point.
Tout individu a droit à la vie, à la liberté et à la sûreté de sa personne.
eflanery
Fri Mar 17, 2006 9:12 pm
Or, on older (2.8) systems where that isn't an option, encapsulate it in a PPP link of some sort (l2tp, etc...), works like a charm (usually).
--Eric
wildbill442
Sat Mar 18, 2006 2:54 am
I didn't think of that, and I do plan on implementing OSPF. Thanks..
Users browsing this forum: sashoatanasow and 96 guests
