learath
RB2011 does not support ethernet auto-negotiation?
Tue Nov 26, 2013 6:08 am
I have an RB2011UAS hooked up to my local gigabit switch and a Verizon FIOS box. The gigabit switch links up at 100m, and the Verizon FIOS box links up at 10mb. I've seen several other mentions of these issues, is there any progress on a fix? I'm running RouterOS 6.6 and firmware 3.10.
aaronhun22
Re: RB2011 does not support ethernet auto-negotiation?
Wed Nov 27, 2013 2:50 am
Which ports are you using because only ports 1-5 are Gb.
learath
Wed Nov 27, 2013 7:28 am
One and two in this case. I understand it's a known issue with early RB2011 hardware? There was another issue which was resolved by a software update, which I have installed to no effect.
