MUM Europe 2020
gorkems
i cant connect different subnet help !!!
Sat Sep 21, 2013 10:24 pm
i use cloud core router and and i have 3 hotspot out ethernet port . these are briged to one hotspot server profile
1. nanobridge hotspot output to my bachhoul
2. my airview server ( binding and bypassed) static ip
3. radius server ( binding and bypassed) static ip
my ubnt diveces are behind 1. port and the devices ip adress is 192.168.1.x
so i want to connect them from 2. port . how i do that easly
thanks for ypur helps
i wait your replys
Ivoshiee
Re: i cant connect different subnet help !!!
Sun Sep 22, 2013 3:52 pm
If your CCR ports are bridged then you can move your other equipment around these ports with not much effort - just plug it into another port.
gorkems
Sun Sep 22, 2013 9:45 pm
i distribute the internet in that port, so i cant move to another port to manage .
Ivoshiee
Sun Sep 22, 2013 10:25 pm
Paint some schematics - your CCR has plenty of lan ports to choose from.
gorkems
Tue Sep 24, 2013 7:54 pm
i solved when i disabled use ip firewall in bridge settings everything fine but i click to enable connections is broken .... why is that ...
Users browsing this forum: antonioiezzi, kazso, MSN [Bot], nescafe2002, Znevna and 159 guests
