CR24
PPTP VPN Question
Sat Jan 04, 2014 9:56 am
When connecting to PPTP VPN I can only connect to web admin of other devices, i.e. switches, if I have "Use default gateway on remote network" under TCP/IP Settings checked, which settings do you need to implement to be able to not use remote gateway and still reach other devices.
Thanks in advance for any help!
nerdtron
Re: PPTP VPN Question
Sat Jan 04, 2014 2:41 pm
How do you configure your VPN server? you should "push routes" from server to clients so that even without the default gateway option, your client will know the routes from the VPN server.
CR24
Thu Feb 12, 2015 2:02 am
I was able to fix this issue by having the PPTP address pool use the same pool as the internal DHCP server. I had a different address pool being used for PPTP clients.
Users browsing this forum: Baidu [Spider], Nexon and 85 guests
