obiseba
Webfig: Error 406: Not Acceptable
Thu Oct 31, 2013 12:12 pm
I have problem with remote access by Webfig, after i put login and pass i recived: Error 406: Not Acceptable. In local network everything going ok, i don't have problem with webfig access.
My firewall have rules with input chain to port 80 and also input remote source IP.
Hardware: RB951Ui-2HnD
Package Versions: 6.5
tiler
Re: Webfig: Error 406: Not Acceptable
Sun Nov 17, 2013 7:59 pm
I have the same issue.
On one device (RB751G) the remote access to the webfig works fine but one another one (RB495G) with the similar firewall other setting I have "Error 406: Not Acceptable".
Spaceath
Wed Oct 01, 2014 6:50 pm
any news?
i have the same problem...
i want to login to webfig through cisco clientless vpn but i get the 406 error..
thomasbaun
Mon Dec 28, 2015 1:02 pm
Same problem on RB1100.
I see this consistently on 5 different locations.
p3rad0x
Long time Member
Long time Member
Wed Dec 30, 2015 1:08 pm
Did you try logging in with winbox to see if it works correctly?
There you go then you touched something ;-) : it only takes a change in wind direction to screw with your nat :-)
Yekver
Thu Feb 04, 2016 7:37 pm
Hi!
Is there any update on this issue?
I have this error when you trying to connect my mikrotik sxt 5hnd via remote ip address
dareru
Wed Oct 05, 2016 3:25 pm
The problem is in your browser. Try using Internet Explorer instead.
Users browsing this forum: No registered users and 25 guests
