frboc
RB912UAG-5HPnD-OUT - how to open the case
Sun Oct 13, 2013 6:42 pm
just purchased the RB912UAG-5HPnD-OUT, now I would like to add a mini pci-e card inside... but actually I realize it is not clear how to open the case ? Please help.
honzam
Re: RB912UAG-5HPnD-OUT - how to open the case
Sun Oct 13, 2013 7:10 pm
LAN, FTTx, Wireless. ISP operator
Kreacher
Sun Oct 13, 2013 7:30 pm
you can mail to support@mikrotik.com and they would explane it to you at doing their best!
Kindly regards
Kreacher ♬
Karma points must not be paid by you
frboc
Sun Oct 13, 2013 7:52 pm
Looking carefuly at the movie, we can see the guy has the device dissassemled already in the box. He did some prework (also the RSMAs are unscrewed in the video) :)
Normally, the bottom part of the device cannot be pulled out.
honzam
Sun Oct 13, 2013 8:01 pm
Yes, it is canned. But you know how to open it?
nickshore
Sun Oct 13, 2013 9:28 pm
There are 2 screws which have small covers on the outside of the case.
Nick Shore MTCNA MTCWE MTCRE MTCINE MTCTCE
LinITX.com - MultiThread Consultants
Get your MikroTik RBs and Training: http://linitx.com/brand/mikrotik
Official UK MikroTik Distributor
IRC chan: #routerboard on irc.z.je (IPv4 and IPv6)
frboc
Mon Nov 04, 2013 8:33 pm
Thanks. Difficult to remove them but possible.
lustyffh
Fri Nov 15, 2013 4:28 pm
Please note that RB912G-5HPND has no space to connect 3rd pigtail for an extension card. AUX2 almost sticks to the motherboard leaving no room for external pigtail.
IngensNetworks
Mon Nov 18, 2013 10:36 pm
Well, we have installed a Sierra 8705 with it's own pigtail, and the solution is to use one of the three marked holes, who can be convert to available, with a simply scissors rotating it till get desired diameter...
Look the pic for final results.
Kind Regards.
Max
Users browsing this forum: Surge and 20 guests
