MUM Europe 2020
trottolino1970
I can install dude on 951?
Sat Sep 28, 2013 12:47 pm
Hello to all, my question is: i can install the dude on rb951 with 128 of ram?
nawshad
Trainer
Trainer
Re: I can install dude on 951?
Sat Sep 28, 2013 1:03 pm
yes, you can install dude on router os
Nawshad Ahmed
MikroTik Certified Trainer & Consultant
MTCINE,MTCRE,MTCNA,MTCTCE,MTCWE,MTCUME
Cell:+17812610808
Massachusetts, U.S.A
Skype:ahmednawshad
trottolino1970
Sat Sep 28, 2013 1:05 pm
yes, you can install dude on 951.
where i can download it?
nawshad
Trainer
Trainer
Sat Sep 28, 2013 1:14 pm
it is better if you run dude server on windows.
Nawshad Ahmed
Cell:+17812610808
Skype:ahmednawshad
nawshad
Trainer
Trainer
Sat Sep 28, 2013 1:15 pm
i didn't find dude server for 900 series
Nawshad Ahmed
Cell:+17812610808
Skype:ahmednawshad
trottolino1970
Sat Sep 28, 2013 1:26 pm
there isn't the versione for this rb :(
ohara
Sat Sep 28, 2013 8:10 pm
You can install the MIPS-BE version on each MIPS-BE routerboard:
http://download.mikrotik.com/dude/4.0be ... mipsbe.npk
trottolino1970
Sat Sep 28, 2013 8:16 pm
i try it thnks ;)
ohara
Sat Sep 28, 2013 9:01 pm
trottolino1970,
you're welcome. assuming that you have a usb port in your router, you can use a usb pendrive to store dude settings (SYSTEM>STORES)
let us know how it works out for you.
trottolino1970
Sun Sep 29, 2013 8:20 am
trottolino1970,
wonderfull idea, i try in the next day
trottolino1970
Tue Oct 01, 2013 12:18 pm
ok, i instal it but how i can configure?
trottolino1970
Fri Oct 04, 2013 12:37 pm
hello to all.
i install it but my rb go reboot every time :(
ohara
Sat Oct 05, 2013 1:09 am
Hi, you're probably need to send it back to the distributor. The routerboad and Dude work fine as long as you don't reboot it. After reboot it goes into a infinite restart loop. Unfortunately I have experienced the same with a 951G last week and 6.15rc. I have flagged this post as a bug report to MT Tech Support.
trottolino1970
Sat Oct 05, 2013 1:20 am
yes i know that dude and mk work fine but as you experience no in 951, loop reboot.
thanks for the reply and have you a beautiful day ;)
ohara
Sat Oct 05, 2013 1:23 am
Ok, I'll call it a beatiful day once the RB will be replaced. By the way which ROS version did you use on your 951?
trottolino1970
Re: R: I can install dude on 951?
Sat Oct 05, 2013 1:46 am
6.4
Inviato dal mio GT-I8190N con Tapatalk 2
Modarresi1984
Sun May 01, 2016 12:26 pm
Hi to all
we are in 2016 , and my rb951 version now is 6.35.
pleas help me to now, which version must download from download page.
trottolino1970
Sun May 01, 2016 12:51 pm
You cannot install the dude on it
Inviato dal mio SM-G361F utilizzando Tapatalk
Users browsing this forum: No registered users and 14 guests
