planetcaravan
Question about RB912-OUT
Mon Jan 06, 2014 3:56 pm
I've just bought two RB912-OUT.
What is the purpose of the box in the first image? Is something for the ground?
I've another question. I've red the warning on the image I've attached.
Based on my experience with Mirkotik wireless device, each time I've access for the first time to a router, all wireless interface are on shutdown. Is it dangerous to operate with wireless interfaces off?
normis
Re: Question about RB912-OUT
Mon Jan 06, 2014 4:03 pm
The first bag contains the DIN rail mount. If you don't plan to put it on a DIN rail, ignore it.
Usually all wireless interfaces are turned on, and ready to operate. I don't believe we ship any products with disabled wireless interface.
planetcaravan
Mon Jan 06, 2014 4:07 pm
As I access to the device for the first time and I disable all wireless interface, is it safe to operate on the device?
normis
Mon Jan 06, 2014 4:10 pm
During the time when you access it, any transmit could damage the wireless interface. This is the reason we have a sticker on the unit.
planetcaravan
Mon Jan 06, 2014 4:13 pm
Thanks!
normis
Mon Jan 06, 2014 4:16 pm
Of course normally, if nothing is connected to the unit during this time, there should be no transmissions happening, so damaging the unit this way is very unlikely.
planetcaravan
Mon Jan 06, 2014 4:18 pm
I just want to connect the Ethernet cable with PoE!
plisken
Mon Jan 06, 2014 4:54 pm
Just disable wireless lan and it is ok
