itmtech
Limitations problem with User Manager!
Mon Sep 23, 2013 9:56 pm
i have a problem with the limitations in the user manager.
A customer that have a limitation to 17mbp/s only gets 11mbp/s maximum.
If i remove all the limitations it works well and gives him 40mbp/s.
Changing the limitation to 6mbp/s and he only gets 3 or 4mbp/s.
This is a paste from the user manager for that Client.
Rate limit: 1048576/20971520 2097152/26214400 524288/17825792 20/20 1 524288/524288
Does anyone know what seems to be the problem here?
Thanks in advance.
itmtech
Re: Limitations problem with User Manager!
Tue Sep 24, 2013 7:37 pm
rate limit 1048576/20971520
burst 2097152/26214400
threshold 524288/17825792
burst time 20/20
priority 1
minimum 524288/524288
it is simple bridged network with PPPOE and usermanager. Ideas?
Blindschleiche
Tue Sep 24, 2013 8:39 pm
try
/queue type set default-small kind=sfq
on the Router with the PPPoE-Server
itmtech
Sun Sep 29, 2013 1:01 pm
IT WORKS!!
I have no idea what I've done but it works. :D
Can you please explain me what I've just done? Maybe there would be some side effects?
Thank you.
itmtech
IT WORKS!!
Thank you.
deejayq
Sun Sep 29, 2013 9:17 pm
i think Blindschleiche suggested you use sfq for default-small type of queues instead of pfifo.
Never worked with pppoe server, but i think the default queue type it uses for the clients it's default-small.
I think the problems when using sfq is when you have more than 1024 clients.
rextended
Fri Mar 28, 2014 7:24 pm
try
share info is good!
+2
I'm Italian, not English. Sorry for my imperfect grammar.
skillful
Trainer
Trainer
Wed Sep 24, 2014 7:21 pm
IT WORKS!!
Thank you.
Please see http://forum.mikrotik.com/viewtopic.php?f=7&t=83477 for some explaination
Users browsing this forum: john231, MaxFrei, mbovenka, sirnef and 52 guests
