jbohac
manually adding link local IPv6 address
Sun Aug 11, 2013 11:10 pm
my ISP is routing my global prefix over a link-local address. My side of the link is fea0:15::2/64, the ISP's side is fea0:15::1.
I am trying to add this address to my WAN iterface:
/ipv6 address add interface=ether1-internet address=fea0:15::2/64
failure: can not add link local address
How am I supposed to do this? This setup worked fine with my previous linux router:
ip a a fea0:15::2/64 dev eth1
ip route add ::/0 via fea0:15::1 dev eth1
snop
Re: manually adding link local IPv6 address
Mon Sep 16, 2013 8:10 pm
i have same problem, i wrote email to support too
Majklik
Tue Sep 17, 2013 3:19 pm
I'm missing this feature too.
The suport was informed some time ago too.
maxknax
Wed Jun 01, 2016 11:41 am
Almost 3 Years and nothing new.
Now I have the same Problem, Datacenter wants ro route our v6 net to fe80::2/64
felipecarneiro
Thu Jun 16, 2016 5:18 am
strg
Tue Nov 21, 2017 10:38 pm
Is this fixed ? Or a workaround exists ? My supplier wants me to add fe80::2a02:2f0f:a8 as a local link address for routing my 48 ipv6 subnet and i cant.
Is there a workaround ?
ZeroByte
Tue Nov 21, 2017 11:50 pm
Unfortunately, Mikrotik does not allow manual configuration of the link-local address. It auto-generates the address using EUI-64. You could possibly create a specific link-local address based on this by manually specifying the MAC address of your WAN interface to a value whose EUI-64 conversion is what you want, but unfortunately, the address your ISP specifies is impossible to generate using EUI-64 because the middle of it must have ff:fe in there.
if your mac is 11:22:33:44:55:66 this would map to fe80::1322:33ff:fe44:5566 - not only is fffe stuffed in the middle of your MAC address, but the 7th bit is flipped (so 11: -> 13).
There is no MAC address possible to result in:
FE80::0000:2A02:2F0F:00A8 because the boldface digits here MUST be FF:FE in EUI-64.
Mikrotik, please fix this!
strg
Wed Nov 22, 2017 2:25 pm
Thanks @ZeroByte, with each day passes more and more mikrotik is a disappointment. I will stop recommendations to other people.
strg
Thu Nov 23, 2017 9:04 pm
Mikrotik, official answer ?
ZeroByte
Mon Nov 27, 2017 8:27 pm
While Mikrotik personnel do participate, this forum is more of a community forum than an official communication medium - so I would suggest that you send an email to support requesting this feature. I did list this as one of the things I consider both important and "easy to implement" for my IPv6 Triage List thread. Feel free to go add your voice to that thread as well.
mrgnulinux
Fri Dec 29, 2017 6:47 pm
Hi, the problem in mikrotik is this not permit add link local address, but the solution to the first post is this
https://wiki.mikrotik.com/wiki/Manual:S ... v6_Routing
this example is the same problem has the first post.
around
Tue Jan 15, 2019 9:34 am
I have the same problem, RouterOS 6.43.8 =(
carsenie
Sun Dec 20, 2020 1:13 pm
Create an ipv6-pool with fe80 :: / 56 and prefix length 64.
Then add normal ip address only it will be selected from the pool in the form ::aaa:bbb:ccc/64
PS
Uncheck advertise
Attached pictures
Good Luck
Ciprian Arsenie
IT systems admin
rextended
Tue May 24, 2022 4:08 pm
If remote is fe80::192:168:88:1/64 and local must be fe80::192:168:88:2/64
/ipv6 pool
add name=pool-link-local-sfp1 prefix=fe80::192:168:88:2/128 prefix-length=128
/ipv6 address
add address=::/128 advertise=no from-pool=pool-link-local-sfp1 interface=sfp1
But why do not permit to set directly the additional link-local IPv6,
instead to leave the user to search a way for circomventing this absurd block...
Some user are FORCED to personalize link-local address from source mainstream...
erwand
Thu Jan 25, 2024 9:03 pm
My ISP only routes to a link-local address (static routes to the 8 /64 it provides)
And today upgrading to 7.13.3 changed the main mac address, and thus the link-local address.
I'll try the pool workaround to get a fixed link-local address for next upgrade.
Users browsing this forum: BoraHorza, holla29, jaclaz, JeffreyAxori, Majestic-12 [Bot], markinhusxp and 205 guests
