hendry
where are password wifi security settings?
Sat Jan 18, 2014 10:16 am
In WebFig v.6.7 I expected to be able to set the wifi password.
I couldn't find the dialog. Am I missing something? I know it's in "Quick set"... but wtf?
RouterBOARD 4xRB952Ui-5ac2nD & 1xRB952Ui-5ac2nD
https://natalian.org/2017/08/20/Choosin ... _Ubiquiti/
Venetti
Re: where are password wifi security settings?
Mon Jan 20, 2014 1:38 pm
The password is set in the "security profile"
Regards,
Benny
Venetti
Mon Jan 20, 2014 1:46 pm
Extra info: You first make or edit a security profile: wireless --> security profiles
in your wireless interface you have selected the default profile so edit your password in the default security profile.
plisken
Mon Jan 20, 2014 10:09 pm
Use winbox not alone quick set this settings are not completed
Open winbox... see http://www.wirelessinfo.be/index.php/mi ... ges/secure
Go to "wireless" and click on "Security profiles"
Click on the blue cross.
Set password and wpa2 in
Done
Zavi
Mon Jan 20, 2014 10:46 pm
At top of "wireless" page should be "security profiles" tab, create new (and set it in the interface configuration) or modify existing.
RB751G-2HnD & RB2011UiAS-2HnD-IN at home
hendry
Wed Jan 22, 2014 5:12 am
Thank you. UI could be better here.
normis
Wed Jan 22, 2014 8:38 am
You can do this in QuickSet tab, where it is much simpler. You are doing this in the "Advanced" interface now.
Users browsing this forum: No registered users and 35 guests
