ramtin7
Radius Server is not responding with Hotspot
Fri Aug 30, 2013 11:33 pm
I searched anywhere to solve this problem. but its not working in my case!
sorry for repeat this subject. help me plz...
these are my logs:
[admin@AFIFNET Sadra] >[/color] radius print
Flags: X - disabled
# SERVICE CAL... DOMAIN ADDRESS S
0 hotspot 127.0.0.1 1
[admin@AFIFNET Sadra] > ip hotspot profile print
Flags: * - default
0 * name="default" hotspot-address=0.0.0.0 dns-name=""
html-directory=hotspot rate-limit="" http-proxy=0.0.0.0:0
smtp-server=0.0.0.0 login-by=cookie,http-chap http-cookie-lifetime=3d
split-user-domain=no use-radius=no
1 name="hsprof1" hotspot-address=192.168.100.1 dns-name=""
smtp-server=0.0.0.0 login-by=mac,http-chap,https,http-pap
mac-auth-password="" ssl-certificate=none split-user-domain=no
use-radius=yes radius-accounting=no nas-port-type=ethernet
radius-default-domain="" radius-location-id="" radius-location-name=""
radius-mac-format=XX:XX:XX:XX:XX:XX
[admin@AFIFNET Sadra]tool user-manager router pr
int
Flags: X - disabled
0 customer=ramtin name="router1" ip-address=127.0.0.1 shared-secret="1"
log=auth-ok,auth-fail,acct-fail use-coa=no
ramtin7
Re: Radius Server is not responding with Hotspot
Tue Sep 03, 2013 2:55 pm
nobody?! :(
noib
Tue Sep 03, 2013 4:13 pm
It looks like you have set your Radius to 127.0.0.1 .. do you have a running Radius server on the mikrotik device, and did you double check the ports (mikrotik radius is not on port 1812 by default) ?
ramtin7
Wed Sep 04, 2013 3:01 pm
thanks.
but my radius port is 1812
yes i have UM on my mikrotik.
no other idea? :(
noib
Fri Sep 06, 2013 12:35 pm
I think you have to test what is wrong: it can be either the radius server, either the radius client
To test the server, use a simple radius client for windows and try to connect to your routerboard.
To test the client, make the routerboard connect to another radius.. windows/Lunix Radius server if you have one available, or install FreeRadius on your desktop.
ramtin7
Sat Sep 07, 2013 1:41 pm
Hi.
Tnx dude. But my radius server is usermanager.
I followed these steps:
http://wiki.mikrotik.com/wiki/User_Mana ... ot_Example
ramtin7
Mon Sep 16, 2013 5:07 pm
please help me to solve this :(
ramtin7
Tue Mar 11, 2014 3:58 pm
I cant solve my problem
Please somebody help
Sent from my iPhone using Tapatalk
bax
Tue Mar 11, 2014 4:42 pm
It must work ... probably your config is bad ... try setup again ... everbody is work ... so must be something wrong with setup
ramtin7
Thu Mar 13, 2014 2:22 pm
Would sb please login to my router and check my config?
pepinw
Fri Aug 29, 2014 9:02 pm
So,
I was having this problem for the last couple days..
Its true, that the UM works if you use the public interface address, however, mine was a DHCP client address, and would have been complicated to manage.
TLDR;
I needed an accept rule to make the 127.0.0.1 UM host work locally.
add chain=input comment="allows user manager to work with local hosts" src-address=127.0.0.0/24
I put this as my first rule in the firewall filter chain. & BOOM. -- Done.
-- Pepin
joenmarz
Sun Aug 20, 2017 2:46 pm
So,
TLDR;
-- Pepin
This works perfectly! Thanks Pepin.
shalaby84
Tue Jan 23, 2018 11:37 pm
So,
TLDR;
-- Pepin
you know pepin , i did reset my router and usermanager more then 5 times and re-confige router for my network :D till i see your post
thank you pepin
Islam Shalaby
dbaricawa
Wed Sep 19, 2018 1:13 pm
Hello Pepinw
I would like to ask what seems to be the problem here. I already add the firewall rule that you send here but it gives me the same response ...
here my config can you please check what's wrong here?
I really appreciate your help.
fernando1787
Fri Oct 19, 2018 2:38 pm
Hello, try extending radius client timeout, sometimes radius server can take some time to send a response.
Enviado desde mi Alcatel_4060A mediante Tapatalk
ashpri
Sun Nov 25, 2018 10:12 am
So,
TLDR;
-- Pepin
2018 and this post solved my issue. Bump for the benefit of others with RADIUS server not responding issue.
Users browsing this forum: No registered users and 1 guest
