rado3105
Cant update routerboard from 3.08 to 3.10
Thu Jan 16, 2014 11:21 pm
I upgraded routeros from 6.4 to 6.7 - successfully.
After this I updated routerboard in terminal: system routerboard upgrade yes
Then I restarted router....it didnt upgrade routerboard...
I repeated this steps 5 times, without success. Why?
normis
Re: Cant update routerboard from 3.08 to 3.10
Fri Jan 17, 2014 10:54 am
did you use power cycle or reboot command? try the other way
ditonet
Forum Veteran
Forum Veteran
Fri Jan 17, 2014 11:02 am
@rado3105
Try this:
ros code
/system routerboard settings set force-backup-booter=no
/system routerboard upgrade
/system reboot
HTH,
DWJ
Fri Jan 17, 2014 8:22 pm
I have found when doing upgrades, that use termail to do the upgrade install and then instead of using term to reboot, go to system>reboot and that works better.
