MUM Europe 2020
dohmniq
Formatting 32GB microSD card causes crash! [RB435G v6.4]
Sat Sep 14, 2013 1:20 pm
I inserted a 32GB microSD card into a RB435 running 6.4.
[admin@RB435G] /store disk> print
Flags: S - system
 #   NAME        TOTAL-SPACE    FREE-SPACE STATUS
 0 S system        126976KiB     107664KiB ready
 1   micro-sd        invalid
[admin@RB435G] /store disk> format-drive 1
WARNING: All disk data will be lost! Format drive? [y/N]:
y
drive will be formatted shortly
[routerbox has crashed]
Strangely no supout.rif is being generated either even though I have the watchdog configured to email them (and emailing works when done manually).
I was planning to use the microSD as a web proxy cache.
Any ideas?
jandafields
Re: Formatting 32GB microSD card causes crash! [RB435G v6.4]
Sat Sep 14, 2013 10:25 pm
Flags: S - system
 1   micro-sd        invalid
y
Any ideas?
Is it a compatible card? Try another card and then send the card's make and model to support@mikrotik.com
dohmniq
Sat Sep 14, 2013 10:56 pm
I would try another card but unfortunately it's 16m up in the air. Even worse, I can't remember the make and model of the card!
Slightly confused about the issue of compatibility - is this is limitation of the microSD interface chipset or something resolvable by MikroTik with firmware?
I have successfully used more of these cards in microSD-to-USB adapters, etc. without any issues. Why would it NOT work?
Users browsing this forum: Google [Bot] and 120 guests
