baracudas
dns connection issue
Thu Oct 10, 2013 12:22 pm
i use 2.9.27 version and i am recentrly facing some issues.
i see cpu 100% and when i run torch, one of my wan interfaces shows too many connections from 2 specific ips and different ports to local 53 port.
After i drop input of those 2 ips, in torch i see the same behaviour.
I have disabled remote dns requests but not fixed.
here is a screenshot of torch.
Rudios
Forum Veteran
Forum Veteran
Re: dns connection issue
Thu Oct 10, 2013 2:02 pm
I think torch shows the packets because the are send to you.
It is regardless of what the firewall does with the received packages.
I assume you are being used as an DNS relay.
Post your ip firewall filter output so we can assist you in blocking unwanted traffic
Testing setup with: 2 x RB750UP | 2 x RB750GL | 1 x RB951G-2HnD | 1 x RB2011UiAS-IN
janisk
Thu Oct 10, 2013 2:10 pm
there is no reason to use such an old version. Update to newer.
baracudas
Thu Oct 10, 2013 7:04 pm
Here is ip firewall filter output.
deejayq
Fri Oct 11, 2013 6:18 pm
had a similar experience
seemed some sort of a dos
just block the two ip's and you should be fine.
baracudas
Sat Oct 12, 2013 1:38 pm
It's odd but i i drop those ip's but the problem persist. Beside that, every day i have some other ip.attacking.
Users browsing this forum: No registered users and 78 guests
