MUM Europe 2020
sisal
CLI /ipv6 address add from-pool= ignored
Mon Jul 15, 2013 11:33 am
Hi
I'm using a RB2011 with RouterOS 6.1. When I configure IPv6 addresses using the console, the from-pool option is ignored.
I added a dhcp client on wan interface:
[admin@rt.test] /ipv6 dhcp-client> add add-default-route=yes disabled=no interface=ether1-wan pool-name="ftth-ipv6" pool-prefix-length=64 use-peer-dns=yes
[admin@rt.test] /ipv6 dhcp-client> print detail
Flags: D - dynamic, X - disabled, I - invalid
 0    interface=ether1-wan pool-name="ftth-ipv6" pool-prefix-length=64 status=bound prefix=2001:8e0:2000:8800::/56 expires-after=1h59m59s duid="00030001d4ca6d9db1df" add-default-route=yes use-peer-dns=yes
Then I want to add an interface using this pool:
[admin@rt.test] /ipv6 address> add from-pool=ftth-ipv6 address=::1/64 advertise=yes disabled=no eui-64=no interface=bridge-lan
[admin@rt.test] /ipv6 address> print detail
Flags: X - disabled, I - invalid, D - dynamic, G - global, L - link-local
 4  G address=::1/64 interface=bridge-lan actual-interface=bridge-lan eui-64=no advertise=yes
The option from-pool gets ignored:
When I do the exact same using the web interface:
I get the following:
 4  G address=2001:8e0:2000:8800::1/64 interface=bridge-lan actual-interface=bridge-lan eui-64=no advertise=yes
Additionally, after removing and adding this address for a few times suddenly leads to the error message "input does not match any value of from-pool", leaving the address pool ftth-ipv6 stale. It is visible in the webinterface and cannot be removed, and is not present in the CLI at all. I got a supout.rif with the pool in this state if it would help you.
May I ask you to connect the CLI option from-pool in /ipv6 add address to the right endpoint, so I can use it in my deployment scripts?
Kind regards
Andy
janisk
Re: CLI /ipv6 address add from-pool= ignored
Tue Jul 23, 2013 5:06 pm
latest RouterOS 6.2 have this issue resolved.
Users browsing this forum: No registered users and 125 guests
