normis
SNMP
Mon Mar 20, 2006 11:28 am
We are working on a completely new SNMP for RouterOS and we are going to also support SNMP write. Could you please write what you wish to see in RouterOS SNMP support, and what network management programs you now use that have SNMP write support.
ice
Mon Mar 20, 2006 12:53 pm
Cool!
SNMP TRAP and GET features are required.
Denis Basta
We're using self-written SNMP client script + iReasoning MIB Browser 3.0.1...
Would be great to have read/write access to:
  • interfaces
    ip addresses
    routes
    queues
    system settings
mag
Mon Mar 20, 2006 6:48 pm
Very good! Looking forward to it.
Now we're using Ipswitch WhatsUp (fading out), InterMapper (my favorite:), Nagios (testing) and a few minor tools.
SNMP-related things springing to mind are:
Traps
Configuration access e.g. interfaces, firewall rules, activating scripts,...
(one more thing, not sure if its possible at all: custom variables by scripting, reachable through SNMP, e.g. for creating own counters or thresholds.)
driton
Mon Mar 20, 2006 6:55 pm
1. Bandwidth description is very helpful, e.g. if you have a 100mbps interface but it is giving only 512kbps why should the interface appear as 100mb when you config the MRTG graph or similar (even if you can do it manually).
2. Interface flaps (down/up) should be available via snmp.
jarosoup
Long time Member
Long time Member
Mon Mar 20, 2006 10:10 pm
Here are a few requests:
- More SNMP support for WDS interfaces. Currently, they support ethernet-like interfaces, but it would be nice to join or index based on the registration table so that there are wireless OIDs available along with the standard ethernet statistics. Please let me know if you need more info about this. We currently do this manually by looking up the OIDs.
- OID support for firewall connection counts. We currently do this with scripting, but after so many networks with this running, the script can "miss". What we need is the value for "/ip firewall connection tracking print count-only".
- OID support for DHCP lease count. Similar to above, we run a script that returns "/ip dhcp-server lease print count-only" to obtain lease counts. It'd be handy to poll this with SNMP.
- Apparently there is now support via SNMP for hotspot active user counts. I haven't upgraded to a version that supports this, but please retain it as this is a great one to have.
- In general, anything that supports "print count-only" would be a helpful addition.
Glad to hear you guys are working to improve SNMP support. Keep up the good work!
eflanery
Mon Mar 20, 2006 10:26 pm
I would say that it would not just be nice to have everything that has a "print count-only" option, but everything that has a "print" command of any sort.
In fact, I would like to see SNMP become as full-featured as the command line. It should be quite possable, even if some parts get a bit confusing.
Also, adding something like "send SNMP-trap" as a logging action would be pretty cool.
I don't think SNMP is really all that great a management protocol, but it could certainly do the job, and would be better than the hack-job scripts I use now. (In my ideal world, each MT would make it's entire self available as a full featured CORBA object, but that is probably asking way, way too much.)
--Eric
cmit
Mon Mar 20, 2006 10:38 pm
Hah! Don't expect the standard router user to even know what CORBA is?! :D
Sounds like you are way to software-addicted for a router admin... ;)
Best regards,
Christian Meis
eflanery
Mon Mar 20, 2006 11:10 pm
Yeah, I've worn a few too many hats in my time. Once upon a time, I even wrote shim code to tie ancient USDA Fortran code in with modern DoD CORBA systems, how wrong is that? :twisted:
No, I wouldn't expect the "standard router user" to know about CORBA, but MT isn't exactly a "standard router", nor are it's adherants "standard users". :)
It's not unheard of to use CORBA systems for network management, though. Actually it's a rather nice fit, being super abstract as it is. While "vendor C" doesn't really do that sort of thing, if you look a bit higher at the likes of Nortel, Lucent, Hauwei, or others in that class, you will find plenty of IDL files available.
I did say it was asking a bit too much, though. Didn't I? :wink:
--Eric
kapusta_kiszona
Mon Mar 20, 2006 11:46 pm
Cacti support and feature using scripts on linux/bsd machine for managing MikroTik via SNMP.
jp
Long time Member
Long time Member
Tue Mar 21, 2006 4:58 am
My SNMP wishes...
read access:
* MT version. There is no excuse for not having that now. I have a database to keep track of my MTs, and use SNMP to keep some of the fields updated. We do this with lots of other hardware. I don't have a way to easily determine the version in the MT.
* arp table (real handy in the ISP world since customer computers and firewalls are rarely pingable now)
* dhcp leases
* as many wireless measurements as possible. See what alvarion and other snmp-ready wireless equipment vendors provide by looking at their MIBs.
* mac address of associated/registered radios would be good for my homemade monitoring systems to automatically figure out what is associated to what.
* perhaps temperature/voltage measurements when hardware makes it possible.
* UPS status via SNMP if a Smart-UPS is attached.
Write access:
* ip configuration
* reboot
* factory reset
* bandwidth test server and client functionality. I could have a nasty bash script cronjob on my linux monitoring systems that automatically setup and take down the bandwdith server to run a test between any two systems at various times.
* sniffer streaming start/stop capture and interface selection. To automate traffic capture to my machine running trafr. A tech could enter one command on my system which would start trafr, connect to a MT, stream sniffed data for 30 seconds, stop the stream, stop trafr, and open the data up in ethereal or another program, or perhaps just archive it if I am looking to get samplings over time if the interesting traffic is intermittent.
either a default input rule to block SNMP access not from a particular IP , would be a good default security configuration as well. The user would just set the IP that is allowed and enable the rule, after setting a write community string.
For SNMP software, we use net-snmp (mostly in bash scripts to get snmp data into a text file or mysql), and MRTG on linux.
normis
Tue Mar 21, 2006 8:58 am
normis
Tue Mar 21, 2006 10:08 am
actually we are also preparing an open API for configuration of the router, so you can develop your own applications that connect to the router and configure/control it. this is not connected to SNMP but i guess you will also like that
sten
Forum Veteran
Forum Veteran
Re: SNMP
Tue Mar 21, 2006 10:53 am
An oid to reboot, but not oids for reset or shutdown as they would be unnecessary and potentially harmful.
Oid's to execute scripts. E.g. write 0 => 1 (equals reboot)
Oid's to save config to specified name. E.g. "" => "myconfig" (equals saving config as myconfig.backup)
Oid's to restort config from specified name. E.g. "" => "myconfig" (equals loading myconfig.backup)
Oid's for (for example) 5-10 static oids which one may put strings and which scripts could read.
Error counters for all interfaces.
Move along. Nothing to see here.
bjohns
Tue Mar 21, 2006 2:48 pm
Love the idea of an API - I can only imagine the amount of flexibility it would provide, especially with the more dynamic functions such as hotspot/ppp connections etc.
GotNet
Tue Mar 21, 2006 5:14 pm
Answer to a prayer! Holy crap, I just did a cartwheel!
andreacoppini
Trainer
Trainer
Tue Mar 21, 2006 5:21 pm
Now where did I put that little thermal printer I had??? :)
- No strings attached -
<< Please give good Karma if this post helped you. Press the + button above the Location entry
csickles
Tue Mar 21, 2006 7:38 pm
Hot "DARN !!"....
:D
Things that make you go "Hmmmmmmmm"...
Craig
eflanery
Tue Mar 21, 2006 8:47 pm
Sweet!
Thank you, thank you, thank you!!!!!!
--Eric
incoming429
MT version
Wed Mar 22, 2006 3:18 am
My SNMP wishes...
read access:
i use this oid to get the fw version (2.9 only): .1.3.6.1.4.1.14988.1.1.4.4.0
the docs are incomplete about the oids
just do a snmpwalk and you get quite an interesting list
regards,
michal
jp
Long time Member
Long time Member
Re: MT version
Wed Mar 22, 2006 4:04 am
regards,
michal
NICE! Thanks a bunch for that oid!
jp
Long time Member
Long time Member
Wed Mar 22, 2006 6:45 pm
while I'm on the topic, how can the "upgradable-till" oid be converted from hex to text. I am basically looking for a human readable text date with year/month/day or similar.
[admin@bht] > /system license print
       software-id: "xxxxxxx"
  upgradable-until: sep/01/2006
            nlevel: 3
          features:
[admin@bht] > /system license print oid
       software-id: .1.3.6.1.4.1.14988.1.1.4.1.0
  upgradable-until: .1.3.6.1.4.1.14988.1.1.4.2.0
             level: .1.3.6.1.4.1.14988.1.1.4.3.0
mocha:/usr/local/mis/bin # snmpwalk -v1 -c public 10.0.1.5 .1.3.6.1.4.1.14988.1.1.4.2.0
SNMPv2-SMI::enterprises.14988.1.1.4.2.0 = Hex-STRING: 07 D6 09 01 00 00 00 00
incoming429
Wed Mar 22, 2006 9:01 pm
            nlevel: 3
          features:
the first two hexs concatenated are the year, the 3rd is the month and the
4th is the day
Converted to dec it looks like this:
perl -e 'printf "%d. %d. %d\n", 0x01, 0x09, 0x07d6'
1. 9. 2006
So your copy is upgradable until 1st september 2006
Best regards,
Michal
jp
Long time Member
Long time Member
Wed Mar 22, 2006 10:51 pm
Now, I can have my database automatically update the version and hostname of my Mikrotiks! I run this script with cron each day. I use the database both as a glorified inventory spreadsheet, and to feed other scripts such as one that makes mrtg config files.
# more db.update.mt
#!/bin/bash
MYCMD="mysql -B -N -h 127.0.0.1 -u xxxxxxxx -s -pxxxxxx -e "
for IP in `$MYCMD " use mt; select ip from router;"` ; do
  VER=`snmpget -r2 -v1 -c public -Ovq $IP .1.3.6.1.4.1.14988.1.1.4.4.0 |cut -d" " -f1|sed -e "s/\"//g"`
  NAME=`snmpget -r2 -v1 -c public -Ovq $IP SNMPv2-MIB::sysName.0 |cut -d: -f4`
  $MYCMD "use mt; update router set version='$VER' where IP='$IP'"
  $MYCMD "use mt; update router set hostname='$NAME' where ip='$IP'"
done
For some reason, I can't get bash to print the month properly. I could use the perl example, but I'm almost there and don't want to need two scripting languages to convert a hex date to decimal.
mocha:/usr/local/mis/bin # cat getle
#!/bin/bash
HEXDATE=`snmpget -r2 -v1 -c public -Ovq $1 .1.3.6.1.4.1.14988.1.1.4.2.0`
CDHEXDATE=`echo 0x$HEXDATE |sed -e "s/\"//g" |sed -e "s/ //g"`
echo $HEXDATE
echo 0123456789
echo $CDHEXDATE
YEAR=`echo $CDHEXDATE|cut -b0-6`
echo YEAR
printf "%d\n" $YEAR
MONTH=`echo $CDHEXDATE|cut -b7-8`
echo MONTH
printf "%d\n" $MONTH
DAY=`echo $CDHEXDATE|cut -b9-10`
echo DAY
printf "%d\n" $DAY
mocha:/usr/local/mis/bin # ./getle 10.0.1.5
"07 D6 09 01 00 00 00 00 "
0123456789
0x07D6090100000000
YEAR
2006
MONTH
./getle: line 14: printf: 09: invalid number
0
DAY
1
incoming429
Thu Mar 23, 2006 12:42 am
# more db.update.mt
#!/bin/bash
done
#!/bin/bash
echo $HEXDATE
echo 0123456789
echo $CDHEXDATE
echo YEAR
printf "%d\n" $YEAR
echo MONTH
echo DAY
printf "%d\n" $DAY
0123456789
0x07D6090100000000
YEAR
2006
MONTH
0
DAY
1
maybe something like this?
#!/bin/sh
OUT=`snmpget -r2 -v1 -c public -Ovq $1 .1.3.6.1.4.1.14988.1.1.4.2.0 |sed 's!\"!!g'`
YEAR=`echo $OUT |awk '{printf "%d", strtonum("0x" $1 $2)}'`
MONTH=`echo $OUT |awk '{printf "%d", strtonum("0x" $3)}'`
DAY=`echo $OUT |awk '{printf "%d", strtonum("0x" $4)}'`
Cheers 8)
Michal
conchalnet
Tue Apr 04, 2006 12:06 am
The amount of registration on the AP is good to have throught SNMP.
Fixed MIBs for clients that are registred is good too, because I want to do MRTG graphics of the signal level of the clients registred in the AP.
Fabrício
prcek
Netwatch -> SNMP
Mon Apr 17, 2006 5:43 pm
Netwatch (tools->netwatch) status of every host will be very helpful. Just up/down flag, nothing more.
prcek
BGP peers -> SNMP
Mon Apr 17, 2006 8:27 pm
Welldone, BGP in >2.9.20 looks great. SNMP status of every peer would be fine (Instance, Remote Address, Remote AS, Remote ID, Uptime, Prefix count and State).
GJS
Tue May 09, 2006 4:04 pm
Just to echo, I would like to have connected UPS stats.
The open API sounds fantastic. Any more info on this?
Guy
wispuk.org
A Forum Community for UK WISPs
normis
Thu May 11, 2006 9:35 am
Can you be more specific on you SNMP requests? What traps would you like to see? What is THE SNMP feature that you miss the most now?
prcek
Thu May 11, 2006 11:44 am
1. Netwatch (tools->netwatch). It should´t be a trap, but simple OIDs for every Netwatch Host and his Status and Since.
2. BGP - status of every peer (Instance, Remote Address, Remote AS, Remote ID, Uptime, Prefix count and State) will be very helpful.
xxiii
SNMP Community in multiple subnets
Wed May 31, 2006 1:06 am
We need to be able to use the same community string in different/multiple subnets.
amtisrac
Fri Jun 02, 2006 11:40 am
On wireless which frequency is currently used (by station mode)
It's very helpful with dude!
Ozelo
Mon Jun 12, 2006 11:12 pm
- OID for per wireless interface RSSI without an MAC address together with the OID number, perhaps the interface index;
- OID for per interface total wireless associations.
MTCRE - 1104RE006
MTCINE - 1104INE001
BrianHiggins
Long time Member
Long time Member
Sun Jun 25, 2006 8:46 pm
- static oid's for client signal strengths (without adding mac to access list)
- ability to upload/execute commands (i.e. run / user set admin password=12345 on 40 systems at once)
- UPS status details (online, battery charge state, voltage, load etc)
Vadim
Tue Jun 27, 2006 1:56 pm
COOL! :) This is a really cool thing I need in RouterOS!
In SNMP I'd like to see traps about extreme CPU and system temperature, extreme CPU load, failure of all the fans, that can be detected by system, change in state of serial or parallel port lines (to use it for any custom sensors like detection of opening of the box, where the router stands).
tlkhorses
Tue Jun 27, 2006 3:56 pm
add or delete user and change their permissions.
We have tech support that come and go. They take a look from the tower at the client which is very helpful. Big pain to go do this to every access point we have manually.
Terri Kelley
Farm to Market LP
Broadband Wireless
eflanery
Tue Jun 27, 2006 8:08 pm
You can use a radius server for administrator authentication, quite easily. Linking device administration access to an employee database can automate the whole process, without the need to alter individual device configs (via SNMP, or otherwise).
--Eric
BrianHiggins
Long time Member
Long time Member
Mon Jul 17, 2006 5:09 pm
it seems that Sergejs either A.) didn't actually read the content of my email before writing back to me, or B.) he wants me to post it here... either way, here it is...
now can we get accurate interface speeds to be reported by SNMP? I hate having 10-15mb link speeds on routers that are reported as 100mbps because it's a ethernet uplink, and 11mbps link speeds reported for 802.11a nstream links that are actually pushing 20mbps...
Re: [Ticket#2006071416000037] SNMP interface speed
Hello Brian,
To view available OIDs,
you can type e.g. 'queue simple print oid'.
Follow this topic about SNMP,
http://forum.mikrotik.com//viewtopic.php?t=7453
Regards,
Sergejs
"Brian Higgins" wrote:
> is there any way to set the interface speed that is reported via SNMP?
> our monitoring system reads the reported speed and bases it's graphing
> off of what it reads. we have a vlan that is pushing about 8mpbs (SNMP
> says the interface speed is 10mbps), and we get constant alerts about
> the utilization because it's over 80% of the reported speed. we also
> have similar issues with our APs because they are reported as 11mbps,
> but they are 802.11a radios running at 24mbps.
> if this is not yet possible, can you please add this ability into 2.10
> (or sooner??)
> For Ethernet interfaces that are hooked into other connections such as
> a DSL modem this would be nice as well so we can specify that the
> interface speed is actually 3.0mbps even though it is a 100mbps
> Ethernet port.
dritoni
Mon Jul 17, 2006 7:20 pm
I have asked it many times that speed and description (comment) values be avaliable via snmp.
BrianHiggins
Long time Member
Long time Member
Tue Jul 18, 2006 5:04 am
the speed already is available... the problem is that it doesn't always show anything even close to accurate... all 802.11 links, even if it's a 5.8Ghz NStream Dual show as 11mbps
dritoni
Tue Jul 18, 2006 8:46 am
I was thinking about speed decription.
BrianHiggins
Long time Member
Long time Member
Tue Jul 18, 2006 2:33 pm
Sergejs's response to this issue, and then my response to him (at the top)
I would like to simply set the interface speed in my monitoring application, but that is not an option, it's not an option in many monitoring applications. I am also emailing the vendor of my monitoring system(IPSwitch What Up Professional 2006) for the ability to change it in there.
I am asking you to change it as well, as ROS is reporting things incorrectly (see my comments about my wireless links) so when you go to fix that, I would just like to see the following option added to any available interface ex. snmpinterfacespeed=######## then when any SNMP probe reads the standard 1.3.6.1.2.1.2.2.1.5.# OID, it reports the value specified by snmpinterfacespeed. Then when I probe my wlan interfaces, they do not show up as 11mbps, regardless of what radio and config I have, or when I have a interface connected to a wireless bridge (like an orthogon link) I can change the interface speed to reflect the speed of the link in the middle, not the speed of the ethernet port that it's connecting to...
Brian
-----Original Message-----
From: MikroTik Support [Sergejs] [mailto:support@mikrotik.com]
Sent: Tuesday, July 18, 2006 7:47 AM
To: Brian Higgins
Subject: Re: [Ticket#2006071416000037] SNMP interface speed
Hello Brian,
Probably you can set appropriate configuration in external monitoring server, that will show desired values, e.g. traffic below 8 Mbps.
It's possible to set name to each monitored value (interface, queue simple, queue tree etc.), where you can set 'VLAN1 8mbps limit', that will indicate it's VLAN1 interface with '8 mbps' limit.
Regards,
Sergejs
ParisDragon
Wed Jul 19, 2006 7:27 pm
Right now the only SNMP I find missing in 2.9.27 is I cant pull the signal strengths and trasmits speeds from an Nstreme Dual Link. I have written a procedure to log the levels into a file, but then I must download it, convert it to the proper format, import it etc., big pain when all my half duplex single radio links/clients signals are readily availiable via SNMP.
It would also be nice if you could have ONLY a certain set of items return for the public community. For example I put all this nice info good for me in and public could read too much info. I would like Public to only be able to pull name, system name, contact and nothing else, so if they see my radio and SNMP poll it they know how to reach me if interference is occuring.
interlink
RF OID
Fri Jul 21, 2006 1:52 pm
It would be nice to have OID´s for noise floor, Signal to noise and Tx/Rx CCQ.
bolton
macro and micro
Tue Sep 26, 2006 1:21 am
I'm new to this forum. But I'm probably gonna be lurkin quite a bit.
I'm new to microtik too. I'm here, of course, 'cause it seems likely to be a solution to my problems.
It's been a long, long time since I last had to mess with subnet masks, and IOS syntax. So in some areas, I'm starting over.
I'm not new to Networks, Systems, or the care and feeding thereof.
This includes Large Enterprise, Network Management systems, Operations Systems,
I'd like to suggest that we break this thread into at least 2 parts.
the First being EMS/NMS/OSS architecture and design as it applies to RouterOS, Dude, and foreign NMS compatibility.
Others could be operational details such as agents, Active OIDs, Traps and trap contents, etc.
On a Macro Level, I'd like to suggest that;
Just about any Security issue that's gonna get fixed, will be first approached with rigorous SNMP V3 compliance. Any, and every other hole will have to be dealt with at other layers. A decent Key Manager would be heaven at this point.
When mentioning things like CORBA, or any other ORB or Message Bus,
If you needed Middleware, You'd be running WebSphere already.
IBM will give it to you if you ask nice.
SNMP exists, because IP exists. If you're not aware of the difference between TCP and UDP, or the effects of Connection Overhead, then your not gonna understand why XML (or any other) based messaging for management automation is tough to do.
As Hairy, Hoary, and Old fashioned as ANS is, it works well if done well.
If your desperate enough, You might want to take a look at CA's press on the latest Unicenter.
The most lightweight ORB you're gonna find, is not gonna fit on a Routerbox anytime soon. various gateways abound that'll repackage
SNMP as messages. But, I'd not ask Microtik to spend manhours on them.
There's some nice PeertoPeer stuff around that looks like it may overlay meshes quite nicely. When We see multiprocessor Routerboards and Multigigabyte Flash that runs at multiples of bus speed, the software may be ready.
If, in our Lifetime, We see solid SNMP v3 with active OIDs for the majority of volatile variables and tables, We'll be way ahead of the game.
We can get a decent picture of how to prioritize OID development and release by concentrating First, on the ones that help avoid Truck Rolls.
RouterOS exists to keep us off towers in the dark and cold. It may be worthwhile to keep that in mind.
In the meantime, All your scripts and code snippets, If shared out and tested, will fill in the gaps while the Microtik team concentrates on the good stuff.
It's nice to hear that you have a solution for your problem. It'd be even nicer to hear that you have a solution for mine.
ParisDragon
SNMP OID
Tue Sep 26, 2006 9:02 pm
I am grateful that the mac address is used to pinpoint the OID of a remote radio, what I dont understand is why the UID for signal strength ends with different numbers, sometimes its always .4, update the OS and it might become .1835 on one box but remain .4 on another, which breaks monitoring scripts I use on MRTG externally. For example:
I was pulling the signal Strength on a backhaul using the OID:
1.3.6.1.4.1.14988.1.1.1.2.1.3.0.96.179.92.190.20.4
it remained this OID from v 2.9.27 (when I first did it) until I went to 2.9.30 the OID changed to 1.3.6.1.4.1.14988.1.1.1.2.1.3.0.96.179.92.190.20.1835 for the same registrered client.
So I thought, ok they switch the ending OID entry for signal strength from .4 to .1835. So I checked other backhauls I upgraded, some remained .4, others changed to .1835 and some to .3 on the end when upgrading. If this isnt by design please look into fixing it, if this is by design then please consider making signal strength OIDs remain the same on a box unless of course the remote radio MAC changes so as to keep remote SNMP monitoring and graphing from halting or falsely reporting issues. Thanks
meister
Mon Oct 16, 2006 4:38 am
I wouldn't mind an OID for # of ppp users connected.
BrianHiggins
Long time Member
Long time Member
Mon Oct 16, 2006 6:21 am
I'll 2nd that request (usefull for seeing if you have connection issues causing users to drop off durring storms or something, as well as tracking IP allocations)
I think I asked for this once before... would be very nice to track for historical trending...
[ASM]
Sat Nov 25, 2006 12:53 pm
I've writen that many times:
get full info from wireless registration table
I need at least: tx-signal-strenght,interface,SNR
The light is faster than sound. People always looks smart before they start talking.
grzesjan
Re: SNMP
Mon Nov 27, 2006 12:38 am
For me, at first read access to some numbers:
- number of dhcp leases (how many all, radius, pool and so on)
- number of hotspot entries (how many authenticated, how many not),
- number of entries in routing table (how many ospf, bgp, static)
And write access I would need mostly for ip address-lists. I use address lists for several things and sometimes there is a need to update the lists on all routers. SNMP write access could help us a lot.
Regards,
Gregor
Gregor
gideono
Wed Dec 13, 2006 12:22 pm
Can we have write access to the interface byte counters?
janog
Mon Jan 15, 2007 1:53 pm
I would like to have read access to /ip neighbour print
stephenpatrick
Forum Veteran
Forum Veteran
Fri Jan 19, 2007 3:11 pm
Is there going to be support for SNMPV3 ?
[asked for by some major potential customers]
Regards
CableFree Solutions
CableFree - Wireless Excellence - Microwave, E-band Radios, Free Space Optics, High performance Radios & Routers
http://www.cablefree.net
interlink
Wed Jan 31, 2007 1:59 pm
So..when the support of new snmp features will be ready to try?
Users browsing this forum: accesspointkft, ACE3021, alber, arm920t, DarkKnightRUS, drbunsen, Google [Bot], jebz, MSN [Bot], RemiR, Zacharias and 124 guests
