andersm
ROS 6.3 + Sierra 320U USB LTE. how do you make it work?
Wed Sep 11, 2013 3:37 pm
I cant seem to make a Sierra Wireless 320U USB LTE dongle work under ROS 6.3
I had no issues with the card under 5.xx, it appeared as a ppp device, and has worked perfectly on many deployed routers.
Since upgrading to ROS 6.3 it now appears as an LTE device. I cant "Scan" or get "Info" from the device.
Is this device no longer supported under 6.3 or am I missing something?
I have a lot of units active in the field, and would be a pain if they wont work under 6.xx
Any assistance would be greatly appreciated,
Andy.
pcunite
Re: ROS 6.3 + Sierra 320U USB LTE. how do you make it work?
Thu Sep 12, 2013 6:22 pm
Try the new v6.4 version.
http://www.mikrotik.com/download
uldis
Thu Sep 12, 2013 6:38 pm
if you do not like the LTE method for those card you can disable that by going into the 'port firmware' and select 'yes' for ignore-directip-modem setting.
andersm
Fri Sep 13, 2013 1:34 pm
Thanks uldis!
Your suggestion worked perfectly! :)
Cheers,
Andy
PiVi
Mon Jul 07, 2014 10:39 am
Hello - you use any special firmware with Sierra U320 ?
On hardware supported list is:
http://wiki.mikrotik.com/wiki/Supported_Hardware
Sierra Wireless AirCard 320U [97] v6.0
Vendor/product id pair should be 0x0f3d/0x68AA and DirectIP firmware loaded on the modem.
USB
PiVi
andersm
Tue Jul 08, 2014 2:26 pm
PiVi,
I have just used it with the stock Telstra firmware.
Noticed they are now badged "Netgear" but seem to still work without the directIP connection.
I'll check what firmware its running tomorrow.
Cheers,
Andy
RogerWilco
Wed Jul 09, 2014 2:31 am
The 320U has worked since 5.4 using PPP connection.
It still doesn't work with LTE/DirectIP
I have no idea who put that on the Wiki. It doesn't even make sense. The drivers are not in the modem and never have been.
You have to, the modem gets stuck otherwise. I've posted it about it before. Just search for "320U".
PiVi
Mon Jul 21, 2014 11:37 am
I just got my modem 320U Sierra Wireles
Where is this configuration ?
In modem settings or in Mikrotik system ?
Where exactly/specifically ?
On ppp metod SW 320U works only in HSDPA/HSDPA+/3G mode ?
Not LTE ? (sorry if this is stupid question - i dont have knowledge about cell transmission).
Any chance to compatybile LTE USB modem not Hi-Link (without second NAT) ?!?
Im looking for modem LTE - but only modem.
All Hi-Link devices this is routers - not modems.
PE
RogerWilco
Wed Jul 23, 2014 8:00 am
Open WinBox and go to System -> Ports on the left hand side. Then click the 'Firmware' button. Uncheck the box, then reboot.
The modem WILL connect to a 4G network, it won't be able to get speeds above 12-14mbps.
PE
I have no idea what any of that means.
Users browsing this forum: erlinden, eworm, mudhoney, saulllynas, tgkmilo, Znevna and 114 guests
