mrz
Functions and function parameters
Wed Jul 24, 2013 4:21 pm
Starting from v6.2 we have added new syntax which allows to define functions and even pass parameters to them
ros code
:global myFunc do={
   :put "arg a=$a";
   :put "arg '1'=$1"
$myFunc a="this is arga value"  "this is arg1 value"
Output:
arg a=this is arga value
arg '1'=this is arg1 value
Read more in documentation:
http://wiki.mikrotik.com/wiki/Manual:Sc ... #Functions
tomaskir
Trainer
Trainer
Re: Functions and function parameters
Wed Jul 24, 2013 4:56 pm
I just want to say one thing: I LOVE YOU!
This is something that will make my daily work so much easier :)
Unimus - configuration management, automation and backup solution
Mass Config Push, network-wide RouterOS upgrades, and more!
boen_robot
Thu Jul 25, 2013 12:35 pm
Nice! 8)
Just one question... if I have a script in script environment, must I ":parse" it into a variable before I'm able to call it with parameters, or does this syntax apply to the run command as well? i.e. could I do something like
ros code
/system script run myScript myVar=myValue
And analogously for "/import" scripts?
PEAR2_Net_RouterOS(1.0.0b6) - My API client in PHP
(Rate my posts? If you want... no pressure...)
mrz
Thu Jul 25, 2013 12:52 pm
You can't pass variables with run command. You will need to parse script into variable as shown in the examples.
boen_robot
Thu Jul 25, 2013 2:20 pm
OK, but... Could we hopefully get that in the (near?) future?
mrz
Wed Jul 31, 2013 12:24 pm
Few more features:
* Now function can return value with :return command
* Catch run-time errors
ros code
:do {
      :put [:resolve test.com];
} on-error={ :put "resolver failed"};
:put "lala"
output:
resolver failed
lala
http://wiki.mikrotik.com/wiki/Manual:Sc ... ime_errors
tomaskir
Trainer
Trainer
Wed Jul 31, 2013 1:03 pm
Keep it up, thats some great additions.
boen_robot
Wed Jul 31, 2013 3:07 pm
Similarly to the question before... can one :return from a script/import?
(Yeah, I really prefer abstracting away utility functions away, for re-usability's sake)
mrz
Wed Jul 31, 2013 3:16 pm
Currently no, but as a workaround you can add scheduler to run on startup script which will import all required scripts into :global variables.
tomaskir
Trainer
Trainer
Sat Aug 03, 2013 3:15 pm
I got time today to play with this, so a few questions:
1) It seems you cant pass variables to functions, this should work, but doesnt:
ros code
:global PutValue do={
	:put $1
:for i from=1 to=3 do={
	:put $i
	$PutValue $i
2) Can you not define functions as :local? This should work, but doesnt:
ros code
:local PutString do={
	:put function
	:put $i
	$PutString
Ivoshiee
Sun Aug 04, 2013 12:10 am
Finally something to improve the scripting, but do you plan to implement JIT compilation of the scripts or some other means to lower the CPU utilization as well? It is needed because the scripting engine on ROS is killing the system performance - it is too simple to implement a script that is doing nothing, but CPU load is at 100%.
mrz
Mon Aug 05, 2013 11:32 am
tomaskir these problems will be fixed in next release.
tomaskir
Trainer
Trainer
Mon Aug 05, 2013 11:33 am
Thanks!
tomaskir
Trainer
Trainer
Tue Aug 06, 2013 5:38 pm
Another thing which doesnt work is functions accessing local variables:
ros code
:local sText "This is a sting of text."
:global putString do={
	:put $sText
$putString
:put $sText
So since I cant at the moment define local functions yet, I have to keep all my variables and all my functions as global, which is a mess and creates potential for naming conflicts :)
mrz
Tue Aug 06, 2013 5:51 pm
Of course it will not work, function is function and it can't see local variables defined in main scope.
You need to pass parameter when executing function
for example:
ros code
:global sText "This is a sting of text."
  :put $txt
$putString txt=$sText
Since there is a bug with local vars being passed. I am using global as an example
tomaskir
Trainer
Trainer
Tue Aug 06, 2013 6:22 pm
You mentioned that you will fix functions to work in local scope in next release. So theoretically:
Since the whole script is enclosed in { }, the whole script is a single scope.
:local functions defined in this scope should be able to access other :local variables defined in the same scope.
So will it be possible (in next release when :local functions work) to do this, since the function and variable are in same scope?
ros code
# local variable
# local function
:local putString do={
	:put $sText
	:set sText "Now a different string of text"
$putString
:put $sText
As you said, you can acomplish this with passing an argument to the function, but if it also works this way, it gives us more options :)
I dont have to pass an argument and then return a value, all is handled with the variable, so less code to accomplish the same.
Also, one more request, since it seems you guys are actively working in this area right now. Would it be possible to implement a "date" variable type? We have a "time" type which works great. Example:
ros code
:local curTime
:local curDate
:set curTime [/sys clock get time]
:put [:typeof $curTime]
# works great with compares etc
:if ($curTime > "12:00:00") do={
	:put "Its after noon"
} else={
	:put "Its before noon"
# also works great
:put ($curTime + 1h)
:set curDate [/sys clock get date]
:put [:typeof $curDate]
# doesnt work since type is str
:if ($curDate > "jan/01/2013") do={
	:put "We are after 2013"
} else={
	:put "We are before 2013"
:put ($curDate + 1d)
If a "date" type existed and was handled the same way as a "time" type, it would save me SO MUCH work in scripting. It would only take a couple of hours for a programmer to make this, but would save hundreds :)
Also thanks to listening to my silly requests :)
mrz
Wed Aug 07, 2013 10:34 am
You will never be able to access local variables (defined outside function) inside function. For that use global variables.
tomaskir
Trainer
Trainer
Wed Aug 07, 2013 11:53 am
Understood, will either pass argument and return value, or use a :global.
Any info on the "date" type?
Feklar
Tue Sep 10, 2013 10:55 pm
Few more features:
ros code
:do {
:put "lala"
output:
resolver failed
lala
Do you have an example of using the :return feature? I cannot find an example of it on the Wiki.
mrz
Thu Sep 26, 2013 1:45 pm
Feklar
Thu Sep 26, 2013 10:51 pm
I was more asking, can you actually do something with the returned value, or does it only put it on the console? Or in the case of a function, will it return to the main script without executing the rest of the called function?
mrz
Fri Sep 27, 2013 10:42 am
Yes of course you can use returned value anyway you like. for example
ros code
[admin@x86] > :global sum do={ :return ($1 + $2)}
[admin@x86] > :put (14 - [$sum 3 4])
7
janisk
Mon Sep 30, 2013 11:10 am
do anything you like with result:
:global lala [$sum 3 4]
now vaiable lala will hold the value of the return.
sten
Forum Veteran
Forum Veteran
Fri Feb 21, 2014 4:03 pm
With or without JIT compilation, it will always be simple to write bad code.
Move along. Nothing to see here.
boen_robot
Fri Feb 21, 2014 4:17 pm
Having it be "simple" to write bad code is one thing... having it be unavoidable is another. And with ROS scripting, it's simple to think of scenarios where bad code is unavoidable.
mishaM
Sat Mar 01, 2014 4:49 pm
Hi dear Mikrotik Team,
I create function , and can't retrieve datas
ros code
[misha@test] > ip route print where 172.16.2.1 in dst-address dynamic
Flags: X - disabled, A - active, D - dynamic, C - connect, S - static, r - rip, b - bgp, o - ospf, m - mme,
74 ADo  172.16.2.0/29                      172.16.88.1             110
when i convert this command to function, it not working
ros code
[misha@test] > :global route do={/ip route print where $1  in dst-address dynamic }
[misha@test] > $route 172.16.2.1
[misha@test] >
efaden
Sat Mar 01, 2014 5:15 pm
+1. A true language would be nice.
Sent from my SCH-I545 using Tapatalk
skot
Long time Member
Long time Member
Sat Mar 01, 2014 8:57 pm
ros code
ros code
[misha@test] >
If you run this, you can see that the passed parameter type is "str" (string) and needs to be converted to an IP.
ros code
:global route do={:put [:typeof $1]; /ip route print where $1 in dst-address dynamic}
$route 172.16.2.1
You can do it this way when you call the function:
ros code
:global route do={/ip route print where $1 in dst-address dynamic}
$route [:toip 172.16.2.1]
Or put the code in the function itself:
ros code
:global route do={/ip route print where [:toip $1] in dst-address dynamic}
$route 172.16.2.1
I don't need any karma... I have Ιησους Χριστος!
mishaM
Sun Mar 02, 2014 8:57 am
ros code
ros code
[misha@test] >
ros code
$route 172.16.2.1
ros code
ros code
$route 172.16.2.1
thanks! , problem solved with [:toip $1] :)
MarcusH
Fri Jun 27, 2014 7:53 pm
Is there a way to get an array of the unnamed/positional parameters?
For example, if "args" were the array of positional/unnamed parameters, this would work:
:global myFunc=do {
    :put $args
$myFunc "1" "2"
1:1;2:2
This would make functions with a variable number of parameters possible.
rextended
Fri Jun 27, 2014 9:37 pm
simply check inside the function if the parameter are passed with ":typeof $3", if the results are "nothing" the parameters are not provided, in this way you can create one function that produce different outputs based on parameters number.
One RouterOS to rule them all.
Clauu
Sun Aug 31, 2014 7:01 pm
Is there any function for archiving files/folders? tar for ex
Having fun with RB850Gx2, RB2011UiAS-2HnD, RB260GSP, RB751U-2HnD, CRS112, RB3011UiAS, hAP ac, cAP ac and hAP ac². More others on the way :-)
rextended
Mon Sep 01, 2014 12:41 am
no one.
dissident76
Mon Apr 13, 2015 5:11 pm
ros code
:global myFunc do={
   :put "arg a=$a";
   :put "arg '1'=$1"
Output:
In case someone finds this useful, I've added this code to my start-up script to automatically define functions from system scripts that start with "Function" (or any other prefix that you may choose). Just creating a script called "FunctionWhatever" will automatically define a global function with the same name available from terminal session or from any other script (remember to declare the function in the script that will use it, though).
Enjoy! :)
:local fnArray;
:foreach f in=[/system script find where name~"^Function.*"] do={:set fnArray ($fnArray.",".[/system script get $f name])};
:set fnArray [:toarray $fnArray];
:foreach f in=$fnArray do={:exec script=":global \"$f\" [:parse [/system script get $f source]]"; /log info ("Defined function ".$f);};
rftnon
Wed Mar 09, 2016 11:23 pm
Thanks!
useful ... 8)
korniza
Fri Mar 11, 2016 5:35 am
mrz functions script is a lifesaver if you start coding real big scripts! :D
Thanks mrz for sharing!
korniza
Fri Mar 11, 2016 6:34 am
how do you call the Functions* after running this script? Do I have to use
 /system script run "Functions"
or there is another fancy way( for ex.
:local testfunc $Functions
ros code
:global myFunc do={
   :put "arg a=$a";
   :put "arg '1'=$1"
Output:
Enjoy! :)
:local fnArray;
icosasupport
Wed Nov 22, 2017 7:11 pm
I have some examples of that here viewtopic.php?f=9&t=40507#p627016
Icosa.
DaleNicholsSTG
Fri Aug 03, 2018 2:02 am
You can do it if you use the older [:parse] functionality. I wanted a function to do some debug logging of a script, but only when I needed it.
Notice the line where I set logfn. "$ident" refers to the value of the local "ident" variable at the time that line is executed. "\$1" refers to the first parameter of the log function when the log function is executed.
Of course, this only allows access to the values of local variables when the function is defined, not the values those variables have when the function is running.
# Declare variables to be used by $log
:local verbose true
:local ident "install"
# Create $log
:local logfn ""
:if (verbose) do={:set logfn ":log info \"$ident: \$1\";"}
:local log [:parse $logfn]
# Use $log
$log "Starting"
Users browsing this forum: No registered users and 22 guests
