MUM Europe 2020
slarner
CCR1036-8G-2S+ SFP Problems
Wed Dec 18, 2013 7:22 pm
Hi
I hope someone can shed some light on this! I brought a CCR1036-8G-2S+ a few weeks ago expecting to use the SFP+ ports in the future. But since this we have had some other connections added in the datacentre which means the router needs a fiber connection to the remote peer.
So i went out and brought 2 x S-31DLC20D 1.25G Singlemode SFP modules.
one was to go in the existing CCR1036-12G-4S and other for the new router.
This is where to problem occurred the CCR1036-12G-4s worked 1st time no problems at all but the CCR1036-8G-2S+ would show link OK on the status but no link on the switch at the other end of the fibre it also shows tx Power as blank and rx power at -9dBm.
But as soon as you put this module in the other router it works straight away so its not the module or the fiber. I have also tried locking the speed at 1G full duplex it seams to make no odds and we also got the peer the other end to lock the speed still nothing.
I have also send a supout to mikrotik with some really useless reply's "try disabling and enabling the port"
Just trying to figure if anyone else may have had any similar problems.
Stewart
http://www.countybroadband.net
Provider of wireless broadband in Essex and Suffolk UK
kbasat
Re: CCR1036-8G-2S+ SFP Problems
Thu Dec 19, 2013 1:34 pm
We just got our hands on 2 sample CCR1036-8G-2S+ and experiencing exactly the same issue.
10G sfp modules work flawlessly, however, we could not get any one of the 1G modules we have (we have both mikrotik single/dual fiber and third party) to work.
When cable is connected, it is recognized as link ok but no data can pass through. I cannot ping to other side and I cannot see other device in neighbors.
We have tried every combination of ARP/autonegotiation, multiple disable/enables, trying with vlans and no luck.
If we remove the sfp module from 8G-2S+ and plug it into a CCR1036-12G-4S, it starts working immediately.
We are currently happy with one port working with 10G sfp as we just upgraded our upstream to a 10g port, but not being able to use the second port with a 1g sfp module is a disappointment.
I hope a software update will be able to fix this problem in near future.
Kemal
krisjanis
Thu Dec 19, 2013 3:31 pm
1. to achieve successful fiber link between CCR1036-8G-2S+ and CCR1036-12G-4S or any other SFP device you need to:
*) disable auto-negation and set interface speed to 1Gbps to routers on both sides.
*) re-plug module or disable/enable interface after these changes.
when this is done link should be active.
2. regarding lack of information "Tx Power" field I suspect that dmi information fetching from module failed. Reboot or power cycle should fix this state.
slarner
Thu Dec 19, 2013 5:12 pm
This does not work I've already tried all of that!
This was also put in the support ticket which I've had no reply to since!
I'm really struggling to understand why such a simple thing does not work?
Neilson
Fri Dec 20, 2013 3:28 am
I am having this same issue with my CCR1036-8G-2S+
Mikrotik 10G modules work flawlessly. However mikrotik or other SFP's don't work, they say link up but nothing works.
No Negotiate doesn't help.
Using the 6.8RC1 build from the other day.
Attached are supout.rif files for the devices with and without auto negotiate.
A.
Kreacher
Fri Dec 20, 2013 7:01 pm
are you all not able to plug in the CRR-1036-2S+ a SFP+ transceiver and in the CCR-1036-8G-2S a SFP transceiver
so that the right transceivers are plugged in the right router on each side and then you are plug in the cables.
Would this not march?
Kindly regards
Kreacher ♬
Karma points must not be paid by you
slarner
Fri Dec 20, 2013 7:17 pm
Finally someone else having the same problem! I have no control of the remote end of the connection. So nothing can be changed there!
I'm quite sure it's a software issue! As same sfp on the same fibre works fine in the old cloud core router!
Neilson
Mon Dec 23, 2013 3:43 am
@Kreacher
Our problem is plugging SFP modules into the SFP+ slots and having things not work right.
The SFP's are known good however when in the 10Gig slots they are being auto negotiated as 1G
Normis had said in a post on here that they should be usable at both 1 and 10 gig so was looking at doing that with 1 gig to start and going to 10 once the SFP+'s arrive.
When I turn off auto negotiation they set to "1Gig" but the link still doesn't work between them
I have tried rebooting the machines and I haven't seen that fix this issue however @krisjanis says setting both ends to manual 1G and rebooting should work (not my experience) but if anyone else can try and see if they can confirm this?
A
afink
Mon Dec 23, 2013 5:17 am
have you tested with SFP Rate Select = low?
slarner
Mon Dec 23, 2013 12:49 pm
I can confirm locking both ends makes no difference! The strange thing is even if you lock it at say 100mbits full duplex it still shows the link running at that speed! which im sure is not correct!
@Kreacher
A
krisjanis
Mon Dec 23, 2013 4:51 pm
@Kreacher
To what device are you trying to connect CCR1036-8G-2S+?
slarner
Mon Dec 23, 2013 5:21 pm
this shouldnt matter? its a laser? set to 1310nm i was trying to connect to an extreme networks switch X460-48x
Neilson
Mon Dec 23, 2013 9:18 pm
CRS125-24G-1S - Supout's above in this post chain
CCR1036-12G-4S - Ticket number: 2013120266000148
Keeping it in the family
I suspected possible vender weirdness with the CCR-CCR link as it was non mikrotik optics (make 80Km CWDM / DWDM lasers ;-) ) but now tested to the CRS with official mikrotik optics and still issue as above in this post.
A
slarner
Mon Dec 23, 2013 9:27 pm
Hi Guys,
Im just standing in the data centre now! And thought i would give this one last go.
i have tried many different SFP's in the router and none of them have worked this is including a Mikrotik one!
I just happend to lay my hands on a Cisco one and boom it worked 1st time! as soon as i locked it to 1G full duplex the link came straight up!
The model number is CISCO-FINISAR FTLF1319P2BCL-C4
Hope this might help!
kbasat
Fri Jan 31, 2014 9:42 pm
What is latest from Miktotik on this?
Can Mikrotik not replicate this issue? It is as simple as using 2x CCR1036-8G-2S+ and using 2 Mikrotik 1GB modules (not 10G modules) and see that they do NOT work!
I have been looking for exact part number slarner has suggested and cannot find one.
5 different brands of sfp's I have, including the Mikrotik ones, does NOT work with 8G-2S+. All of these SFPs work with 12G-4S without any issues...
Any feedback is greatly appreciated.
welan
Mon May 26, 2014 4:31 pm
Same problem here, disabling auto-negotiation the sfp works, but a lot of jitter on the link.
Any news?
0ldman
Wed Jun 04, 2014 4:29 pm
Same problem here.
Mikrotik parts, 100%. The link works with an RB2011 with the same model MT SFP, though I had to force 1GB FD to get it to link.
So far I am not impressed with the CCR.
0ldman
Wed Jun 04, 2014 5:34 pm
Kreacher, thanks for the karma and thanks for the info about the SD card. I'll try that.
norepto
Wed Jun 04, 2014 5:58 pm
I have this similar router with MikroTik S-3553LC20D pairs, i put the SFP blue one in the router and in the other site i have the yellow one in a Meridian MS8GT4GX4. When the fiber is connected i see SFP LIGHT ON and i don't have connection between them. In the Winbox i see the interface registered but i only see TX traffic. I try with others sfp modules and it's always the same. I'm thinking maybe it's a soft problem because when i try CCR=SPF"MIKROTIK"=><=SPF"MIKROTIK"=CCR Works perfect.
This Meridian MS8GT4GX4 Works fine with other devices, not with my CCR's 1036-12G-4S...
Kreacher
Wed Jun 04, 2014 6:55 pm
No problem I really think it should be also even the best if anyone find out something
and then he is sharing this with all others! So the world will never stops and turns around. :D
Kindly regards
Kreacher ♬
joegoldman
Long time Member
Long time Member
Thu Jun 05, 2014 1:30 am
Hi All,
I too am experiencing this problem. I have 2x10G SFP+ modules and 2x1G SFP modules, 1 of each in 2 CCR1036-8G-2S+'s.
If i take my cable and plug in between the 2 10G modules it comes up straight away.
When i take the exact same cable and plug into the 2 1G SFP's no link light or anything.
It seemed to work when I first got them, but they are in production now so I can't roll back to early version ROS.
Thanks,
Joe
Kreacher
Thu Jun 05, 2014 1:55 am
Hi Joe Goldman,
in some cases it would be helping to disable the auto-negotiation on one or both sides.
Kindly regards
Kreacher ♬
joegoldman
Long time Member
Long time Member
Thu Jun 05, 2014 3:17 am
in some cases it would be helping to disable the auto-negotiation on on or both sides.
Thanks, I'll try that out next I'm in front of them or get some new ones. As said they are in production now so not going to play with them :)
norepto
Sat Jun 07, 2014 10:50 am
I have similar problem, i resolved it upgrading to 6.13 and after i make factory defaults. Now it's working. Auto-negotiation still enabled.
becs
Mon Jun 09, 2014 2:33 pm
I would like to clarify once again that 1.25G SFP modules used in RouterBoard SFP+ ports require to have auto-negotiation=no and speed=1Gbps in order for link to work.
This means usually device on the other end also must have exact port settings.
cdiedrich
Forum Veteran
Forum Veteran
Wed Jun 11, 2014 2:47 pm
Thanks, becs. Very informative.
Do I read correctly that ALL MikroTik SFP+ ports are capable of getting 1G links to work with 1.25G SFP modues?
I'm asking because Sergejs stated by email (in the end of April) that only 10G links are possible - so we didn't put a significant order on the CRS226 yet...
Thanks for any clarification.
-Chris
Christopher Diedrich
MTCNA, MTCUME, MTCWE
Basel, Switzerland
Bremen, Germany
There are 10 types of people: Those who understand binary and those who don't.
There are two types of people: Those who can extrapolate from incomplete data
janisk
Thu Jun 12, 2014 2:15 pm
some are and some are not. if interface name is set as sfp-sfpplusX - it is capable of 1.25G and 10G, if only sfpplusX it is 10G only.
On particular router (CCR1036-8G-2S+ both should be sfp-sfpplus interfaces)
bela
Thu Jun 19, 2014 8:21 pm
I have two CRS226-24G-2S+RM switches with a 1G LC SFP in port 1.
I can confirm that setting the links manually to 1G DOES NOT HELP.
I can not make a link work between two switches with Mikrotik 1G single mode (LC) modules.
Tried a different brand SFP module as well.
Installed V6.15, same thing.
Link comes and goes every few seconds.
Please help.
Regards,
Bela
Kreacher
Fri Jun 20, 2014 12:26 pm
Please help.
Regards,
Bela
Hello Bela,
not in all situations or very often but sometimes it will work if you set up this likes @becs was
explaining in some lines above.
- Stitch in the SFP+ Modules
- set up the settings like mentioned above
- stitch in the cables
- power cycle the CCR/CRS
And the link will be up and stable.
I really don´t know why and also I really don´t know why it works on both devices only
from time to time and not even, bur give them a try and perhaps you will be the lucky one
could also not be worth I think!
Good luck!
Kindly regards
Kreacher ♬
spectrasurf
Tue Jul 29, 2014 3:57 am
No news on this? Trying to link the 8-port SFP unit with the 24-port switch unit using an SFP. Must be SFP because only have 1 fiber between sites. Mikrotik only sell 10G SFP+ with 2 fiber.
So what? Junk?
jkarras
Tue Jul 29, 2014 5:53 am
I am confused by your question No one here seems to be talking about 1GBase-BX optics.
One option you have is to buy a cheap CWDM optical MUX and convert your single strand of fiber into multiple channels.
Kreacher
Mon Sep 08, 2014 5:41 pm
As I see it also, it is even better to be compatible to all or the most other things on the
market it will be also grow the range of usage and customers.
SX - 850 nm, 500 m
LX - 1310 nm, 10 km
EX - 1310 nm, 40 km
ZX - 1550 nm, 80 km
EZX - 1550 nm, 120 km
BX - 1490 nm/1310 nm, 10 km
Would be great to see all standards are supported.
Also the 100/1000 MBit/s and 1000/10000 optics would be also great.
Kindly regards
Kreacher ♬
aacable
Tue Dec 02, 2014 11:53 am
Suffering with same issue.
I have ccr1036-12g-4s with sfp modules, setting up to 1g link manually set the LINK to OK. but no data pass. Tried every suggestion mentioned here and at forums, but no luck.
_____________
Regard's
Syed Jahanzaib
Web: http://aacable.wordpress.com
Email: aacable [at] hotmail.com
hashbang
Wed Dec 03, 2014 11:30 am
Can you please explain how you had connected and which modules you are using. This will benefit others .
eternal0
Tue Dec 09, 2014 3:58 pm
Same problem in CCR1036-8G-2S+EM.
10G SFP+ module works well on both side. But with 1G SFP module, the router show link OK on the status and no link on the switch at the other end.
savage
Tue Dec 23, 2014 2:28 pm
CCR1036-8G-2S+ with SFP+ modules, linked at 10G - unable to pass anything over 1.2Gbps...
Not impressed AT ALL with these devices currently.... Incredibly slow.
Regards,
Chris
Neilson
Wed Dec 24, 2014 2:02 am
Chris
How many connections are you using to test the throughput?
Its widely communicated on here that the cores seem to have a limit of processing ~1Gbps each and that work still needs to be done to balance single connections over multiple cores.
Try running 20 different connections over the link or try multiple systems pushing 1 Gbps each. That should give the system a workout.
some creativity may be needed to get certain traffic to break down into multiple connections (iSCSI springs to mind) but for more typical ISP service with a number of customers and probably few, if any, at over 1Gbps as a single connection then these boxes shine.
Regards
Alexander
savage
Wed Dec 24, 2014 8:40 am
uhm...
Thanks, but no, this is a router in actual production networks. Well over 5K established TCP sessions. CPU sitting at less than 20% also, so it's not a load issue either.
A simple single threaded wget in linux gets over 3Gbps. So yes, it is most certainly a Mikrotik issue. If Mikrotik's products aren't 10G ready, they should not be selling and/or advertising them as 10G ready devices...
I would still LOVE to see *any* real world traffic graph of a CCR pushing 3 or 4 Gbps on a Graph, over a 24 hour period. It's ironic that there isn't ONE such graph on these forums or on the Internet that I can see...
Regards,
Chris
tetecko
Wed Dec 24, 2014 11:54 am
DMI not working on new modules .. trough version 6.20 to 6.24 .. unplug modules, reboot, upgrade fw, but nothing help... on new MKT modules, there is lack of DMI .. tested on CCR, CRS, RB2011
Neilson
Thu Dec 25, 2014 1:11 pm
So can you only pass 1.2 Gbps? or 3Gbps?
What software version are you running on this box?
what sort of config have you got on it?
What have you tried to do to tweak for pushing high volume?
What testing are you running across the box?
Regards
Alexander
hashbang
Fri Dec 26, 2014 9:08 am
uhm...
@Savage, If you'd invested in x86 servers and that server is not in production can you please try some other os maybe Vyos which is fork of vyatta and see exactly where the problem is.
savage
Sat Dec 27, 2014 9:25 am
Linux on x86 box and I get +- 3-4Gbps on a single threaded HTTP download...
Regards,
Chris
popcorrin
Tue Dec 15, 2015 7:20 pm
Did the sfp in sfp+ ports issue get straightened out. I was going to purchase a ccr1072 but if this is still an issue I will need to rethink my purchase.
popcorrin
Mon Dec 21, 2015 8:01 am
I tested with a ccr1016-1S+-12S and it is still an issue. sfp transcievers do not work on sfp+ ports. I'm surprised this is still an issue. I would think this would have been addressed by now.
XTX
Mon Dec 21, 2015 11:48 am
The solution from krisjanis worked for me...3rd post from the top...
krisjanis
Wed Dec 23, 2015 5:38 pm
On that specific CCR model SFP+ interface works only with 10G links. Due to it's hw design it's not possible to use that SFP+ in 1G link rate.
It's the same on CRS226 and CRS210 with their SFP+2 interface.
davidking3000
Mon Mar 13, 2017 2:28 pm
Thanks the above quoted fix worked between CCR1009-8G-1S and CCR1036-8G-2S+ using 2 MT-RBSFP-SM modules.
magnavox
Thu Feb 08, 2018 7:13 pm
Hello, solved this?
Best Regards...
mikron15
Thu Mar 01, 2018 7:33 pm
I am in the same boat. Cannot get the SFP module to work in the SFP+ port on the CCR1009-7G-1S+ router. The Mikrotik router sees the module present and identifies it but the link on the side (Cisco 3750-x) shows it down. Yes, I have read the wiki and several other posts about disabling auto-negotiations, and hard setting the speed to 1Gbps and full duplex. This router model doesn't have any 1Gbps port restriction on the SFP+ port either based on the wiki. Still no luck. Tried with a original Cisco 1G Sfp moule (glc-sx-mmd) and Fiber store brand equivalent SFP1G-SX-85. Any other suggestions?
[admin@MikroTik CCR1009] > /interface ethernet monitor sfp-sfpplus1
                  status: link-ok
        auto-negotiation: disabled
                    rate: 1Gbps
             full-duplex: yes
         tx-flow-control: no
         rx-flow-control: no
      sfp-module-present: yes
             sfp-rx-loss: no
            sfp-tx-fault: no
                sfp-type: SFP-or-SFP+
      sfp-connector-type: LC
    sfp-link-length-50um: 550m
    sfp-link-length-62um: 270m
         sfp-vendor-name: CISCO-OPNEXT
  sfp-vendor-part-number: TRF2715AALB202
     sfp-vendor-revision: A1C
       sfp-vendor-serial: OPA111702xx
  sfp-manufacturing-date: 07-04-24
          sfp-wavelength: 850nm
         eeprom-checksum: good
                  eeprom: 0000: 03 04 07 00 00 00 01 00  00 00 00 01 0d 00 00 00>
                          0010: 37 1b 00 00 43 49 53 43  4f 2d 4f 50 4e 45 58 54>
Symmetris
Sat Nov 16, 2019 10:11 pm
Is this solved? I have a 1Gbps NTU connecting to a CCR1036....won’t work with a SFP (have tried generic and MIKROTIK) shows on but no link on other device!?
wesambhaya
Sat Jan 04, 2020 12:34 am
This solution solved the problem, a perfect solution.
Symmetris
Sat Jan 04, 2020 10:22 am
Sadly we don’t have control of the NTU but will request our backhaul provider forces 1Gbps (not autoneg) and test this.
BTW our work around of placing a tplink media converter in between the ports worked.
mbovenka
Sat Jan 04, 2020 12:43 pm
I have a TP-Link 1000BASE-BX10-U SFP in my CCR1036-8G-2S+. Works just fine.
KenY21
Wed Jan 08, 2020 11:08 am
I have a bit different problem with CRS212-1G-10S-1S+IN and SFP SM/MM modules here (viewtopic.php?f=2&t=155089&sid=63692533 ... 92ba8e5169).
I haven't tried krisjanis #3 post solution using SFP+ port, because I have two multimode connections and need to use 1.25G ports. Maybe someone has idea why S-85DLC05D doesn't work?
mkx
Wed Jan 08, 2020 12:06 pm
I don't think that speed setting in ROS actually affects the sync speed between two SFP modules. So if your modules are 1.25 Gbps, they will sync at that speed regardless the rate used by L2. And ethernet will be 1Gbps over those SFPs anyways because that's what standard says. The ROS setting actually affects L2 speed (in this case at least) and krisjanis' recommendation bypasses auto-negotiation (which can be problematic with SFP modules).
BR,
Metod
afink
Wed Jan 08, 2020 12:10 pm
Keep in mind that there are some SFP+ modules which can run at 1G as well as 10G speeds. So for these you might need to set the port to 1G speed if a the other side there is a 1G only SFP.
Users browsing this forum: No registered users and 7 guests
