planetcaravan
Problem with disk space
Thu Dec 26, 2013 4:21 pm
Hi there,
I'm using RouterOS 5.25 on a RB1000. I'm sure that external flash card has problem but I'm not using it.
I've noticed that in the file section packages are downloading automatically without any manual action.
I delete theese file but system disk is still full.
What can I do? I've attached a screenshot.
planetcaravan
Re: Problem with disk space
Fri Dec 27, 2013 4:54 pm
Help me, please, I don't know what is using my system disk!
davestahr
Wed Jan 29, 2014 10:44 pm
I'm having the same sort of problems. I've read a lot about disabling user manager and uninstalling unused packages like dude, but none of that applies to my routers, where I haven't used user manager, dude, or anything other than the core routeros components.
I do routinely use syslog and log quite a bit of data -- I'm wondering if that's causing my problems.
Any ideas?
Lakis
Forum Veteran
Forum Veteran
Wed Jan 29, 2014 11:55 pm
No meter u have 1000xCF u can never use them as system "HD" memory
It is looking strange u should have at lest 16-20MB free
Well I suggest u to do netinstall but remove (no just disable - remove) all unused packages like wireless.npk dude.npk ups.npk keep only what u need
Also u can do that in System->packages, there u can uninstall some unused packages
RB1000 basically is old but it was very expensive it should have at least 128MB
plisken
Thu Jan 30, 2014 12:08 am
There is nothing else to run netinstall
http://www.wirelessinfo.be/index.php/mi ... netinstall
planetcaravan
Thu Jan 30, 2014 1:33 pm
Hi and thanks for all your answers. My RB1000 had and uptime of 250 days. As I was experiencing disk problem I bought a new RB.
I turned off the old RB1000 and it doesn't boot anymore!
So maybe my problem was that RB1000 was slowly dying!
plisken
Thu Jan 30, 2014 2:25 pm
With netinstall can you fixed the routerboard if this a disk problem
Goodluck with the new one
