Superdust
Webfig, auto login, show only some data...
Tue Dec 10, 2013 2:42 pm
Hi
I need to have some none "technical" staff have access to certain parts of webfig.
Made a quick webpage as a "control panel" for several RBs, with link to webfig for each.
Like this: http://username:password@10.1.60.2/webf ... ver.Leases
But still i just get the login page for webfig.
Any way to make this autologin work?
And any way to only show certain parts, like DHCP server leases, without showing the entire menu?
Regards
sergejs
Re: Webfig, auto login, show only some data...
Tue Dec 10, 2013 3:24 pm
At the moment admin without password login automatically to webfig.
Configure appropriate skin for admin user (and do not forget to grant it read permissions).
Amm0
Mon Oct 07, 2019 11:52 pm
Similar problem. Related question, I have a limited user without any password, can I create some URL that specifies the user name it to login in instead?
E.g. http://RouterOS.example.com/webfig/#Too ... n=testonly
Basically I’d like to have a URL link to a webfig pages that doesn’t redirect to login. Tried using a web server in between to do some login, but even that didn’t work. Since the login uses a webpage, we couldn’t figure out a clean way to fetch a webfig page from a web server to workaround this. I understand basic auth doesn’t work. And I take it X.509 client don’t work to access webfig as that solve my problem too?
Any ideas?
Users browsing this forum: No registered users and 58 guests
