MUM Europe 2020
jfvelamoscoso
Trainer
Trainer
NAT only one port
Tue Nov 26, 2013 4:37 pm
I am trying to deliver public ips to some costumers. This is what i want to do and i think i need a little help.
The topology is show in the atachment. In this case i only want that the port eth5 will be nat using the public ip 1
Best regards
jfvelamoscoso@gmail.com
Network Engineer Noc Department
MTCNA, MTCTCE
If it helps please give some karma
aaronhun22
Re: NAT only one port
Wed Nov 27, 2013 2:27 am
You can NAT the public IP's to your customers using the answer from this post:
http://forum.mikrotik.com/viewtopic.php?f=2&t=79253
Or you can route the public IP's by sub-netting them on a /30 network.
jfvelamoscoso
Trainer
Trainer
Thu Nov 28, 2013 12:28 am
Thanks for the quick rep
This looks like a 1:1 Nat, it could work i didn't try on my enviroment yet but it sounds as it work. I was thinking in nat only the port eth5 masquerading the packet with ip of eth1 because this is LAN network. And leave ethernet from 2-4 without natting. Because this ports eth2-eth4 will have public ip
Best Regards
MTCNA, MTCTCE
Rudios
Forum Veteran
Forum Veteran
Thu Nov 28, 2013 8:56 am
You can bridge the interfaces ether1-4 and assign your desired local IP to ehter5.
Give the bridge a public IP available to you.
Testing setup with: 2 x RB750UP | 2 x RB750GL | 1 x RB951G-2HnD | 1 x RB2011UiAS-IN
jfvelamoscoso
Trainer
Trainer
Thu Nov 28, 2013 9:43 pm
It didn't work beacuse in this case if i bridge from eth1-4 i'll be doing a loop betwenn external an internal interfaces.
MTCNA, MTCTCE
Users browsing this forum: ifast, Rey68 and 132 guests
