lemonmagic
Mikrotik 3G as Bridge to Router?
Tue Dec 17, 2013 1:09 pm
I have my Mikrotik Router mounted in the basement. Now I want to change my Internet Connection from ADSL to a 3G Network, but the only good Reception wood be outdoor on the Roof.
Now I would like to mount a small Routerboard with USB Connection underneath the Roof, and transparently connect the 3G-Routerboard with my Router in the Basement.
How would I have to set the small Routerboard without any NAT - Firewall Actions.
thanks
aaronhun22
Re: Mikrotik 3G as Bridge to Router?
Tue Dec 24, 2013 12:33 am
So are you trying to boost the 3G signal from your basement or are you putting the 3G in the attic and relaying to the basement? Any RB OS with License Level 3 and up can connect to a RB AP in station mode.
lemonmagic
Tue Dec 24, 2013 1:06 am
No, in the Basement there is a RBL-2011 Router without Wifi.
Now I want to switch from Adsl to 3G, but for a good Signal, I will need to place the usb Modem outside the Roof.
The Router will be connected by cat5 with the RB acting as "Modem".
It should passthrough the 3G Ip Adress straight to the RB2011 in the Basement.
How would I have to confiure the Mikrotik with the USB Modem attached?
thanks
aaronhun22
Tue Dec 24, 2013 2:50 am
Add the 3G interface to the bridge of the RB acting as modem and make sure the network cable connected to the RB in the basement is connected to your WAN interface. If you're planning on utilizing both 3G and ADSL connections then you'll have to configure 2 WAN interfaces and mangle rules.
RogerWilco
Thu Dec 26, 2013 12:39 am
Can you just connect a 3G antenna to the modem to save the trouble?
lemonmagic
Wed Jul 29, 2015 6:36 pm
Today I picked up the Topic again, as I want to move to 3G only Internet.
Still need a way to figure out how I pass the Internet Connection from one Mikrotik without NAT to the Router in the Basement.
The Suggestion by aaronhun22 won't work, as you can't add a 3G pppoe Connection to a Bridge.
I don't need the 3G Internet Address on the Router, as long as I don't have a double NAT it should be fine.
ExNihilo
Tue Nov 10, 2015 2:32 pm
I'm interested in trying this setup as well. Most likely using an LTE interface on the Router Board with the modem attached. Any advice on how to achieve this would be greatly appreciated.
lemonmagic
Tue Nov 10, 2015 4:06 pm
I got it working through a dstnat Rule, but with this I was not able to pass the external IP to the Router,
but I had to use a seperate internal IP for the 3G Modem Router.
Here is the Setup I am using:
/interface ppp-client
add apn=internet default-route-distance=1 disabled=no name=ppp-out1 port=usb1
/ppp profile
add bridge=br-drei name=profile-drei
add bridge=br-drei interface=ether2
add bridge=br-drei interface=ether1
add name=dhcp_pool1 ranges=192.168.124.2-192.168.124.254
add address=192.168.124.1/24 interface=br-drei network=192.168.124.0
add address=192.168.124.0/24 gateway=192.168.124.1
add action=dst-nat chain=dstnat dst-address=77.119.226.91 to-addresses=\
    192.168.124.2
/system scheduler
add disabled=yes interval=1d name=Reboot-daily on-event="/system reboot " \
    policy=reboot,read,write,policy,test,password,sniff,sensitive start-date=\
    aug/05/2015 start-time=05:30:00
And on the Router where the 3G Modem Router is connected, you just put a static IP in the same IP Range (192.168.124.2), with it's masquerading rule.
I have a static IP Address for my 3G Modem, not sure how this should work with dynamic Addresses.
Hope it helps.
ExNihilo
Sat Nov 14, 2015 4:21 pm
Thanks. This gives me something to think about. Unfortunately I cannot get I static ip for my LTE connection so I'll need something a bit different.
RogerWilco
Sun Nov 15, 2015 1:06 am
http://www.scribd.com/doc/82742398/Solar-Relay-v2
I've switched to 4G now, but haven't updated guide. Works a treat.
Users browsing this forum: faxxe, k6ccc, pmurdock, ShayanPAL, st2505ts and 55 guests
