wispwest
Mikrotik Spectrum Analyzer?
Sun Jul 14, 2013 6:58 am
We've been having to connect a UBNT product to do a spectral analyzer lately. Does Mikrotik have plans for doing anything similar? The "freq usage" isn't really worth a darn. I heard somewhere you can get a better view using the terminal?
JorgeAmaral
Trainer
Trainer
Re: Mikrotik Spectrum Analyzer?
Mon Jul 15, 2013 1:56 am
Check this:
http://wiki.mikrotik.com/wiki/Manual:Spectral_scan
wispwest
Sun Aug 03, 2014 9:03 am
Followed the Wiki, put in WLAN1 for the 'number', all I get is an error:
[admin@Airport to Sheep RL] /interface wireless> spectral-scan
number: wlan1
failure: allowed ranges [4790; 6110]
uldis
Mon Aug 04, 2014 10:10 am
most likely your device doesn't support 2ghz range as by default it tries to use 2ghz.
Try to use such command:
/interface wireless spectral-scan wlan1 range=5ghz
gius64
Mon Aug 04, 2014 3:54 pm
It would be great to have a gui for the spectral-scan in winbox
CyberTod
Long time Member
Long time Member
Mon Aug 04, 2014 3:56 pm
There is a gui in Dude. But you are right - it will be a very good addition to winbox.
nz_monkey
Wed Aug 06, 2014 11:06 am
+1
It would be awesome to see this in WinBox
pcunite
Tue Mar 22, 2016 5:48 pm
I need this!
vortex
Tue Mar 22, 2016 8:12 pm
What about Tik App ?
laca77
Wed May 11, 2016 5:52 pm
This is on the linked page ( http://wiki.mikrotik.com/wiki/Manual:Spectral_scan ): "Currently, this feature is supported only for Atheros AR92xx, AR93xx and is NOT supported for Atheros 802.11ac chips (e.g. QCA98xx)."
But on the last picture this scan run on an HAP AC device witch has a QCA9558 SOC. So this feature run or not on HAP AC? Or run it on only 2.4Ghz? Is the 5Ghz (AC) support on the TODO list?
kermu
Sun Oct 30, 2016 12:33 am
Open source driver (eth10k) support spectral scan for QCA98xx chipset family
https://wireless.wiki.kernel.org/en/use ... k/spectral
