MUM Europe 2020
wsgtrsys
ipv6 nat in routeros
Wed Oct 16, 2013 9:13 am
IPv6 NAT support with kernel 3.7
routeros When can adding that feature?
http://lwn.net/Articles/514087/
Test-funtoo ~ # uname -a
Linux Test-funtoo 3.9.0-gentoo #1 SMP Fri May 3 22:47:49 CST 2013 x86_64 Intel(R) Xeon(R) CPU E5645 @ 2.40GHz GenuineIntel GNU/Linux
Test-funtoo ~ # ip6tables -t nat -A POSTROUTING -o eth0 -j MASQUERADE
Test-funtoo ~ # ip6tables-save
# Generated by ip6tables-save v1.4.18 on Wed May 15 22:00:03 2013
*nat
:PREROUTING ACCEPT [0:0]
:INPUT ACCEPT [0:0]
:OUTPUT ACCEPT [0:0]
:POSTROUTING ACCEPT [0:0]
COMMIT
# Completed on Wed May 15 22:00:03 2013
jandafields
Re: ipv6 nat in routeros
Fri Oct 18, 2013 2:23 am
Mikrotik uses kernel 3.3.5
I seriously doubt they will update that kernel version significantly until they release mikrotik 7.x
Buster2
Thu Oct 31, 2013 10:24 pm
Why should you need any kind of NAT in IPv6? Protecting users from incoming connections? That will do any rule like "drop incoming connection if not related to any outgoing connection from client ip" you can built in iptables and ROS since ages.
jandafields
Fri Nov 01, 2013 3:17 am
Maybe greedy ISP's are only giving out a handful of IPv6 addresses instead of large blocks?
docmarius
Fri Nov 01, 2013 10:37 am
Maybe some ISPs hand out dynamic IPv6 addresses, and you want some fixed addresses in your local network?
Maybe you could have 2 IPv6 providers and want fallback without changing IPs... you can imagine a lot of scenarios.
Torturing CCR1009-7G-1C-1S+, RB450G, RB750GL, RB951G-2HnD, RB960PGS, RB260GSP, OmniTIK 5HnD and NetMetal 922UAGS-5HPacD + R11e-5HnD in my home network.
awacenter
Tue Nov 05, 2013 11:09 am
I think Ipv6 NAT is necessary for activate the hotspot service using IPv6 addresses.
Moreover, it some networks it is userfull to net map an IPv4 LAN address to IPv6 address (in SOHO).
awacenter
Fri May 16, 2014 10:50 am
Do you think this feature will be implementing the next MikroTik release 7.x ?
Users browsing this forum: alkar, eworm, inteq, komdee, MSN [Bot] and 119 guests
