molesza
Vlan by MAC Address?
Thu Jun 20, 2013 12:25 pm
Is it possible to assign specific mac addresses to a certain vlan?
Basically I want all new clients who do not have a specified mac address to default to one vlan. Then I want to set up rules where if the mac address is known it is assigned to a different Vlan. It is not possible to do this with different ports on the board because we have a mixture of pc's which will need to go to either vlan in different buildings.
Hope it can be done!
tomaskir
Trainer
Trainer
Re: Vlan by MAC Address?
Thu Jun 20, 2013 1:36 pm
Use MAC-based vlans on your switch to do this...
Unimus - configuration management, automation and backup solution
Mass Config Push, network-wide RouterOS upgrades, and more!
molesza
Thu Jun 20, 2013 4:55 pm
Thanks. Can this be done on the RB751G and where do I find the info?
tomaskir
Trainer
Trainer
Thu Jun 20, 2013 5:09 pm
Yes, see this wiki article on how switch chip works with vlans. (user ROS v6)
http://wiki.mikrotik.com/wiki/Manual:Sw ... outerOS_v6
After you have the VLANs setup and working, use the rule table to add desired MACs to desired VLANs.
/interface ethernet switch rule add switch=$switchName src-mac-address=$mac new-vlan-id=$vlanID
molesza
Tue Jun 25, 2013 1:27 pm
Thanks! Will read up and see how I go.
Users browsing this forum: No registered users and 68 guests
