bachebikar
reset-counters
Sat Oct 12, 2013 8:36 am
Hello sir:
I'm using Mikrotik + UserMan as PPTP server to grant internet access to my users.
I made some profile limitations like 2Hour up-time limit; so my users disconnect after 2 hour of internet usage.
Then i scheduled a script to run at 12am every day:
/tool user-manager user reset-counters [find]
so the users up-time limit resets every night and they can reuse it tomorrow.
but as i upgraded to ROS 6.4 if a user used all of his time last day, he can't connect next day and i see that the actual-profile of user has gone and i must remove the current profile and assign it again in web-panel!
why this happened? do you have any solution?
I think its because user-man empties actual-profile field for user or reset-counters is not working fine!
corkuck
Re: reset-counters
Fri Feb 07, 2014 10:12 pm
I'm having the same problem of sorts.
See this post it could help us both.
http://forum.mikrotik.com/viewtopic.php?f=10&t=81617
"Happy MikroTik-ing"
/rk
bachebikar
Re: reset-counters
Sat Feb 08, 2014 6:50 am
Thanks. But i think it's a "must have" feature for user-man, because most ISPs don't use User-Man for commercial ISP billing solutions and User-Man's main usage is LAN-Accounting for internal company usage without any bank transfer (Just for managing Employees Internet access).
i hope MikroTik staff implement this feature in next release.
http://forum.mikrotik.com/viewtopic.php ... 87#p408087
Users browsing this forum: durkonos and 18 guests
