tabate47
Open DNS and Mikrotik
Sat Oct 12, 2013 8:29 pm
I would like to protect the kids from the internet in general. I have been looking at opendns and it seems like the way to go.
Is opendns the best way to do this?
If so, I have a dynamic ip address. Is there a way to keep my ip address in sync on the Mikrotik router?
Thanks.
pcunite
Forum Veteran
Forum Veteran
Re: Open DNS and Mikrotik
Sat Oct 12, 2013 9:13 pm
I've just started using OpenDNS ... seems to work well enough. There is no issue with a dynamic IP. Just set your DNS under IP / DNS Settings to use OpenDNS's ip addresses. As far as securing your computers, consider setting up SRP.
tabate47
Sun Oct 13, 2013 12:58 am
What happens to your custom settings when your dynamic ip changes?
tabate47
Sun Oct 13, 2013 9:51 am
That is the dilemma... how do you keep your dynamic ip address current on the mikrotik so that you don't lose your opendns settings?
efaden
Sun Oct 13, 2013 2:26 pm
http://www.opendns.com/support/dynamic_ip_tech/
Just use a hostname. Haven't tested it, but is from their faq
Sent from my SCH-I545 using Tapatalk
tabate47
Sun Oct 13, 2013 8:18 pm
Are you saying their host name? If so, how do you keep it up to date? Is there a script that works for the mikrotik with the hostname?
efaden
Sun Oct 13, 2013 8:39 pm
I believe you make your "label" marked as dynamic through the dashboard... then you can use the following URL to update the IP
https://UserID:Password@updates.opendns ... rLabelName
efaden
Sun Oct 13, 2013 8:41 pm
DNS-O-Matic also seems to support updating an OpenDNS Label
Kindis
Mon Oct 14, 2013 12:00 am
I have used it for over 2 years now and love it. If you have windows or Mac use the opendns Clint that will update you ip to opendns if changed. http://vwww.opendns.com/support/
Sent from my RM-821_eu_sweden_235 using Tapatalk
efaden
Mon Oct 14, 2013 2:33 am
If you want to run a script on your router here you go... Basically ensure that your "label" is marked as Dynamic on OpenDNS... then put the label, username, and password in the script. Run it every 10 minutes or whatever. If you wanted to you could make it check the current vs the old IP and only fetch if they differ...
ros code
#.* by RouterOS
# EntryDNS Update Script
# Variables
:local openDNSUsername "USERNAME"
:local openDNSPassword "PASSWORD"
:local openDNSHostname "LABEL"
# Script
/tool fetch url="https://updates.opendns.com/nic/update? ... NSHostname" \
    user="$openDNSUsername" password="$openDNSPassword" \
    mode=https keep-result=no
tabate47
Mon Oct 14, 2013 3:44 am
Thanks Eric. I will give it a try.
Do you think it makes a difference if I check it and only fetch if it differs?
Also, does checking every 10 minutes tax the router or bandwidth in any way?
efaden
Mon Oct 14, 2013 3:48 am
Shouldn't make a difference. And unless your on dial up the bandwidth is negligible.
tabate47
Mon Oct 14, 2013 3:32 pm
To be clear, am I correct in saying this script sends my current public IP address to opendns to always keep it current?
efaden
Mon Oct 14, 2013 3:49 pm
It actually doesn't send any ip. Their server uses the ip the request came from.
BS85
Mon Oct 14, 2013 4:11 pm
Etza
Fri Feb 27, 2015 5:27 pm
hi
what hapen in load balance ?
i have 4 wan load balance and 4 opendns network, how can update every wan ??
nichky
Long time Member
Long time Member
Tue Dec 27, 2016 9:57 am
What was my problem using OpenDNS. So it's working great but after couple of days OpenDNS servers disappear, and the customer can open any web side who i've been blocked on OpenDNS. Is anyone familiar with that?
Nikola Suminoski
MikroTik Consultan
MTCRE l MTCWE
!) Safe Mode is your friend;
Users browsing this forum: Google [Bot] and 71 guests
