TheWiFiGuy
Scripting - FIND with Wildcard
Mon Sep 02, 2013 3:37 pm
Hi
Im trying (unsuccessfully) to find some comments based on using a wildcard:
I have some hotspot ip-binding(s) that have a comment such as 'BP:9'
I simply need a way to find the comments that start 'BP:' , so that I can decrease the number after BP: and when it reaches 0, i'll remove the entry.
I just cant find the correct format of regex and the Where command...
This doesnt work:
:put [find where comment~"BP:"]
any help much appreciated.
Mikrotik Consultant.
MTCNA, MTWCE, MTCTCE, MTCRE, MTCINE
boen_robot
Re: Scripting - FIND with Wildcard
Mon Sep 02, 2013 3:41 pm
I think the ":" may be a special character in regex. Plus, you'd be searching for all CONTAINING, not STARTING, so try:
ros code
:put [find where comment~"^BP\:"]
or if that doesn't work, try to make it more explicit, like:
ros code
:put [find where comment~"^BP\:.*$"]
P.S. I like trains...
PEAR2_Net_RouterOS(1.0.0b6) - My API client in PHP
(Rate my posts? If you want... no pressure...)
efaden
Mon Sep 02, 2013 4:27 pm
ros code
ros code
If its in a script the $ needs to be escaped also.
ros code
:put [find where comment~"^BP\:.*\$"]
.. I'm not sure if the : needs to be escaped. You'll just have to try it.
janisk
Mon Sep 02, 2013 4:59 pm
.(dot) *(star) $(dollar) all are special symbols where (dot) - one symbol; (star) - previous symbol repeated none or any times; (dollar) - end of string.
if you escape them, then script will look for the symbol inside the string and script will not work.
efaden
Mon Sep 02, 2013 5:17 pm
If you don't escape the $ in the string then inside of a script it tries to match it for a variable...
janisk
Tue Sep 03, 2013 2:59 pm
yes, (dollar) has to be escaped
TheWiFiGuy
Wed Sep 04, 2013 8:14 am
Thank you guys,
I can now run this fine from the terminal, but when pasting my code into a script , I have a problem with the Tilde character directly after the where statement causing problems.
comment~"^BP\:.*$"]
^-This character gets flagged up when running /sys scr print as being bad and stops the script.
How do I go about escaping that?
boen_robot
Wed Sep 04, 2013 11:18 am
You shouldn't be escaping the "~". It's what tells the scripting engine this is a regex match.
How does your whole line look like?
efaden
Wed Sep 04, 2013 3:26 pm
I don't think you actually need the where in the script. Show us the full script. But for example the below code works fine.
ros code
:foreach i in [/interface ethernet find comment=~"^BP:.*\$"] do={
 :put "test"
Jotne
Sun Jun 16, 2019 11:40 pm
ros code
 :put "test"
PS script does not work with both ~ and =
So it should be:
:foreach i in [/interface ethernet find comment~"^BP:.*\$"] do={
 :put "test"
Why do not use Splunk to monitor your MikroTik Router(s)? Look at this page in how to set it up.
MikroTik->Splunk
Fantomas
Wed Jan 13, 2021 5:52 pm
Escaping \$ works fine. But I must be missing something since escaping a dot like \. gives me a syntax error.
I'd like to prevent script from potentially finding files that have longer extensions:
:local mm "01"
:local yyyy 2021
:foreach FILE in=[/file find name~"^disk1/backups/$yyyy-$mm/.+\.txt\$" ] do={
:local name [/file get $FILE name];
:put $name;
Error: syntax error (line 4 column 63)
Jotne
Thu Jan 14, 2021 9:14 pm
Double escape the dot. You can also remove the ; at end of each line (only needed when multiple commands on same line).
:local mm "01"
:local yyyy 2021
:foreach FILE in=[/file find name~"^disk1/backups/$yyyy-$mm/.+\\.txt\$" ] do={
	:put $name
MikroTik->Splunk
Users browsing this forum: No registered users and 11 guests
