ohara
Voltage fluctuation
Thu Aug 08, 2013 12:16 am
Hi, since a few days I noticed a drop in voltage on one of my Grooves at ca. 5pm every day. Does that mean that the device is using more power at that time? Or is it because of the electrical installation?
SurferTim
Re: Voltage fluctuation
Thu Aug 08, 2013 4:46 am
If it is an unregulated power supply, it is probably due to daily mains voltage variations. Highest voltage is around 4am, and the lowest is around 4pm.
ohara
Thu Aug 08, 2013 8:34 am
Thanks.
Lakis
Forum Veteran
Forum Veteran
Fri Aug 09, 2013 1:12 am
It can be temperature related when it's hot voltage sensor begin to be "not accurate"
I've made a test about that on RB433AH
Also in some case lets say if u have wlan on some board when it's active "in time when sending data to clients" wlan is draining more power - voltage sensor may show less
see the time frame
I have almost same reading on all RBs
ohara
Mon Aug 12, 2013 12:09 am
I also thought it to be temperature/sun related for some reason. anyway, thanks for your insight.
janisk
Tue Aug 13, 2013 11:21 am
these are not measuring devices so they are not that accurate. Newer RouterBOARD products use different measuring chain and are not that susceptible to temperature changes.
SurferTim
Tue Aug 13, 2013 2:19 pm
The temperature would not explain why I get these same variations. My RB433AH is inside in the a/c under almost no client load. The temperature only varies a couple degrees. Mine is caused by the daily mains power variation.
Users browsing this forum: Bing [Bot] and 66 guests
