MUM Europe 2020
marsark
CCR1036-8G-2S+ problem with Direct Attach Cable in SFP+ port
Fri Dec 13, 2013 1:32 am
I have finally got my hands on the CCR1036-8G-2S+ and started testing it in our network. But suddenly I have fallen in troubles with Direct Attach Cables which are connecting CCR to Extreme Networks X670.
First of all I X670 was unable to establish a link with CCR, but on the side of CCR port was running, but no link or activity signalized by LEDs. This was fixed by disabling auto-negotiation on X670 and forcing 10GbE full-duplex.
At this point data goes trough at 10Gbps but link and activity LEDs still don't have a light. I gave chance to a few other DA cables but behavior is same. Actually I don't have SM/MM SFP+ modules available for testing.
Any ideas?
Martin
nz_monkey
Re: CCR1036-8G-2S+ problem with Direct Attach Cable in SFP+
Fri Dec 13, 2013 5:31 am
We are using SR modules to connect to Summit X670 switches successfully. You problem sounds like it is related to DA cable compatibility.
http://thebrotherswisp.com/ | Mikrotik MTCNA, MTCRE, MTCINE | Fortinet FTCNA, FCNSP, FCT | Extreme Networks ENA
nz_monkey
Fri Dec 13, 2013 5:32 am
We are using SR modules to connect CCR's to Summit X670 switches successfully. You problem sounds like it is related to DA cable compatibility.
marsark
Sat Dec 14, 2013 12:27 am
Yes, it seems to be some problem with DA cables at the side of CCR. I tested more different cables with no difference in behavior. Some SR/LR will arrive on Monday, so I plan to do more testing.
marsark
Thu Dec 26, 2013 12:33 am
I finally did some more test fit SR/LR SFP+ modules instead of DAC and noticed no problem with LEDs. So it look like support for DAC in CCR is somehow unfinished.
Does any body else runs CCR with DAC? I have a DAC only from one vendor, so I'm just curious if it is problem of brand or DAC in general.
krisjanis
Mon Mar 17, 2014 2:04 pm
Which ROS version is installed on this CCR? Led behavior for DACs should be correct in latest releases.
marsark
Wed Mar 19, 2014 12:22 am
Our box is actually running ROS 6.7 with bootloader 3.10. Both SFP+ port are used, communication is running but no lights.
krisjanis
Wed Mar 19, 2014 5:28 pm
What do you see in "/system led print"? Possibly default config for leds might have been corrupted.
marsark
Thu Mar 20, 2014 11:54 am
output is empty
/system led print
Flags: X - disabled, * - default
 #    TYPE                     INTERFACE        LEDS
krisjanis
Thu Mar 20, 2014 1:23 pm
Try re-adding led configuration.
/system leds
set 0 disabled=no interface=sfp-plus1 leds=eth0-led1 type=interface-speed
set 1 disabled=no interface=sfp-plus1 leds=eth0-led2 type=interface-activity
set 2 disabled=no interface=sfp-plus2 leds=eth1-led1 type=interface-speed
set 3 disabled=no interface=sfp-plus2 leds=eth1-led2 type=interface-activity
marsark
Thu Mar 20, 2014 5:56 pm
nope...
[admin@felk-fw] /system leds> set 0 disabled=no interface=te1 leds=eth0-led1 type=interface-speed
no such item
[admin@felk-fw] /system leds> set 2 disabled=no interface=te1 leds=eth0-led2 type=interface-activity
no such item
[admin@felk-fw] /system leds> set 3 disabled=no interface=te2 leds=eth1-led1 type=interface-speed
no such item
my 10GbE interfaces are named te1, te2 :)
krisjanis
Fri Mar 21, 2014 4:05 pm
In that case it would be good to upgrade this unit to v6.11. And check leds there, if they are not working there and leds are not avaialble for configuration then we would like to get supout file from this device.
marsark
Fri Mar 21, 2014 4:33 pm
this is productional, mission critical box, it is save to upgrade to 6.11 ? :)
marsark
Sat Mar 29, 2014 12:11 am
So, I upgraded to the ROS 6.11, but attempts to restore default LED config in console still fails with: no such item, but i was able to add configuration in the Winbox dialog LEDs.
[admin@felk-fw] /system leds> set 1 disabled=no interface=te2 leds=eth1-led2 type=interface-speed
no such item
There is also some inconsistence between Winbox dialog and the console. Console offers type=interface-speed, but there is no such option in the Winbox LEDs dialog. When configuration is created in Winbox it after a while becomes "default" (changes color) and I'm unable to change it anymore.
martini
Mon Mar 31, 2014 11:56 pm
try this
[admin@felk-fw] /system leds print
[admin@felk-fw] /system leds set 1 disabled=no interface=te2 leds=eth1-led2 type=interface-speed
marsark
Tue Apr 01, 2014 11:21 pm
nope ... i tried this many times
[admin@felk-fw] > /system leds set 1 disabled=no interface=te2 leds=eth1-led2 type=interface-speed
failure: This preset is read-only!
Users browsing this forum: No registered users and 16 guests
