oxigeno20
Some nice examples for make your own PHP Scripts with API
Sat Oct 12, 2013 6:40 am
Hello everybody!!
I want share some post of my blog. (in spanish).
1) Introduction: what i can do with this API?
http://www.tech-nico.com/blog/api-mikro ... roduccion/
2) First Script: Create a script for testing the access of the API to your RouterOS.
http://www.tech-nico.com/blog/api-mikro ... i-con-php/
3) Manage Hotspot > IP-Bindings from your cel phone. (enable, disable and remove)
http://www.tech-nico.com/blog/api-mikro ... o-abierto/
4) create simples queues with validation.
http://www.tech-nico.com/blog/api-mikro ... car-regla/
5) Graph and log a specific pppoe client. Very Nice!!
http://www.tech-nico.com/blog/api-mikro ... ar-el-log/
6) Graphing real time trafic for some interface with highcharts
http://www.tech-nico.com/blog/api-mikro ... harts-php/
7) Enable or disable some ethernet port.
http://www.tech-nico.com/blog/api-mikro ... -ethernet/
I hope that you like it.
Best regards from Argentina!!
Nicolas www.tech-nico.com
boen_robot
Re: Some nice examples for make your own PHP Scripts with AP
Sat Oct 12, 2013 12:02 pm
I'd like to know what made you choose Denis' client. Thanks.
PEAR2_Net_RouterOS(1.0.0b6) - My API client in PHP
(Rate my posts? If you want... no pressure...)
oxigeno20
Sat Oct 12, 2013 4:50 pm
The true, i don't know. lol
The first time than i used this was very easy and fast. I can change too the port of API service, adding more security for the scripts.
I am visiting your site now.
Your libraries are new for me!
Can i try and post some examples on my blog using your libraries?
What can you tell me about ?
best regards!
Nicolas
www.tech-nico.com
boen_robot
Sat Oct 12, 2013 6:00 pm
Yes, please!
It can do everything Denis' client can, and a lot more.
- Of a particular note is the ability to translate shell-like commands into API syntax automatically, so that a user doesn't need to learn a new syntax (assuming they're already familiar with RouterOS' shell syntax).
- Another unique, more niche (but more impressive if you're in the niche) feature is the support for "persistent connections" - the ability to share the TCP connection between PHP requests, resulting in lesser load for the router (though at the expense of the web server).
- In the latest version, there's even file transfer and script execution with variables that can be supplied ala SQL prepared statements (except better).
- Oh, and since the first version, there has also been the ability of an automatic charset conversion that you can optionally enable. It allows you to write out in your native alphabet (accents and all) from Winbox, while also allowing your PHP application to read/write such data correctly as well, even if it uses UTF-8 (as it should).
ohara
Sun Oct 13, 2013 7:25 pm
Could you please give me some advice how to run a script? I tried the following, but I am using it wrong?
php code
<?php
namespace PEAR2\Net\RouterOS;
require_once 'src/PEAR2/Autoload.php';
$client = new Client('192.168.1.1', 'api', 'api');
$responses = $client->sendSync(new Request('/system/script/run script1'));
boen_robot
Sun Oct 13, 2013 7:28 pm
All arguments need to have their names supplied (that's why I always say "shell-like" as opposed to just "shell"; there are a few differences, with this being the most noticeable and inconvenient one). Sadly, the protocol does not (yet) provide any hints that would allow me to automatically infer the possible argument name if not explicitly supplied.
So:
$responses = $client->sendSync(new Request('/system/script/run number=script1'));
ohara
Sun Oct 13, 2013 7:34 pm
Perfect, thanks! I couldn't get it working with Denis' API. Now it works.
Users browsing this forum: Ahrefs [Bot], Bing [Bot], germarsh, jonah1810, krawadl, kulisnicek, liebenjj, Semrush [Bot], sindy, zaqik and 47 guests
