kometchtech
RB912UAG-5HPnD-OUT not working!
Sun Sep 08, 2013 6:55 pm
I bought the RB912UAG-5HPnD-OUT, ​​but it is a situation that does not work well.
In the form you are using PoE Injector the RB912UAG-5HPnD-OUT, you connect the AC power,
it is connected to a PoE Port of RB951G-2HnD, but the power LED RB912UAG-5HPnD-OUT does not light.
Is this a failure?
The power LED on the PoE Injector is a state that is lit.
Best regards
Routerboard Users Group JP
http://www.rb-ug.jp/
CCR1009-8G-1S-1S+, RB750Gr3, CRS226-24G-2S+, RB850Gx2, RB960PGS, CRS317-1G-16S+,
RB2011UAS, CRS125-24G-1S, RB962UiGS-5HacT2HnT, CRS212-1G-10S-1S+, RB3011UiAS
haik01
Re: RB912UAG-5HPnD-OUT not working!
Mon Sep 09, 2013 9:14 pm
It should be connected to the Eth 1 (or LAN1). If nothing happens (no LED goes on etc...) return for a RMA to the supplier.
kometchtech
Mon Sep 09, 2013 9:19 pm
Hi there
Thanks for the information.
I try to connect to Eth1, but the situation did not improve.
So, I decided to RMA negotiating with dealers.
Best regards
normis
Tue Sep 10, 2013 1:10 pm
Did you connect the PoE correctly? See 1:58 on this video: https://www.youtube.com/watch?v=-KNo1B7K-YY#t=121
kometchtech
Tue Sep 10, 2013 2:03 pm
hi, normis
The description of how to connect, thank you.
As long as you see this, I was mistaken about the connection method.
However, you are in that you have to exchange correspondence as the RMA dealer.
So you no doubt next time.
I would like to thank the appropriate advice.
Best regards
InoX
Wed Sep 11, 2013 12:47 am
:lol: :lol: :lol:
kometchtech
Wed Sep 11, 2013 1:05 am
I was connected as shown in the image, but the power does not enter, it did not work.
scampbell
Trainer
Trainer
Wed Sep 11, 2013 6:58 am
That'll sure do it :lol:
Also be sure when testing that your Ethernet cable has all 8 wires connected (look at RJ45). Some inexpensive cables (shipped with cheap soho 10/100 routers for example) only have 4 wires so will not work for PoE.
kometchtech
Wed Sep 11, 2013 7:09 am
I've tried the cable of category 5e something of this, but none was also no good.
scampbell
Trainer
Trainer
Sat Nov 30, 2013 2:07 am
In case anyone did not understand - the image is how NOT to connect the cable :-)
Power to Mikrotik is supplied via the socket connecter of the adapter using an additional RJ45 cable.
kometchtech
Sat Nov 30, 2013 2:11 am
As you say, how to connect the cable seems to be bad.
We're now eliminated this problem.
Best regards
Users browsing this forum: No registered users and 29 guests
