MUM Europe 2020
XTX
CCR 1009
Fri Sep 27, 2013 3:40 pm
Hi
If it's not a highly classified data... :)
Could someone from MT give a little more info on the CCR 1009 ?
What version of the Tile GX 8009 is used ? 10C, 10CE, 12C, 12 CE ?
How much RAM will be onboard ?
When approximately will it be launched ? (in Q's is fine :)
Will it be cheaper or more expensive than let's say CCR 1016 ?
THX
AlArenal
Re: CCR 1009
Fri Sep 27, 2013 4:24 pm
Why should it be more expensive with less power!? Is your car getting cheaper when you buy it with a bigger engine?
XTX
Re: CCR 1009
Fri Sep 27, 2013 4:52 pm
hmmm...while it's true that 1009 has a "smaller" CPU...it has one SFP and one SFP+ port (and thus 10G option)
So that's why I'm asking where it will be positioned price-wise
PS: and don't get me started with your car comparison... :)
Kreacher
Re: CCR 1009
Mon Sep 30, 2013 2:52 pm
+ 1 for which CPU is used
+ 1 for how many RAM
+ 1 for the Qs, but please followed by the year please!
And perhaps on top a prize range, where this device will be pointed in.
Hopefully they have taken the CPU variant with the high speed encryption engine called MiCA
and up to a maximum of 8 GB or 16 GB ECC RAM would be fine!
Together with the RG953GS-5HnT as an wifi AP it would be a really fine set up for my home network I think.
Kindly regards
Kreacher ♬
Karma points must not be paid by you
normis
Re: CCR 1009
Mon Sep 30, 2013 3:49 pm
2GB RAM soldered
Q4/2013
Kreacher
Re: CCR 1009
Mon Sep 30, 2013 3:56 pm
2GB RAM soldered
Q4/2013
Thanks for jumping in and sharing some more detailed and precise technical specs and informations
about the CCR1009 and on top the quarter + the year!
Kindly regards
Kreacher ♬
AlArenal
Re: CCR 1009
Mon Sep 30, 2013 4:07 pm
So it's pretty much the more powerful / more flexible successor to the 1100 series.
Looks good to me! I had hoped for 4 GB RAM, but of course MT has to take care not to cannibalize its own market for the higher grade models.
normis
Re: CCR 1009
Mon Sep 30, 2013 4:12 pm
CPU: 10CE
Kreacher
Re: CCR 1009
Mon Sep 30, 2013 4:30 pm
CPU: 10CE
Wooohoo, also it comes with the MiCA engine!
+1 from me there fore
Good work and well done MikroTik!
Kindly regards
Kreacher ♬
XTX
Re: CCR 1009
Mon Sep 30, 2013 5:53 pm
Thank you very much for the info, Normis ! :)
honzam
Re: CCR 1009
Mon Sep 30, 2013 10:11 pm
LAN, FTTx, Wireless. ISP operator
normis
Re: CCR 1009
Tue Oct 01, 2013 8:56 am
Yes TLR4-00980CG-10CE
ofca
Re: CCR 1009
Wed Oct 02, 2013 10:00 am
It's Q4 since yesterday - where's the 1009? :D
Hopefully I'll live until times in which CCR with 2 SFP+ and 24 SFP becomes available :) (I can also live with 4 SFP+ and 16 SFP :>)
AlArenal
Re: CCR 1009
Wed Oct 02, 2013 10:57 am
@ofca:
What would you do with that many ports on a router!?
ofca
Re: CCR 1009
Wed Oct 02, 2013 10:59 am
Connect business end-users to MPLS cloud and remove switches and vlans from the network.
onnoossendrijver
Re: CCR 1009
Wed Oct 02, 2013 11:19 am
If Mikrotik adds 6RD support I will buy one for at home without any hesitation :)
Linux/network engineer: ITIL, LPI1, CCNA R+S, CCNP R+S, JNCIA, JNCIS-SEC
Kreacher
Re: CCR 1009
Wed Oct 02, 2013 4:21 pm
@ofca:
Nobody is asking you if you will buy a router with 4 LAN Ports and a Switch with 10 Ports like the
combination I have many times seen, (like this here):
- Netgear FVS336Gv2
- Netgear GS110T
All is even fine and no one asks for this set up, but if we will buy a MikroTik CCR-1009 router for home usage
and this router comes with 10 LAN Ports, the whole world wants to know why? So what is so special on this
router? Only one device, much power , enough ports, ROS inside and hopefully in the near future all is running
smooth with the ROS version on Tilera´s Tile Gx, but if we buy a no one is accepting this in see more and more.
Kindly regards
Kreacher ♬
AlArenal
Re: CCR 1009
Wed Oct 02, 2013 5:52 pm
For an ISP it doesn't make much sense to use a core router for switching. You rather keep the task for each device as specific as possible and use systems for what they're best at. The more tasks you offload on a single device the more probable side effects become and of course they make bug tracking a lot more complex as e.g. you can't just replace switches without also having to change a significant part of your CCR's config.
ofca
Re: CCR 1009
Thu Oct 03, 2013 2:45 am
I don't need switches in backbone. I'm fine with wirespeed forwarding of MPLS traffic by CCR. To make this happen all I need is a device with sufficient number of SFP ports for customers and SFP+ ports for backbone ring.
NathanA
Forum Veteran
Forum Veteran
Re: CCR 1009
Thu Oct 03, 2013 5:15 pm
I could be wrong, but given the 9-core CPU, I'm guessing that MikroTik is planning to position this price-wise to replace the one remaining RB1000-series PPC router that they still sell: the RB1100AHx2. If I'm correct, I just have one request for MikroTik:
Please don't.
At the very least, please don't discontinue the RB1100AHx2 until after you have a working MetaROUTER implementation on the Tile CPU architecture. (Once that happens and you have a CCR w/ Tile CPU priced between $300-400 USD, then feel free to discontinue it at that point. :) )
-- Nathan
mrz
Re: CCR 1009
Thu Oct 03, 2013 5:43 pm
Metarouter is not supported on RB1100AHx2, too.
djdrastic
Re: CCR 1009
Thu Oct 03, 2013 5:45 pm
Speaking of discontinuing the 1000 range . Do the CCR's have IPSEC acceleration now ?
Been ages since I've worked on a CCR . Gonna be a tough sell for me if they don't as most of our endpoints require encryption.
Kreacher
Re: CCR 1009
Thu Oct 03, 2013 7:41 pm
Perhaps you are right but in any way I think it is not the best option or way for them.
But if I see they have hired 20 employees in 1 year, I really think Mr. Tully got some grey hair!
For sure it must also be able to handle the whole works load for the Mikrotik employees and there for
I think some RBs will be discontinued in the near future, but trust my word I really think it is the false way
for MikroTik to do so. I would love to see rich assortment of many different routers for any kind of purposes.
RB433 series, RB435G, RB450G, RB493G, RB800, RB1200, RB1100AHx2
RB2011 series, RB2012 series, RB2013 series,...... :D
CCR series 9 Core, 16 Core, 36 Core, 72 Core, 100 Core with modules and on each module is a 36 Core,..... :lol:
CCR traffic shapers, CCR queue only handlers, CCR like the Handlink ISS7000
So you will have a entry level, a mid ranged level and a professional Level of products and for many different kind
of needs and also budgets! Ok this is only my poor opinion.
Kindly regards
Kreacher ♬
NathanA
Forum Veteran
Forum Veteran
Re: CCR 1009
Fri Oct 04, 2013 12:10 am
It may not be "supported", but it is possible; with Tile it isn't even possible since no MetaROUTER code has ever been written for it.
I will be posting instructions on how to enable MetaROUTER on the (A)Hx2 later today to the Virtualization forum.
-- Nathan
yoshioka
Re: CCR 1009
Thu Nov 07, 2013 12:28 pm
does anyone know how large will the main board for CCR1009 will be?
is it larger then ccr2011?
normis
Re: CCR 1009
Fri Nov 08, 2013 9:56 am
Board is similar in size to the CRS (see picture in another topic), but bigger than RB2011. The estimated release date is still within Q4 as promised.
onnoossendrijver
Re: CCR 1009
Fri Nov 08, 2013 4:16 pm
Will there be a CRS desktop-sized case (or smaller) for the CCR1009?
JanezFord
Re: CCR 1009
Sat Nov 09, 2013 10:45 am
And maybe fanless?
rzirzi
Re: CCR 1009
Wed Nov 13, 2013 9:20 am
And maybe fanless?
That are mostly expected "features": desktop-size case and fanless board.
MikroTik team could You answer taht questions please?
honzam
Re: CCR 1009
Wed Nov 13, 2013 3:47 pm
I have the same question. It is fanless?
normis
Re: CCR 1009
Thu Nov 14, 2013 11:09 am
You can actually see the CCR1009 in our MUM presentation:
http://www.mikrotik.com/download/share/us13.pdf
As you see, it is a rackmountable device. Even if it has less cores, it is still a massive performance CCR series device, and it will require active cooling. Those CPUs are very powerful and they do emit a certain amount of heat.
CCR1009 should not be confused with a small RB450G replacement.
rzirzi
Re: CCR 1009
Thu Nov 14, 2013 11:38 am
Thank You Normis.
So - are You planning to introduce any RG 450G with all strong points of that board?: Small case, five Ethernet ports, DC-jakc and PoE, voltage monitor. We need ALL of them, but faster CPU.
normis
Re: CCR 1009
Thu Nov 14, 2013 11:47 am
Thank You Normis.
Yes, we are working on something like that. No more info.
rzirzi
Re: CCR 1009
Sun Nov 17, 2013 9:55 pm
It's 4th quarter 2013r. Is there any pending date of release CCR1009?
rzirzi
Re: CCR 1009
Tue Nov 19, 2013 5:33 pm
WHEN? WHEN? WHEN?
It will be available (CCR1009) at distributors?
Borage
Re: CCR 1009
Wed Nov 20, 2013 1:53 am
My guess is december 2013. :)
rzirzi
Re: CCR 1009
Wed Nov 27, 2013 11:02 pm
MikroTik Team - any news about availability of this product (CCR1009)???
KoDAk
Re: CCR 1009
Mon Dec 02, 2013 9:28 pm
YES we all NEED -> CCR 1009 <-
it will be first CCR that most people can buy !
and it be definitely most popular model of all CCR (i think so)
Certified MTCNA
honzam
Re: CCR 1009
Mon Dec 16, 2013 4:38 pm
Still it is true that promise?
rzirzi
Re: CCR 1009
Tue Dec 17, 2013 9:24 am
I think if that is no answer - there is nothing to confirm.
Next answer from MikroTik will be that "it will be available at first quarter of 2014" or ..... no answer.
rzirzi
Re: CCR 1009
Mon Dec 23, 2013 11:44 am
So, as I written...
No answer from MT team - mean that You should NOT expect it (CCR1009) at this Year.
Maybe......first quarter of 2014 ;) or maybe...
rzirzi
Re: CCR 1009
Tue Dec 31, 2013 10:31 am
Today is last day of Q4 2013.
Maybe I have missuderstand Your answer...
So we have to wait to Q4 2014 Year ?? ;) ... for CCR1009
KoDAk
Re: CCR 1009
Thu Jan 02, 2014 11:00 am
is so so sad(
because even after the announcement, it take at least another month product availability in the local market (
Certified MTCNA
chris6671980309
Re: CCR 1009
Mon Jan 06, 2014 10:21 am
Possible date will be end of march in Singapore after equipment has been certified by IDA. :cry:
KoDAk
Re: CCR 1009
Mon Jan 13, 2014 8:44 pm
it is not good so long wait (
Certified MTCNA
rzirzi
Re: CCR 1009
Wed Jan 22, 2014 9:53 pm
Dear MikroTik Team. Is there any chance to buy it (CCR1009) at first quarter of this Year (2014)?
rzirzi
Re: CCR 1009
Tue Jan 28, 2014 9:51 am
KoDAk
Re: CCR 1009
Tue Jan 28, 2014 11:23 pm
WE ALL want BAY CCR1009 but tired wait
you announce it in last quarter in 2013 !!!!!
and we disappointed that we don't see it on routerboard.com not saying see it on local sale !
Certified MTCNA
rzirzi
Re: CCR 1009
Sun Feb 02, 2014 9:46 pm
MikroTik Team - coul You answer the question please: WHEN it will be available:CCR1009 ???
normis
Re: CCR 1009
Mon Feb 03, 2014 9:33 am
We have a large MikroTik event coming up, so expect all news to happen there ;)
lunchboxrts
Re: CCR 1009
Thu Feb 13, 2014 8:43 am
So your going to re-announce the ccr1009?
normis
Re: CCR 1009
Thu Feb 13, 2014 8:48 am
Among other things. This time CCR1009 is much closer to availability :)
lunchboxrts
Re: CCR 1009
Thu Feb 13, 2014 11:54 am
I really want to get my hands on one! Have any demo models?
normis
Re: CCR 1009
Thu Feb 13, 2014 12:09 pm
Yes we plan to bring some demo devices.
lunchboxrts
Re: CCR 1009
Fri Feb 14, 2014 1:22 pm
I can't make mum this is our busy time now that its warming up here. Lots of installs. We could beta test one in a real world environment for you :D
letter
Re: CCR 1009
Mon Feb 24, 2014 8:17 pm
New date for those who haven't seen in Venice MUM 2014 thread: April...
rzirzi
Re: CCR 1009
Tue Feb 25, 2014 11:13 am
WHEN? When CCR1009 will be available??
letter
Re: CCR 1009
Tue Feb 25, 2014 5:34 pm
Again: April (according to normis' linked post)
Kreacher
Re: CCR 1009
Wed Feb 26, 2014 11:47 am
Did he (normis) told anything over the launching year?
It is not that I want to be ungentle, but on the 1th April
the most peoples inside many countries are kidding their peoples a little bit
and so I was asking my self if this could be also a small joke perhaps?
But if not the CCR1009 is very welcome, it should be the best actual
choice to set up a really powerful router for smallest, small and little
companies or power home users and a lot of peoples would be nasty
to get their hands on this product.
Kindly regards
Kreacher ♬
bSir
Re: CCR 1009
Wed Feb 26, 2014 2:45 pm
1th April !
letter
Re: CCR 1009
Wed Feb 26, 2014 6:27 pm
:lol: There wasn't mentioned a year explicitly... But one says CCR1009 will be available "very soon". I hope this means April 2014.
Did you pick up that CCR1009 will have dual power supply (see http://mum.mikrotik.com/presentations/IT14/it14.pdf)? This makes this device even more interesting.
marrold
Re: CCR 1009
Thu Feb 27, 2014 12:23 pm
This is another request for a desktop version of the CCR1009. Fanless would also be great, but not a necessity.
I'm a SIP / VoIP engineer. Feel free to ask questions...
chris6671980309
Re: CCR 1009
Tue Mar 11, 2014 8:19 am
Do CCR 1009 have hardware switch chip ?
onnoossendrijver
Re: CCR 1009
Tue Mar 11, 2014 1:19 pm
Update.. I was wrong.. See comment from normis below.
Last edited by onnoossendrijver on Tue Mar 11, 2014 2:03 pm, edited 1 time in total.
Kreacher
Re: CCR 1009
Tue Mar 11, 2014 1:52 pm
Me too! :lol:
Kindly regards
Kreacher ♬
normis
Re: CCR 1009
Tue Mar 11, 2014 1:57 pm
First 4 ports are connected to a switch chip, rest are each directly connected to CPU
blue
Re: CCR 1009
Tue Mar 11, 2014 8:34 pm
Oh how disappointing. I was hoping that all ports are connected directly to CPU, just like any other CCR...
Quindor
Re: CCR 1009
Tue Mar 11, 2014 11:29 pm
I think it's handy that some ports can be grouped together as a switch group and thus not put any load on the CPU as bridging would. It kind of depends what the switch chip would be capable of in regards to VLAN's and such, but judging from the RB2011 for instance it's at least possible to do it right. :)
It also depends how big the interlink between the switch chip and the CPU is internally, but most often this is limited to 1Gbit (a 5 port Gbit switch in reality with 4 ports external and 1 port internal). Hoping to see a block diagram soon. Actually, judging from the TILE-Gx8009 spec sheet, it has up to twelve 1000Mbit ports and/or 2 10Gbps XAUI ports + at least 10 PCIe 2.0 lanes.
Depending on configuration, it's possible that that the 4 Gigabit Ethernet ports are directly connected to the CPU, the SFP+ slot uses one of the 10Gbit XAUI ports and the internal switch is a 10Gbit internal uplink and 5x external Gigabit Ethernet ports model (including the SFP slot). This would impose no bandwith limitations if used as routed ports but would give you the advantage of being able to use them as switched ports, offloading the CPU.
Alternatively the switch or a 10Gbit port could be connected using some form of PCIe interface of which the processor also has a multitude available. Using the available 10 lanes of PCIe 2.0 bandwith that would result in 10x512MB/sec = 5120MB/sec up and down (full-duplex). More then enough to use for the switch or a 10Gbit SFP+ port, etc. That would still leave another 2 PCIe 2.0 lanes unused also the spec sheet lists that everything else such as UART, USB, etc. is separately connected.
Only time will tell, hopefully they will release a block diagram before it's purchasable so we can check out how they configured it before buying!
Personally I'm wondering what the expected NAT throughput would be. Sadly, I seem unable to find any real performance numbers for the other Cloud Routers thus I'm unable to make a guestimated number either. Does anybody have any numbers or tests on it? I'm hoping it will be able to do 1Gbps of NAT without too much trouble, making it a great router for newer fiber connections.
http://www.campzone.nl World's Largest Outdoor LANParty, http://intermit.tech Intermittend Technology blog, My blog about the ESP8266, IP Camera's and other tech related subjects!
blue
Re: CCR 1009
Wed Mar 12, 2014 8:29 am
Quindor, thanks for very technical post. It would be great if those first 4 switched ports share 10G connection. That way, if You don't want to use switch, 1000m * 4 ports will go to the cpu without bottleneck. Only time will tell, and it would be great that MTK guys post block diagram...
chris6671980309
Re: CCR 1009
Wed Mar 12, 2014 11:18 am
Can the CCR 1009 10Gbit SFP+ port accept a standard SFP module?
Do CCR 1009 has NAT acceleration?
Quindor
Re: CCR 1009
Fri Mar 14, 2014 2:41 am
Some SFP+ slots can accept SFP modules. And some SFP modules will work in an SFP+ slot and some will not. It's kind of a vague issue and it highly depends on the combination of the specific SFP+ slot and SFP module combination if it will work or not. Best is to try, electrically it should not pose a problem.
As you can read 2 posts upward, I also wonder about NAT performance. But from what I understand there is no hardware accelerated NAT above that the processor is able to process. There is no NAT block in the processor like there is a separate encryption block inside of it. Still, if there is a multi-threaded NAT engine performance should be excellent because of the 9 cores.
Vanta
Re: CCR 1009
Mon Mar 24, 2014 4:36 pm
normis
It will have dual PSU or not?
+1 for Dual PSU.
Quindor
Re: CCR 1009
Mon Mar 24, 2014 4:54 pm
normis
+1 for Dual PSU.
From all the available information available, it is going to have a dual PSU. Also see http://download2.mikrotik.com/news55.pdf page 4 to see the "Dual PSU" listed.
lunchboxrts
Re: CCR 1009
Wed Apr 02, 2014 3:26 am
Well it's April, any more news on availability?
rzirzi
Re: CCR 1009
Wed Apr 02, 2014 4:12 pm
We all want to know...is there any chance to buy it at april...?
ronniee
Re: CCR 1009
Sun Apr 13, 2014 5:50 pm
The CCR1009 doesn't appear in Mikrotik Product Catalog 2014 Q2 :(
But in January u sad: "CCR1009 will be available around end of the first or beginning of the second quarter."
Will be launched on Q2 or not?
I hope the price will be around uby edge router pro(2GB DDR3, 4GB NAND)340$.
bds1904
Re: CCR 1009
Mon Apr 14, 2014 12:38 am
Don't get me wrong, I like mikrotik and routerboard products a lot and they have great support.
That being said releasing products "on time" isn't one of their strong suits. If they say Q1 2014 first, expect second half of Q2 or Q3. Getting hardware from design to 1st concept to engineering approval to production to production approval, then inventory and distribution takes a lot. Sometimes the process gets delayed for some time because of waiting on thing like enclosures, raw board production or working out bugs in the assembly process. It happens.
normis
Re: CCR 1009
Mon Apr 14, 2014 9:51 am
you can ask your distributor tomorrow ;-)
nz_monkey
Re: CCR 1009
Mon Apr 14, 2014 11:37 am
I love the subtlety :)
http://thebrotherswisp.com/ | Mikrotik MTCNA, MTCRE, MTCINE | Fortinet FTCNA, FCNSP, FCT | Extreme Networks ENA
KoDAk
Re: CCR 1009
Tue Apr 15, 2014 11:50 pm
and be send for some next month (
and STILL NO 1009 on routerboard.com (((
Certified MTCNA
honzam
Re: CCR 1009
Wed Apr 16, 2014 9:43 am
Our supplier says: 30.4.2014
lunchboxrts
Re: CCR 1009
Wed Apr 16, 2014 10:00 am
My supplier says they have no idea on release or price. Did yours give any pricing?
chris6671980309
Re: CCR 1009
Wed Apr 16, 2014 10:27 am
My supplier stop replying after ask for the price of both models for end-user.
onnoossendrijver
Re: CCR 1009
Wed Apr 16, 2014 10:32 am
2x IEC C14 power jacks AC 110/220V, PoE
in 12-58V, 802.3af/at compliant
Cool! What about redundancy? Can you connect both IEC and PoE and have them failover?
I saw some prices online: 350-400 euro.
normis
Re: CCR 1009
Wed Apr 16, 2014 10:34 am
It's in the brochure:
honzam
Re: CCR 1009
Wed Apr 16, 2014 10:40 am
CCR1009-8G-1S-1S+ = 272,13 € netto
CCR1009-8G-1S = 238,68 € netto
onnoossendrijver
Re: CCR 1009
Wed Apr 16, 2014 11:54 am
It says nothing about PoE as backup.
normis
Re: CCR 1009
Wed Apr 16, 2014 12:03 pm
Sorry didn't understand what you meant. You want 3 power sources? Yes, it's possible, but you need to use less than 24V for PoE. 22V or something like that. PoE and PSU can't have equal voltage, and PSU gives 24V
onnoossendrijver
Re: CCR 1009
Wed Apr 16, 2014 12:16 pm
That's great! I'd like to use 48v PoE and 1 or 2 IEC connections. Will PoE then be the primary source for power and IEC the backup?
Zorro
Long time Member
Long time Member
Re: CCR 1009
Wed Apr 16, 2014 3:05 pm
any further info about switch chip, used for first four ports ? so we're can dig datasheets and understand possible caps/performance.
is any chance to get model without SFP cage(one 10Gb copper port instead will be welcomed, howver), single-powered and probably with dedicated PHY's at all ports(ie w/o swtich chip)?
ie as low-cost, high-thoughput premises CPE for SOHO deployment. ie to fit between rb850gx2 and initial 1009 model in terms of feats/cost and probably, size(no rackmountability meaning for premises in 80% cases)>
janisk
Re: CCR 1009
Wed Apr 16, 2014 3:18 pm
highest voltage source will be primary
chris6671980309
Re: CCR 1009
Fri Apr 18, 2014 5:12 pm
1Gb/sec NAT is it possible for 1009?
lunchboxrts
Re: CCR 1009
Fri Apr 18, 2014 11:21 pm
I would hope, the 1100AHx2 can
chris6671980309
Re: CCR 1009
Tue Apr 22, 2014 6:57 am
Just place an order for Cloud Core Router 1009-8G-1S-1S+. :) 699SGD. Will arrive in 1st week of May 2014.
lunchboxrts
Re: CCR 1009
Tue Apr 22, 2014 9:42 am
balticnetworks.com says:
Thank you for your inquiry! The CCR1009 is expected to arrive around the 2nd half of May, and I would be happy to place a pre-order for you once we have activated the product for ordering. Please let me know if you have any questions or if I can be of further assistance.
ispsupplies.com says:
We are ordering them on our next shipment so we should have them in roughly 2-4 weeks. The list price for the devices are $425.00 for the CCR1009-8G-1S and $495.00 for the CCR1009-8G-1S-1S+.
honzam
Re: CCR 1009
Wed Apr 23, 2014 12:41 pm
Markvlie
Re: CCR 1009
Fri Apr 25, 2014 12:26 pm
Is there any information yet on performance? I'm considering buying either 1100AHx2 or CCR1009 but im not sure which one would be best for my situation: 500/500M Fiber internet with PPPoE/NAT for 1 VLAN. LAN connections to 3 switches / 2 servers directly. I think both could do this but which one would have "the most" to spare?
Quindor
Re: CCR 1009
Fri Apr 25, 2014 9:31 pm
I know these posts aren't always seen as positive....but..... I have ordered a CCR1009-8G-1S-1S+ and fedEX reports they should drop it of coming Monday! :D
When it gets here I will open a topic so people can ask questions, get photo's, etc.
lunchboxrts
Re: CCR 1009
Fri Apr 25, 2014 10:57 pm
keep us posted!
jrees5625
Re: CCR 1009
Sun Apr 27, 2014 7:56 pm
Does anybody know if the CCR 1009 will use same version of ROS (Tile v6.12) that is currently on the RouterOS website and is running on other CCR routers? Or, will they be releasing a new version that supports the CCR 1009 hardware? Thanks!
janisk
Re: CCR 1009
Mon Apr 28, 2014 9:15 am
Does anybody know if the CCR 1009 will use same version of ROS (Tile v6.12) that is currently on the RouterOS website and is running on other CCR routers? Or, will they are releasing a new version that supports the CCR 1009 hardware? Thanks!
it will run same Tile packages that are available on our download page. However, to actually have 6.12 you will need to upgrade it.
Quindor
Re: CCR 1009
Mon Apr 28, 2014 11:46 pm
Anyone looking for more information. I received mine and have made a special topic for it with information and some tests!
http://forum.mikrotik.com/viewtopic.php?f=3&t=84475
KoDAk
Re: CCR 1009
Sun May 25, 2014 11:00 pm
i change RB2011iLS-IN to CCR1009-8G-1S
I visually see the difference in speed of opening each page in browser and folders on FTP!
Amazing!!!
Speed on the brink of possibilities!
p.s.
it be cool see RB2011UiAS-2HnD-IN with some 3-core's version of TLR4-00980CG-10CE !!!!!!!!!!!!!!
Certified MTCNA
Users browsing this forum: No registered users and 15 guests
