Silvermoon
Multiple Lan on single wan
Thu Dec 26, 2013 12:44 pm
Hi All,
I am having a bitch of a time getting things to work how I think they should...
I have a 951h2nd, and have set up ppp-oe, wireless and all ports working, now I need eth-5
to be a separate lan, so far so good, everything seems to be set up, dhcp is working etc.
The only machine on the second network is a backup of my work SBS2003 server, it can ping
8.8.8.8 no problem but it cannot browse the web. I have disabled IE enhanced Security, disabled the firewall
but still nothing.. the only rules in my RouterOS firewall are
add action=drop chain=input dst-port=53 in-interface=WAN protocol=tcp
add action=drop chain=input dst-port=53 in-interface=WAN protocol=udp
SurferTim
Re: Multiple Lan on single wan
Thu Dec 26, 2013 1:08 pm
You should post "/ip firewall nat" also. If you are not masquerading your localnet ips, it will not be able to access the internet.
I presume you have a valid default route in "/ip route" if other interfaces work ok.
Silvermoon
Thu Dec 26, 2013 1:15 pm
Cheers SurferTim,
Below is my complete config. I also have issues where machines on my home lan (192.168.0.0) can connect to the net fine but machines on work lan (10.0.0.0) can't. (they can ping all over the place though :-) )
# jan/03/1970 03:10:49 by RouterOS 6.2
# software id = 34SD-GKT9
add admin-mac=00:00:00:00:00:00 auto-mac=no l2mtu=1598 name=bridge-local \
    protocol-mode=rstp
/interface wireless
set 0 band=2ghz-b/g/n disabled=no distance=indoors ht-rxchains=0,1 \
    ht-txchains=0,1 l2mtu=2290 mode=ap-bridge ssid=ISD wds-default-bridge=\
    bridge-local wds-mode=dynamic wireless-protocol=802.11
set 0 name=ether1-gateway
set 1 name=ether2-master-local
set 2 master-port=ether2-master-local name=ether3-slave-local
set 3 master-port=ether2-master-local name=ether4-slave-local
set 4 name=ether5-silvermoon
/interface pppoe-client
add add-default-route=yes disabled=no interface=ether1-gateway name=WAN \
    password=********** use-peer-dns=yes user=**********
/ip neighbor discovery
set ether1-gateway discover=no
set [ find default=yes ] authentication-types=wpa2-psk group-ciphers=\
    tkip,aes-ccm mode=dynamic-keys unicast-ciphers=tkip,aes-ccm \
    wpa-pre-shared-key=********** wpa2-pre-shared-key=**********
/ip hotspot user profile
set [ find default=yes ] idle-timeout=none keepalive-timeout=2m \
    mac-cookie-timeout=3d
add name=dhcp ranges=192.168.1.50-192.168.1.100
add name=Silvermoon ranges=10.0.0.200-10.0.0.210
add address-pool=dhcp disabled=no interface=bridge-local name=default
add address-pool=Silvermoon disabled=no interface=ether5-silvermoon name=\
    Silvermoon
add bridge=bridge-local interface=ether2-master-local
add bridge=bridge-local interface=wlan1
/interface wireless access-list: not used for 10.0.0.0
add address=192.168.1.1/24 comment="default configuration" interface=wlan1 \
    network=192.168.1.0
add address=10.0.0.1/24 interface=ether5-silvermoon network=10.0.0.0
/ip dhcp-client
add comment="default configuration" dhcp-options=hostname,clientid interface=\
    ether1-gateway
add address=10.0.0.0/24 dns-server=10.0.0.1 gateway=10.0.0.1 netmask=24
add address=192.168.1.0/24 gateway=192.168.1.1 netmask=24
set allow-remote-requests=yes
/ip dns static
add address=192.168.1.1 name=router
add address=10.0.0.1 name=Silvermoon
add action=masquerade chain=srcnat comment="default configuration" \
    out-interface="(unknown)"
add action=dst-nat chain=dstnat dst-address=xxx.xxx.xxx.xxx dst-port=80 \
    protocol=tcp to-addresses=192.168.1.2 to-ports=80
/ip firewall service-port
set sip disabled=yes
add disabled=yes distance=1 gateway=192.168.1.254
/ip service
set ftp disabled=yes
set ssh disabled=yes
/system clock
set time-zone-name=Pacific/Auckland
/system leds
set 0 interface=wlan1
add leds=user-led modem-signal-treshold=-51 type=modem-signal
/tool mac-server
add interface=ether2-master-local
add interface=ether3-slave-local
add interface=ether4-slave-local
add interface=ether5-silvermoon
add interface=wlan1
add interface=bridge-local
/tool mac-server mac-winbox
add interface=wlan1
SurferTim
Thu Dec 26, 2013 1:23 pm
You need a valid out-interface here, like ether1-gateway.
Silvermoon
Thu Dec 26, 2013 1:36 pm
Cheers Tim,
Where do I add that? I have a terminal open and I keep getting suggested commands... right pain in the ass!
SurferTim
Thu Dec 26, 2013 1:38 pm
If in doubt, add this rule and remove the rule with unknown in it.
add chain=srcnat action=masquerade out-interface=ether1-gateway
Silvermoon
Thu Dec 26, 2013 2:01 pm
Thanks Tim, that went well... NOT.
Completely killed net connection :-)
Luckily I have been coding since 1980 so I know how important a backup is :-)
N.
SurferTim
Thu Dec 26, 2013 2:10 pm
Is your pppoe interface called WAN? Try that as the out-interface on your nat.
Silvermoon
Thu Dec 26, 2013 2:15 pm
Just tried it... i get
"input does not match any value of interface"
Silvermoon
Thu Dec 26, 2013 2:17 pm
-gnore that.. had the case wrong :-)
Silvermoon
Thu Dec 26, 2013 2:20 pm
you beauty!!!
Many thanks Tim, my old SBS is now updating :-)
SurferTim
Thu Dec 26, 2013 2:24 pm
Good deal! My bad about the interface name. I did not see the pppoe part of your setup at first.
Silvermoon
Thu Dec 26, 2013 2:32 pm
Doh, it didnt work :-(
IE just got further with windows updating.....
SurferTim
Thu Dec 26, 2013 2:38 pm
If all your local interfaces lost internet connection when you removed that one nat rule, then try a "shotgun" nat. It masquerades all interfaces, even between local interfaces. Add this and remove any other srcnat rules.
BTW, what ip/subnet are you getting on your pppoe connection?
Users browsing this forum: Google [Bot] and 27 guests
