MUM Europe 2020
lcm
Trainer
Trainer
MPLS / VPLS - cant ping each other
Thu Nov 21, 2013 12:02 am
Hi guys,
i need some help here, this is my scenario:
Rt1 -> Rt2 -> Rt3 -> Rt4 -> Rt5
Rt1
RouterOS 5.26
Rb1100AHx2
Rt2 to Rt5
RouterOS 5.26
Rb1200
They are running OSPF + MPLS with a /29 between each router.
vpls tunel with LDP
The problem:
I can estabilish the vpls and Ping from Rt1 to Rt2,3,4 the tunel with Rt1-Rt5 is estabilished but cant ping each other.
Ldp interfaces have been added, mpls interface MTU is 1500 for all.
some clues?
More info:
i did a sniffer and attached the image. it seens cant find the interface (unknown)
Greets from Brazil.
Luiz Claudio Martins Maia
lcm
Trainer
Trainer
Re: MPLS / VPLS - cant ping each other
Mon Nov 25, 2013 8:18 pm
anyone out there?
Greets from Brazil.
CelticComms
Mon Nov 25, 2013 11:19 pm
It isn't clear which IPs you have assigned to the VPLS interfaces or what the routing table looks like on R1 & R5.
Interlynx | Networking and Information Security Consultants & Trainers | Email: routerlynx@gmail.com
BGP | EIGRP | OSPF | MPLS | Firewall | VPN | IPsec | Multicast | QOS | IPv4/6 | STP | VLAN | PON | AE | M2M | and more!
lcm
Trainer
Trainer
Mon Nov 25, 2013 11:37 pm
ok, i'm sorry about that, i'll try to be clear:
vpls from Router 1 to Router2:
r1 vpls ip-192.168.0.1
r2 vpls ip-192.168.0.2
Status running.
ping OK
vpls from Router 1 to Router3:
r3 vpls ip-192.168.0.2
Status running.
ping OK
vpls from Router 1 to Router4:
r4 vpls ip-192.168.0.2
Status running.
ping OK
vpls from Router 1 to Router5:
r5 vpls ip-192.168.0.2
Status running.
ping NOT OK
With default ping size.
i can ping from outside the vpls
Greets from Brazil.
CelticComms
Tue Nov 26, 2013 12:27 am
Does it show running at both ends - R1 & R5? (I ask because it is possible to get one end showing running and the other end not...)
Any firewall differences on R5?
shahbazian
Trainer
Trainer
Tue Nov 26, 2013 9:00 am
You say:
But I thing you should use 1526 for mpls interface MTU when use vpls.
/mpls interface
set 0 interface=all mpls-mtu=1526
Learn MikroTik to improve your network.
( MTCNA, MTCRE, MTCWE, MTCTCE, MTCUME, MTCIPv6E, MTCINE )
MikroTik Certified Trainer & Consultant
RIPE NCC Trainer
lcm
Trainer
Trainer
Tue Dec 10, 2013 4:59 pm
thanks for the answer.
yes, running on both ends.
no firewall at all.
Greets from Brazil.
lcm
Trainer
Trainer
Tue Dec 10, 2013 5:01 pm
You say:
/mpls interface
yes i know i should, but i have some mtu problema with wireless devices. so if i keep the mtu 1500 the RB must fragment the packet, right?
Greets from Brazil.
shahbazian
Trainer
Trainer
Sat Mar 01, 2014 12:57 am
If MTU is too large and next header is IP
Then generate “ICMP Need Fragment error”
Else silently discard packet
RIPE NCC Trainer
Users browsing this forum: No registered users and 6 guests
