tonymobile
Special Features Channel width on ROS v.6
Sat Dec 07, 2013 8:03 am
Hi to all,
I know the date of implementation of these functions?
http://wiki.mikrotik.com/wiki/Manual:Wi ... d_Channels
Regards.
nkourtzis
Re: Special Features Channel width on ROS v.6
Sat Dec 07, 2013 7:59 pm
They are already implemented, but you need to acquire a (free) license extension from Mikrotik in order to use them. Also, they are not supported on the latest 9xx routerboards. :-(
Passionate about networks
Enthusiastic about Mikrotik
MTCNA | MTCRE | MTCINE
No trees were killed to send this message,
but a large number of electrons were terribly inconvenienced.
tonymobile
Sat Dec 07, 2013 9:33 pm
Hi nkourtzis, thanks for reply, how and where can I buy the license?
Regards,
Tony.
tonymobile
Sun Dec 08, 2013 3:42 pm
RB 711-5Hn with AR5008 Wireless Network Adapter (rev: 1) not supported!!!! :(
normis
Mon Dec 09, 2013 10:53 am
Yes, the manual describes this:
Currently only Atheros AR92xx based chips support non-standard center frequencies
tonymobile
Tue Dec 10, 2013 12:22 am
Hello Normis, how active the advanced channel???
I want to test it on some PTP.
Regards.
nkourtzis
Tue Dec 10, 2013 3:19 pm
You have to have an account on the Mikrotik site. You go to the last tab ("Account") and login. Select "Support contact form" (right menu column) and tell Mikrotik that you want to activate the extra channels feature on your account. They will send you a legal form to print out, sign and email it back to them. Then, they will activate the feature on your account. This essentially means that you will be able to upgrade any Mikrotik license with this feature.
To do this, you first have to import the license key from the device. In either the webfig or the winbox, you go to System -> License and copy the Software ID. You then login to your account on the Mikrotik site, select "request key from another account" (left menu column) and paste the ID. Then go back to main menu, select "all keys" and navigate to the key you just entered (the keys are placed in folders on a folder tree). Select the key row and click the "Upgrade" button below the table.
Now open up a Winbox to your device, go to System -> License and click "Update License Key" on the right. That's it!
tonymobile
Wed Dec 11, 2013 8:35 am
Ok, many thanks!
Tony.
Users browsing this forum: Bing [Bot], GhostyG89 and 146 guests
