MUM Europe 2020
sergejs
MUM Live video from St. Louis starting now!
Thu Sep 19, 2013 4:52 pm
nz_monkey
Re: MUM Live video from St. Louis starting now!
Thu Sep 19, 2013 5:31 pm
Thanks Sergejs,
The audio was great this time :)
A lot of cool new products for us to buy.
http://thebrotherswisp.com/ | Mikrotik MTCNA, MTCRE, MTCINE | Fortinet FTCNA, FCNSP, FCT | Extreme Networks ENA
ronniee
Thu Sep 19, 2013 5:46 pm
I missed the first presentation :(
There was some news about new 24 port Cloud Core Router Switch? When will be ready???
And when will make a router with ~8 Ethernet port with POE output? Like ubiquiti.
honzam
Thu Sep 19, 2013 6:32 pm
QRT G - New integrated antenna product at 2.4GHz
CCR 1009 - 9 cores, 8GBit ports • 1SFP port • 1SFP+ port
mAP - PoE injector 8-57V, Built in 2GHz AP
CCR1016-12S-1S+ - 12SFP slot and one 10Gbit slot
CRS - Cloud router switch
RB953GS-5HnT - routerboard with wifi and 2x SFP , 3x Gig. eth, New Atheros “Scorpion” CPU, 3 chain 5GHz wireless - wau :D
Thank you
http://www.mikrotik.com/download/share/us13.pdf
LAN, FTTx, Wireless. ISP operator
lcrhea25
Thu Sep 19, 2013 6:37 pm
Lost the stream and now it says stream not found. Anybody know what is going on?
urmom
Thu Sep 19, 2013 6:46 pm
I got that, too. The guy mentioned something about a new product and then the stream ended.
honzam
Thu Sep 19, 2013 6:51 pm
urmom
Thu Sep 19, 2013 6:54 pm
So what does that have to do with the stream dying?
normis
Thu Sep 19, 2013 7:08 pm
Stream disconnected for a few minutes, it was restored. Product presentation PDF is linked above.
lcrhea25
Thu Sep 19, 2013 7:28 pm
Will Steve Discher's video presentation be posted on Tiktube?
efaden
Thu Sep 19, 2013 7:36 pm
Normis: When will the mAP be available? Where can we get more info on it. Looks like a pretty cool little device.
normis
Thu Sep 19, 2013 7:49 pm
All videos will be on tiktube in around 2 weeks (because we continue our travel to Mexico MUM after the USA MUM).
mAP will be available in beginning of 2014
asaleh75
Trainer
Trainer
Thu Sep 19, 2013 8:19 pm
Syed Abu Saleh
( MTCNA, MTCRE, MTCWE, MTCTCE, MTCUME, MTCINE )
MikroTik Certified Trainer & Consultant
http://www.sastechbd.com
Cell:+8801713060704
honzam
Thu Sep 19, 2013 9:00 pm
Normis - What means "New Atheros “Scorpion” CPU"
It is mipsbe, powerPC, or? How many Mhz?
soulflyhigh
Thu Sep 19, 2013 9:42 pm
Normis,
Image from projector on the wall is way to bright to watch online, it is impossible to see almost anything,
could someone reduce the exposure settings on the web camera?
MTCRE, MTCTCE
onnoossendrijver
Thu Sep 19, 2013 11:25 pm
I like the RB953GS-5HnT! Can you give me a price indication?
Linux/network engineer: ITIL, LPI1, CCNA R+S, CCNP R+S, JNCIA, JNCIS-SEC
ronniee
Thu Sep 19, 2013 11:57 pm
Maybe change a little the angle and distance of the camera.
Tomorrow for the Janis presentation, please get a better projector with a bigger image. Now with a white background can' t see the texts.
AlArenal
Fri Sep 20, 2013 12:02 am
Atheros is in fact Qualcomm Atheros, after Qualcomm bought Atheros a couple of years ago.
And Qualcomm's first Snapdragon processor was dubbed Scorpion. It was based on the ARMv7 instruction set and similar in architecture to the ARM Cortex-A8 with some multimedia SIMD extensions.
http://en.wikipedia.org/wiki/Scorpion_(CPU)
I can find references to single core Scorpion SoCs with 0.8 - 1.4 GHz and dual cores with up to 1.7 GHz that have been used / are used in smartphones and tablets.
Maybe they're re-using the core in a new networking chip.
nz_monkey
Fri Sep 20, 2013 2:08 am
So the new RB953 is ARM based.
Nice move.
honzam
Fri Sep 20, 2013 9:12 am
Normis, can you confirm?
Lupin
Fri Sep 20, 2013 9:18 am
Normis, "QRT G" is a dual pool antenna?
It would be perfect in a "23dB" "5Ghz" version. Is that possible?
raz
Fri Sep 20, 2013 9:54 am
when you will show us the new Routing Engine?
janisk
Fri Sep 20, 2013 10:40 am
Nice move.
it is MIPSbe
AlArenal
Fri Sep 20, 2013 10:44 am
Nice move.
it is MIPSbe
Then it's either not Scorpion-based or QA chose to use the nickname again for another (Not yet official?) architecture - which would mark the first time (afaik) that a vendor does so.
janisk
Fri Sep 20, 2013 11:09 am
my guess is - Atheros had this in works when Qualcomm acquired them. For us - nickname just stuck.
AlArenal
Fri Sep 20, 2013 11:33 am
Good idea! I just hope for them they didn't pay $3.3bn just fro some naming rights ;-)
normis
Fri Sep 20, 2013 6:11 pm
It is not ARM based. Atheros Scorpion is Mips-be, QCA9558, more info:
http://www.qca.qualcomm.com/corporate/c ... 9&news=804
rzirzi
Fri Sep 20, 2013 9:32 pm
How much will cost mAP? I was waiting for product like this! It's great news. but could You tell please what price should we expect?
praeses
Fri Sep 20, 2013 11:07 pm
Is the QRT G going to be just plastic like the SXT/SEXTANT/OmniTik/912G Outdoor or is it going to have some sort of RF Shielding? That has been the main obstacle preventing me from pursuing the Routerboard's integrated radios.
asaleh75
Trainer
Trainer
Sat Sep 21, 2013 12:08 am
Getting problem, error "stream not found".
Syed Abu Saleh
Cell:+8801713060704
ropeba
Sat Sep 21, 2013 3:33 am
Normis, which CPU does have CRS?
demopro
Sat Sep 21, 2013 2:11 pm
RB953GS-5HnT will have 3 chain 5GHz wireless, does that mean that this will be 802.11ac ?
Basdno
Sun Sep 22, 2013 3:30 pm
Will CRS be able to deliver "Wire Speed" on all ports so it can be used as a "Coreswitch" in a bigger network?
Is there any limitations in the chip how much it can process effectivly?
Will it run SwitchOS or (preferably;) ) RouterOS?
And most important: When will it be available?? :)
Raf
Mon Sep 23, 2013 9:38 am
No, according to link provided by Normis:
The new reference platform features the QCA9558 dual-band, 3-stream 802.11n system-on-chip (SoC)
Rafał Wójcik from AWB-NET
High Definition enthusiast
normis
Tue Sep 24, 2013 7:41 am
CRS runs RouterOS, and will have new Switch related settings. It will be wire speed because, well, it's a switch :)
normis
Tue Sep 24, 2013 7:42 am
CRS is like RB911 with a smart switch attached, so CPU is like RB911
ropeba
Tue Sep 24, 2013 1:37 pm
Can CRS work as 24 port router and that he's not used as switch? Will ROS see all 24 ports?
macgaiver
Tue Sep 24, 2013 2:48 pm
have you ever used switching in other RB products? RB2011? RB951? RB751? RB450? etc
CRS will have similar implementation - only with 24 ports and with some additional features.
Also as Normis stated is 2-in-1 device (RB911 + manageable switch), so IF not used as switch total trougput will be limited to 1Gbps full duplex
With great knowledge comes great responsibility, because of ability to recognize id... incompetent people much faster.
asaleh75
Trainer
Trainer
Tue Sep 24, 2013 3:25 pm
What about OS?. SwOS or RouterOS?
Syed Abu Saleh
Cell:+8801713060704
ropeba
Tue Sep 24, 2013 4:19 pm
I hope that we will see a little better processor in CRS, in some close future. It doesn't have to be like the one in CCR serie but 1 GHz or 1 GHz dual core would be perfect for our FTTB project.
XTX
Tue Sep 24, 2013 5:05 pm
Hi Normis
Can you elaborate a bit more on the CCR 1009 ?
Scheduled release date ? Price range...more or less than a CCR1016 ?
Some specs sheet maybe ? :)
THX
normis
Tue Sep 24, 2013 7:22 pm
Like I already said, it will be RouterOS. Imagine RB2011 with more ports.
mauricioisp
Tue Sep 24, 2013 8:04 pm
When are we going to know prices?
richinuk
Wed Sep 25, 2013 12:34 pm
I see the mAP appears to take a standard DC input jack. Will this device allow for ESD grounding via the ethernet drain wire? Or, is there an alternative approach?
Kreacher
Fri Sep 27, 2013 3:45 am
It looks more like an indoor device.
RB953GS-5HnT
But what kind of device is the RB953GS-5HnT or what is the main usage of this device?
Is it a small router or more a WLAN AP (CPE) device?
CCR1009
The CCR1009 looks really great but is the TILE-Gx9 platform sorted wit a high
speed encryption engine called MiCA or is this a variant without MiCA?
And how many RAM can be inserted as a maximum?
But all in all, yes, good work, well done MikroTik!
P.S.
@normis
Under the link you where showing up to Qualcomm-Atheros, they where making the following press statement:
"By pairing the QCA9880 802.11ac radio with the QCA9558 802.11n SoC, networking OEMs can build cost-effective
and power-efficient 802.11ac-enabled products that are capable of aggregate PHY rates of up to 1.7 Gbps."
How can this be paired?
As I understand it right now, MikroTik was inserting the "QCA9558 802.11n SoC" inside of the RB953GS-5HnT
and if we find a mini PCIe wifi card with the QCA9880 802.11ac chip set we will able to get 1.7 GBit/s throughput?
Or do I miss understanding something? And the RB953GS-5HnT is also capable to hold 3G/UMTS modems
also with GPS support? I mean can the GPS signal be used by MikroTik clients?
Kindly regards
Kreacher ♬
Karma points must not be paid by you
helectro
Fri Sep 27, 2013 5:25 am
Well done MikroTik!
RB953GS-5HnT From Tower Fm is Great use SFP instead of UTP
I will change many 433ah from my backbone if your processor is more faster
CCR1009 =looks great
mAP= looks great to sell with of service
QRT G= want But 5GHz maybe 23 dBi or More
richinuk
Fri Sep 27, 2013 9:23 pm
Yes, absolutely - I took that viewpoint too. Similar in concept to UBNT's AirGateway, running a full RouterOS.
My question was what do we do with the ESD from the outdoor antenna (e.g.: SXT)? It looks like there's metal ethernet jacks on the mAP which means we can ground the external device into the mAP using metal ethernet connectors and ethernet cable with a drain wire - nice and simple! My question is whether the mAP has a grounding mechanism to discharge the static (eg: mains earthing)?
Also would like to join the collective in saying well done MikroTik for these new products! I really like the whole range of integrated radio devices.
Rich
Kreacher
Fri Sep 27, 2013 10:12 pm
@richinuk
Ah ok I see I was miss understanding it!
Kindly regards
Kreacher ♬
normis
Fri Sep 27, 2013 10:42 pm
Yes, but this pairing is with a chip that RB953 doesn't use. So it doesn't apply to this product.
unable to confirm this right now
it has so many ports, that you can use it for different purposes. SFP could be used to go up the tower for long distances. or can be used indoors like a router. It will have multiple wlan interfaces, so CPE/AP/Sector is also possible. Depends on what you need - it can do it all.
Kreacher
Fri Sep 27, 2013 10:48 pm
@normis
Thanks for more details.
Great to from you, I´ll take one for testing it out!
Kindly regards
Kreacher ♬
infused
Sat Sep 28, 2013 3:54 pm
So when is the CRS (originally scheduled for May) going to be hitting the shelves :)
SamWCL
Sun Sep 29, 2013 7:34 am
Does anyone have the files for
"Building Effective Firewalls with MikroTik"
Downloads:
• APNIC Reserved IP Addresses.rsc
• Block by Country Worksheet.xlsx
• Block_Country_By_Subnet_Example.rsc
• L7_Pattern_Matcher_from_MikroTik.rsc
• RWF_Firewall_3.0.rsc
Cheers
GlueGuy
Sat Mar 01, 2014 1:30 am
A couple questions about the QRT.
  • Does it have 1 or 2 ethernet ports?
  • If 2, does the 2nd port provide passive POE?
bp
Users browsing this forum: No registered users and 74 guests
