MUM Europe 2020
Ehman
mesh.. soooo unstable!
Sun Oct 13, 2013 12:40 pm
Hi, I've got a WDS Mesh With Bridge with rstp on bridges with 7 antennas on static wds mesh mode [dynamic is worst] and the performance suuuck, sometimes the "nodes" just drop off the air and return when they feel like it
and the system seems to make the worst! signal the root, example:
best signal = path cost 90, root path cost 253 ---alternate port
second best signal = path cost 117, root path cost 189 ---root port
so in this case, the one with the worst or second worst signal got made the root port!! woooow, is there a way to change this
ros 6.3
samsung172
Re: mesh.. soooo unstable!
Mon Oct 14, 2013 1:09 am
prioritize in your rstp setup.
Ehman
Mon Oct 14, 2013 1:13 am
wish I knew how
samsung172
Mon Oct 14, 2013 3:45 am
well. It could be complicated. but to try in a simple way, try to make the perfered route. start at 1000 at your root (gateway), and set 2000 to fisrt device, 3000 to second, 4000 to third etc. If multipath. try to see as a circle with more rings.. put devices in the same "ring" at same priority
EG:
r1-r2-r3
1000-2000-3000
R1-R2 and R3, R2 and R3 - R4
1000-2000-2000-3000
Ehman
Mon Oct 14, 2013 11:18 am
EG:
r1-r2-r3
1000-2000-3000
1000-2000-2000-3000
my wds mesh setup have static wds ap's set, but the rstp bridges is on automatic, I need to find a way to put it on manual i guess
uldis
Mon Oct 14, 2013 11:44 am
for rstp ports you also can set manual path-cost and also by lowering the main routers priority to a lower one to make it as a root-bridge.
Ehman
Mon Oct 14, 2013 7:56 pm
OK, just found out, the bridge path cost and stuff needs to be dynamic, but I need a better method then now, I want the thing to connect to highest Tx/Rx rate, not the worst signal available like now that sometimes result in 600ms or timeout, can't someone at mikrotik just add something there for more control please??
or add more factors in the system that determines the best path
Ehman
Mon Oct 14, 2013 8:31 pm
something to consider:
Uptime + highest tx/rx signal + highest tx/rx rate + ...maybe the little packet flood thing that determines the max bandwidth
I think if you guys can add that, it will improve the system by far! or give the user options to select that will influence the "root path cost" values, so that we can at least have a more stable wds mesh networks, and I'm only talking about wds meshes .....
"WDS Mode: static mesh" and "WDS Default Bridge:XXX" with rstp enabled, that works fine for me, dynamic mesh... no thank you!
rstp on ethenet works fine
samsung172
Tue Oct 15, 2013 1:25 am
EG:
r1-r2-r3
1000-2000-3000
1000-2000-2000-3000
Still possible to do the "prio" to AP's. It don't matter. BTW, in a mesh wds network, set a minimum allowed signal to connect.
Ehman
Tue Oct 15, 2013 3:34 am
EG:
r1-r2-r3
1000-2000-3000
1000-2000-2000-3000
Hmm, I tried that ~1month ago, what a mess that was, didn't work at all as I wished, the thing just kept on ignoring my signal level rule, so I just left it on -120 setting
Ehman
Wed Oct 16, 2013 12:06 pm
LOL ..I still need someone to help me with this major issue? :(
Why does the AP drop when it connects to new WDS AP ???
but there's no drop when it connects to the alternate port, its lame
samsung172
Thu Oct 17, 2013 2:48 am
How do you configure your rstp and "connect list". This should work if setup correctly.
Ehman
Thu Oct 17, 2013 11:40 am
http://wiki.mikrotik.com/wiki/Wireless_WDS_Mesh
Model 2 : Wireless WDS Mesh With Bridge Interface
exactly the same bridge config, the only difference is, I use [WDS MODE:static mesh] and I've entered all my mac addresses of my AP's under interfaces as WDS on all AP's, and that's it ...static mesh causes less flooding each time a WDS AP join's my network, it causes a chain reaction of flooding... :?
Users browsing this forum: No registered users and 110 guests
