zaherhamiyah
what is the differnce between ip proxy and web proxy?
Sun Apr 02, 2006 3:34 am
and can i use them at the same time in mikrotik router os?
sergejs
Sun Apr 02, 2006 2:19 pm
Using regular 'web-proxy' package, the main difference between web-proxy and proxy, that web-proxy provides caching facility, but proxy doesn't.
Using web-proxy test package (MikroTik proxy), you will get only 'ip proxy', that provides with caching facility.
zaherhamiyah
Sun Apr 02, 2006 2:56 pm
my dear,
when i activate "webproxy-test" in package list the "webproxy" package disappears, and when i activate only webproxy i get the two http proxy and webproxy!!!!!
And inside the mikrotik's manual v 2.9(http://www.mikrotik.com/docs/ros/2.9/) we have two subjects:
1-http proxy and ,
2-webproxy
for 1 the manual says
"The MikroTik RouterOS implements the following proxy server features:
Regular HTTP proxy
Transparent proxy. Can be transparent and regular at the same time
Access list by source, destination, URL and requested method
Direct Access List (specifies which resources should be accessed directly, and which - through another proxy server)
Logging facility "
And for 2 the manual says
Regular HTTP proxy
Cache access list (specifies which objects to cache, and which not)
Logging facility"
And u said"Using web-proxy test package (MikroTik proxy), you will get only 'ip proxy', that provides with caching facility."and "that web-proxy provides caching facility, but proxy doesn't."
So how webproxy provides caching and proxy doesn't?.
Then u said "you will get only 'ip proxy', that provides with caching facility."
For now i understand from the manual one thing that webproxy provides caching and http proxy doesn't provide caching.
So my question is what is http proxy exactly?and can i use it with webproxy at the same time?
sergejs
Sun Apr 02, 2006 6:27 pm
1. Using web-proxy test package, there will be only proxy in 'ip proxy', MikroTik proxy that provides caching facility.
2. Using regular 'web-proxy' package, you will have,
'ip proxy', something like HTTP and FTP firewall or to redirect requests to external proxy.
'ip web-proxy', proxy with caching.
No, you have to use one, 'ip proxy' or 'ip web-proxy'.
zaherhamiyah
thanks
Sun Apr 02, 2006 7:25 pm
thanks
Users browsing this forum: vikinggeek and 159 guests
