spotts78
Metarouter move to another host
Fri Sep 20, 2013 11:46 pm
I started experimenting with metarouter on a RB450G running ROS 6.2, very cool stuff. If I build a MR running ROS or even openwrt how would I move it to another host or even backup the metarouter? I don't see anything under the Files menu and don't see an option to backup/export the metarouter VM.
janisk
Re: Metarouter move to another host
Mon Sep 23, 2013 8:34 am
there is no way on how to save metarouter explicitly, but this has to be done in steps:
for RouterOS:
save on host
a) /metarouter export
b) /interface virtual-ethernet export
on ROS guest:
c)/export (for all guests separately)
to restore do the same in reverse order and yo should restore the configuration
for non-rotuerOS guests
for non-RouterOS guest:
save relevant configuration of guest
to restore - create guests by importing relevant images and restore configuration.
It is not possible to export whole guest.
Users browsing this forum: No registered users and 4 guests
