arxont
Mikrotik SSH Backup - my solution
Wed Oct 09, 2013 4:42 pm
Hello All! I am created mini-tools for Mikrotik configuration backup over SSH.
One function - Backup and sending e-mail on failure. The program is written. NET.
Can run with a key "Backup" (command line, sample "MikrotikSSHBackup.exe Backup") for background backup.
Download - https://dl.dropboxusercontent.com/u/101 ... Backup.zip
GitHub - https://github.com/psionika/MikrotikSSHBackup
It will be good if somebody come in handy :)
rickfrey
Trainer
Trainer
Re: Mikrotik SSH Backup - my solution
Mon Feb 17, 2014 8:09 am
Very nice! Thank you!
docmarius
Wed Feb 19, 2014 9:21 am
Nice tool, thank you.
Just a small bug: If regional settings on the host computer include forward slash, the path of the backup file can not be created, since Windows doesn't allow slash in file names.
e.g. Date setting MM/dd/yyy will try to create invalid file name "rb450, IP 192.168.1.1 02/19/2014 09-15-09.txt" and give an error message.
while yyy-MM-dd will create "rb450, IP 192.168.1.1 2014-02-19 09-15-09.txt" which is OK.
Creating/parsing your own date string is needed for portability.
arxont
Wed Feb 19, 2014 3:34 pm
FIXED: Changed in the file creation date to the substitution
DateTime.Now.ToString(CultureInfo.InvariantCulture)
                             .Replace(@"/", "-")
                             .Replace(":", "-")+".txt"
That cleared up the problem with the creation of files with different regional settings.
ADD: Editing by double-clicking on the row
ADD:
Close settings and add/edit forms after press ESC
ADD:
Added progressbar when working backup through the form
Download: https://dl.dropboxusercontent.com/u/101 ... Backup.zip
rickfrey
Trainer
Trainer
Wed Feb 19, 2014 5:41 pm
I've only been able to play with this a little, but so I love it. Thank you for putting this together! :D
docmarius
Wed Feb 19, 2014 6:39 pm
Thank you for the fix. This is a really nice tool.
The only thing it is missing is a restore button :lol:
ditonet
Forum Veteran
Forum Veteran
Thu Feb 20, 2014 12:17 am
Nice tool, thanks.
I have a feature request:
1. add ability to define port used by SSH service, currently is fixed to 22. I always use non-standard port for SSH to prevent automated port scanning.
2. some kind of credentials encryption in 'data.xml' and 'settings.xml' files. Maybe I'm slightly paranoic :)
Best regards,
rickfrey
Trainer
Trainer
Thu Feb 20, 2014 5:07 am
Once you enter the world of routing & switching, you can't help but become paranoid :shock: :D
arxont
Thu Feb 20, 2014 3:15 pm
  • ADD: SSH port parameter
  • ADD: Create context menu (add, copy, edit, delete)
  • ADD: Add to context menu - "Connect over winbox" (connect if the ssh user has rights to connect and winbox.exe located in the same folder as the program)
  • ADD: remove color and stateBackup after press :"Start Button".
  • ADD: Encrypt data.xml (for command run "MikrotikSSHBackup.exe Backup YourPassword")
  • CHANGE: Move email settings to data.xml (for Encrypt)
  • CHANGE: Remove ProgressBarForm and add progressbar in statusstrip
  • FIXED: Tab key order in AddEdit Forms
rickfrey
Trainer
Trainer
Thu Feb 20, 2014 5:01 pm
arxont, I am really very impressed with this program and with you improvements you have made with it. Thank you! Can you explain how do this:
boen_robot
Thu Feb 20, 2014 6:28 pm
Nice.
@arxont
GitHub have this thing known as releases. Consider putting the binaries there... and maybe tag some versions?
nbctcp
Wed Sep 24, 2014 4:10 am
Thank you for your nice tool.
If possible could you please add box to set time to launch backup
nbctcp
Wed Sep 24, 2014 4:12 am
Nice tool
I have request if possible to put time box, so that I can set the time when a backup script would run
tq
arxont
Sun Oct 26, 2014 5:13 am
Nice tool
tq
Hello. No this functional.
Use standart windows Task Scheduler (or other realizations - xStarter, nnCron)
Users browsing this forum: Bing [Bot] and 7 guests
