MUM Europe 2020
mbethers
ChangeIP
Tue Oct 01, 2013 9:47 pm
Anyone else have any luck with their ChangeIP scripts since the website changeover?
nawshad
Trainer
Trainer
Re: ChangeIP
Tue Oct 01, 2013 10:16 pm
what is that mean?
Nawshad Ahmed
MikroTik Certified Trainer & Consultant
MTCINE,MTCRE,MTCNA,MTCTCE,MTCWE,MTCUME
Cell:+17812610808
Massachusetts, U.S.A
Skype:ahmednawshad
nickblame
Re: ChangeIP
Wed Oct 02, 2013 10:03 am
I've got problems too. Script reports Authentication Failure
StNick
Re: ChangeIP
Wed Oct 02, 2013 10:18 am
Same problem here.
ChangeIP is a Dynamic DNS provider. There is a script available herewhich allows us to update our DNS via RouterOS.
However, at the end of September, ChangeIP did a massive upgrade of their systems, and it appears to have broken the script.
Log reports "Authentication Failure", but I know that my username and password are correct (I can log in on their frontend with these credentials).
anaktos
Re: ChangeIP
Wed Oct 02, 2013 3:58 pm
I've got problems too. :?
The script reports "Authentication Failure", however on the website (changeip.com) I can logon using the same credentials.
______
MTCNA
EtienneO
Re: ChangeIP
Wed Oct 02, 2013 4:50 pm
Reply on a ticket I submitted.
We have identified a problem that is affecting use of updates via devices and scripts. A fix is being implemented and should be in place within the next 24 hours. In the meantime, manual updates via DNS Manager are working. Thank you for your patience.
anaktos
Re: ChangeIP
Wed Oct 02, 2013 5:35 pm
I opened a ticket on "changeip.com" and they told me the following
We have identified a problem that is affecting use of updates via devices and scripts. A fix is being implemented and should be in place within the next 24 hours. Thank you for your patience.
Thank you,
ChangeIP Support
______
MTCNA
385esantic
Re: ChangeIP
Wed Oct 02, 2013 9:45 pm
Same problem here "Authentication Failure"
using "homing Beacon" script
orgtopus
Re: ChangeIP
Thu Oct 03, 2013 4:06 am
Thank you,
ChangeIP Support
me too.
archosiris
Re: ChangeIP
Thu Oct 03, 2013 5:44 am
any updates for the script guys? my previous site that using the changeip script got no problem, still can be use for remote but there's an error msg on log ----> http://i.imgur.com/bWnUyHF.png. But apparently, we will got a problem to setup the script on a new site.
zohaib
Re: ChangeIP
Thu Oct 03, 2013 4:03 pm
any update i m also facing similar issue
anaktos
Re: ChangeIP
Thu Oct 03, 2013 7:25 pm
already solved.
it works again!
______
MTCNA
zohaib
Re: ChangeIP
Thu Oct 03, 2013 11:53 pm
already solved.
it works again!
thanks
orgtopus
Re: ChangeIP
Fri Oct 04, 2013 6:34 am
already solved.
it works again!
thanks
zohaib
Re: ChangeIP
Fri Oct 04, 2013 1:10 pm
again authentication failure error
EtienneO
Re: ChangeIP
Fri Oct 04, 2013 1:20 pm
I just reset my ChangeIP password now and it started working again. My details weren't working for the site anymore either though.
zohaib
Re: ChangeIP
Fri Oct 04, 2013 5:23 pm
yes you are right
and one thing is that my change ip password not works then i reset my password
and script working now
thanks
Users browsing this forum: gammy69er, MSN [Bot] and 42 guests
