agshekeloh
"system sup-output" hangs at 6% on ROS6.7
Tue Dec 10, 2013 5:34 pm
I'm running 6.7 on a CCR1016-12G and need to file a support request. So I go to a terminal and run:
[admin@router]> system sup-output
created: 6%
-- [Q quit|D dump|C-z pause]
It sits here. No file supout.rif file appears. Profile shows that the system is overwhelmingly idle.
I can interrupt the system sup-output command, but I can't seem to generate a support file.
Any ideas? I'd open a ticket, but I need the supout file to do so...
agshekeloh
Re: "system sup-output" hangs at 6% on ROS6.7
Tue Dec 10, 2013 6:01 pm
Of course, I posted this question and the command finished. Never mind.
It took far longer than I expected, but I didn't think to time it. More than 15 minutes, less than 90 minutes, for the benefit of anyone else who experiences this issue.
futsker
Fri Jan 20, 2017 5:37 pm
did you solved the problem?
I have the same issue: http://forum.mikrotik.com/viewtopic.php?f=2&t=117054
Users browsing this forum: ath, dcalanchini, jebz, mmp1992, szymonzdziabek and 60 guests
