gimmepatiencequickly
Fortigate SSL-VPN connection
Tue Jun 25, 2013 11:34 am
I need to connect to a remote network where a fortigate device is installed.
I would like to use my mikrotik router to connect to the fortigate device using an ssl-vpn connection.
I am not the administrator of the fortigate device, so I will need to get the assistance of the administrator on the remote side to assist
What would I use with the mikrotik router?
What settings would I need to get from the fortigate device to correspond to the mikrotik settings
I tried using SSTP, but I get an error... "terminating... - broken http connection"
0 X  name="SSTP Connection" max-mtu=1500 max-mru=1500 mrru=disabled connect-to=x.x.x.x:10443
      http-proxy=0.0.0.0:443 certificate=none verify-server-certificate=no
      verify-server-address-from-certificate=yes user="y" password="z" profile=default-encryption
      keepalive-timeout=60 add-default-route=no dial-on-demand=no authentication=pap,chap,mschap1,mschap2
Any assistance will be much appreciated
Defer not till tomorrow to be wise, tomorrow's sun to thee may never
rise.
--- William Congreve
Boardsurfer
Re: Fortigate SSL-VPN connection
Wed Jun 26, 2013 7:05 pm
I'm not sure if that's possible. As far as I know, the SSL VPN service on FortiGate devices is pretty much SSTP, but it's a proprietary version that is only compatible with FortiNet's official client software and browser plugin. At least I've never seen support for third-party clients mentioned anywhere in the documentation for FortiGate firewalls. My experience with FortiNet products is not that extensive, though, so I might be wrong.
We use a FortiGate firewall with SSL VPN at work, so I can do a little bit of testing and will let you know if I figure out a way to make it work.
Boardsurfer
Mon Jul 22, 2013 9:28 pm
Any updates on this? I haven't made any progress on the SSL VPN bit, but I can confirm that IPSec between a FortiGate and a RouterBoard works just fine. I have successfully set up a gateway-to-gateway IPSec VPN connection between our FortiGate at work and my RouterBoard at home. Let me know if you'd like to try that option, and I'll provide detailed instructions on setting it up.
viviirawati
Thu Sep 26, 2013 8:16 am
may i have the configuration please.
viviirawati
Thu Sep 26, 2013 3:35 pm
may i know the detail instruction for configuration of gateway-to-gateway IPSec VPN between fortigate and RB, thanks in advanced
Mon Oct 14, 2013 3:38 pm
Thanks for the info Boardsurfer.
Unfortunately I do not have administrative access to the fortinet server. I have spoken to our client to assist with the setup of the VPN connection.
I would appreciate if you would provide instructions on how to set this up
I was thinking of something like this, but I need the fortinet configuration...
http://wiki.mikrotik.com/wiki/MikroTik_ ... wall_IPSEC
Thank you
rise.
letabawireless
Thu Aug 04, 2016 10:20 am
Hi
Having the same scenario here - any updates ?
carlosfrosario
Fri Jul 21, 2017 3:05 am
Same issue here, anybody has a solution?
Troz
Thu May 24, 2018 6:53 pm
BUMP
ALSO need this info please any updates ?
anav
Thu May 24, 2018 7:03 pm
Sounds like the need for a WIKI for an IPSEC connection between a mikrotik and a fortinet device.
Extrapolate away......................
https://www.draytek.com/.upload/pdffile ... d65847.pdf
https://blog.webernetz.net/ipsec-site-t ... co-router/
https://cloud.google.com/files/CloudVPN ... te300C.pdf
From the NET
QUOTE: " I have set up Fortigate VPNs with Cisco, Watchguard and Sonicwalls in the past without issue. As long as all the settings for Phase 1 and Phase 2 match it should work regardless of vendor." UNQUOTE
I'd rather manage rats than software. Follow my advice at your own risk! (Sob & mkx forced me to write that!)
evince
Fri May 25, 2018 12:51 pm
VPN IPSec between Fortigate and Mikrotik is quite easy. The only need is to match both phase1 and phase2. In fortigate side, you can choose interface mode instead of policy based vpn if you prefer
Users browsing this forum: Majestic-12 [Bot] and 42 guests
