molesza
Muti wan load balancing by gateway ip
Thu Dec 19, 2013 6:38 am
Hi all. I have 2 DSL connections on a wireless network. One DSL modem in one building and another in a separate building. Everything is connected to the same network subnet. Both modems have static ip addresses and have dhcp disabled. Clients pcs are setup using using static ip addresses. What I would like to know is whether it is possible to use an RB750 to load balance these two DSL connections without having a network cable directly attached to the modem. Can you just specify Ip addresses of each DSL modem as a gateway and combine and then point each pc to the mikrotik static ip. We don't use DHCP at all.
Thanks for taking the time to read my question.
aaronhun22
Re: Muti wan load balancing by gateway ip
Tue Dec 24, 2013 2:42 am
The MT must have a connection in some form (ethernet, fiber, or wireless) to both DSL endpoints in order to connect to them.
deejayq
Tue Dec 24, 2013 12:49 pm
you can try something like single interface routing
but your clients have to be on different subnet than the dsl modems are.
Users browsing this forum: No registered users and 132 guests
